Question about Whirlpool Refrigerators
Is the card board covering condensor coil supose to stay
  • 139 Answers
Yes the fan needs that cover their to remove the heat from the coil under the frig so put it back on
Posted on Aug 23, 2010
Refrigerator will not stay cold and ice is building up in freezer.
your compressor or condensor or capacitor is bad, need a technician
Dec 11, 2015 | Maytag Refrigerators
Tip
Easy way to check if ur condensor coil is clean
while in operation, with condensor fan running, hold a piece of thick paper up to condensor coil, let go of paper, ir it stays stuck to the coil, the fan is pulling air thru, cooling the coil temp. this is good. if the paper dont stay in place ur condensor coil is dirty and needs to be cleaned
on May 22, 2010 | Heating & Cooling
Refridgerator side not getting cold model gss201epaww
make sure the damper vent door located between the freezer and refrige compartments is opening and letting in cold air from the freezer,if they ice up they can stick shut and not allow air flow,this door is behind a plastic grille an a hair dryer works great to defrost them
Apr 30, 2010 | Refrigerators
When I moved, the cardboard backing on the bottom of the fridge was wrecked and subsequently removed. Is this vital to the fridge's performance and can I replace it with another piece of cardboard? It...
yes that panel directs the air flo for the condenser fan that helps keep the compressor cool and moves the air over the condensor coils you can use card board just make sure you put air holes so the fan can pull air in
Mar 07, 2010 | Frigidaire 20.6 cu. ft. Top Freezer...
Inside strip of fridge is very hot. cleaned out behind fridge and the coils, etc. fan is barely moving/not moving. any suggestions???
Replace the fan. The strip has a freon line running behind it, and when it is hot, this tells us that you have a dirty condensor, bad condensor fan motor, bad evaporator fan motor, defrost problem, or a freon system problem. When you say your fan is barely moving, I am assuming this is your condensor fan motor, which sucks air through the hot freon lines in the condensor coils, and cools the freon off. If it is barely moving, it can't cool the freon. In some brands a slow moving condensor fan can be caused by a bad main control board. Good Luck, Appliance Specialists
Jan 28, 2010 | Refrigerators
Vacuum condensor light flashing and the refrigerator won't get colder than 51 degrees.
The light is indication a problem with the condenser coils being covered with dust/dirt and cannot dissipate the heat energy absorbed by the system in the evaporator coils (freezer). Or the condenser fan is not running. Clean the condensor and/or check the fan.
Nov 12, 2009 | Sub-Zero 650 / O Bottom Freezer...
Ge tpx21pr side by side refig/freezer Freezer is not cold enough
If your unit is NOT a static condensor, (the type with cooling fins and tubes on the outside of the back of the unit) If the door seals are okay and sealing properly, you might need to service the forced air condensor components located at the rear lower area, usually behind a fiber board cover. Remove the cover and look for dust on the condensor fins and fan blades. If clogged, carefully brush, vacuum, or blow the dust out, opposite the direction of the fans natural air flow direction. (You don't want to lodge the debris further into the condensor fins.)..Be sure to unplug the unit first.
Jul 31, 2009 | Refrigerators
Condensor won't stay on
Compressor is overheating. You need to make sure your indoor and outdoor coils are clean. Sometimes it just needs a vacuum job. If you hose the outside coils, be sure to do it from the inside out. Hosing from the outside will just pack the dirt in farther.
Jul 28, 2009 | Heating & Cooling
No video from the board
Check the motherboard user guide for how to reset to default factory settings. If the BIOS is set to work with the on-board only and the on-board VGA is dead the motherboard is supose to detect that and switch to AGP. If is not doing that chances are not only the on-board VGA controller is gone ... the motherboard is gone too.
Try with a PCI video card.
1.Reboot with the AGP or PCI video card installed - assuming the on-board is gone but the motherborad still OK.
2. Press DELETE key
is supose to go in BIOS settings menu.
Browse and Look for on board VGA adapter ENABLE/DISABLE setting or something similar.
(My bet ? You need a new motherboard.)
Jan 12, 2009 | Intel Motherboard
GE Side By Side refrigerator evaporator freezing up
There is a pc board that senses how long the condensor motor has been running and when it gets to a certain amount of time it turns off the refridgerator condensor and turns on the heater coil that melts any ice formed on the condensor coils untill a temperature sensor says enough then it allows the condensor motor to run again. The problem is definitely in this board which is a common problem with Whirlpool and related brands. This board is about 50 to 75 dollars and can be easily replaced.
Sep 04, 2008 | Refrigerators
Refrigerators Logo
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Dan Webster
Dan Webster
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
