Question about GE Nautilus 24" Built-in Dishwasher
We do not use our washer very ofter, when we tried today the water came in and then nothing. I don't see how it could be the moter, and it has electic to the settings.
  • 139 Answers
GE motors are known to lockup if not used for some time .take the bottom cover plates off. find the motor their should be an impeller vissible turn it to free up motor and its fixed!!
Posted on Aug 23, 2010
  • racerbill53 Nov 13, 2010
    I did what you said and it solved the problem. Thanks, you saved me having to buy a new one.
    My wife only runs ours every couple of months( it scares our dog).
  • vquirozmailu Aug 14, 2011
    Thank you very much. I don't know what to else to say. But you really saved me some good bucks.
    Victor in Long Beach, CA
Drops of water come out of my 2004 houndi elantra wiper washer moter i hear the moter i cleaned out hose but no pressure
Remove the hoses directly from the pump and try your washer. If you don't get a positive flow then either the pump is bad, obstructed flow to the pump or you have a low level in the reservoir
Oct 16, 2013 | 2001 Hyundai XG300
I have a pressure washer that sputer when i pull the trigger. The moter sounds fine but i have pressure then nothing and i have pressure. Thank you Stu
how do i unclog the end of my pressure sprayer it works on low pressure but when i put it on high pressure nothing comes no water comes out.
May 03, 2011 | Karcher 2500 PSI Pressure Washer
My washer turns some things inside out and wrings them so jeans legs are wrapped tight.the dryers balls things up so bad today my top bed sheet was wrapped into a ball inside the fitted sheet. Why is this...
Tying things in knots is a characteristic of older washing machines that didn't have an oscillating action. It was soon realised to avoid that the washer should oscillate or reverse the action by equal amounts and so that is what the automatic washer is designed to do.
Perhaps there is something wrong with the controller or the motor and it isn't reversing properly.
Laundry that is tied in knots is likely to cause the drum to be out of balance more than usual and so the tub suspension, the hoses, wiring and door seal will be subjected to more stress and that could be the reason for the mysterious leak.
Oct 19, 2017 | Amana NTW5400TQ Top Load Washer
Our PLD4375RFC2 dishwasher fills up with water but doesn't run
no their is no fuse. sound to me like your motor is not working, however
the pump should still drain out.push cancel only and unit should drain if it does then id say motor bad. you can try to take apart and check motor blade ive seen toothpics, food , other objects hold motor impeller from turning making it seem like its the motor but actually its just stuck..remove btm wash arm and filter cover thentake two or 3 small screws from a plastic cover covering motor impeller, look to see if anything is in their if so remove. warning if you see a white ball down their leave it alone reinstall and see what happens. hope this helps.
Sep 17, 2009 | Frigidaire PLD4375RFC Dishwasher
Maytag washer performa model pavt234aww, just now 5 years old. -Two weeks ago, it started making an intermitten "loud-funky" noise, but worked just fine. Today, it filled up with water and simply died. We...
i would concentrate on moter moters have a limit not replacable , the whole moter would need to be replaced also check the lid switch this can cause a intermitant issue . as far as fixing or replacing its a issue you need to weigh out .
Aug 10, 2009 | Maytag PAV2300 Top Load Washer
My washer is not spinning or draining properly, the timer is working, it will continue until it is in the off position but once it is my clothes are sopping wet. Is there a part I need or anyway I can fix...
if it is a top loader the moter controls the pump and spin u need to check power to the moter and clutch i.e if the moter runs but no spin the clutch has gone if its not geting the water out i can be the moter the best way to check is take the waste pipe out and put it in to a bucket and turn on the water should jet out if not the pump may be blocked try these first
Jul 29, 2009 | Kenmore 24032\24036 Top Load Washer
Washer spins but really really slow, not fast enough to extract water
it can be the pump if it does not get the water out fast it will slow spin best way to check put it on spin with nothing in and watch it if it does the same then the moter is faulty change it try ebay for replacements
Jul 28, 2009 | Speed Queen ATS90AWN Front Load Washer
Will not agitate,spin or drain
There's a coupler that normaly goes.just tip the machine over and loosen the motor.the coupler will be 3 legged and plastic.just replace and it should be ok.
Feb 22, 2007 | Whirlpool LSR5132PQ Top Load Washer
GE Nautilus 24" Built-in Dishwasher Logo
683 people viewed this question
Top GE Dishwashers Experts
Mike
Oloyede Monsuru
Are you a GE Dishwasher Expert? Answer questions, earn points and help others
