Question about Vacuums
I borrowed a Shop Vac Ultra plus wet dry vacuum to use as a dry vacuum. It needs emptying. How do I open it, and clean the filter? Thanks
    Problem Solver:
  • 10 Answers
Posted on May 04, 2008
So I just got my shop vac second hand and it has no manual and no basic instructions were given either. Does it actually need a bag when using it? I feel like something may be broken or missing....
Shop cacs are multiple purpose dry/wet intake so typically you don't need a bag. You just open the tank and empty it like a big trash can. They will have a large filter In the tank that needs to be cleaned/replaced.
Oct 16, 2015 | Shop Vac Vacuums
How do you change the ridgid 9 gallon wet/dry shop vac from a dry to wet vac? Is it simply changing the hose to the back fitting?
all you have to do is open it up and take the paper filter off and then it's a wet vac. If it has a foam over filter you leave that on
Oct 13, 2009 | Ridgid 9 Gallon Wet/Dry Shop Vac 96882...
Vac doesn't work well after cleaning
check your filter
it the round thing hanging from the middle
you may need to clean or replace your filter
you should never leave the filter in while using it as a wet vac that will ruin it immedatly
Oct 09, 2009 | Shop Vac 925-09-62 QSP Plus Wet/Dry Vacuum
I've been using a small shop vac in the seller to vacuum up dust, sawdust etc. I have emptied the inside and the filter looks laden with dust. It does not "****" any longer. What is wrong and what do I do...
you have to clean the filter too. Use an air hose to clean it or brush it off with a stiff brush or you can wash it if it isn't paper. As a last resort you can get a new one.
Oct 04, 2009 | Shop Vac 925-13 Canister Wet/Dry Vacuum
Hi there I have a Shop.Vac QS800 57519-63 its about 6 years old. I don't have manual for it & want to know how I can use it in the wet mode Thanks for your help. Jasper
To use a shop vac to **** up water you just need to remove the filter element inside. open it up just as if you were going to empty out the dirt and on the top center you will see a filter. unscrew the retaining nut on the bottom and remove filter. After unit is dry and you are done using it in the wet mode replace the filter and put the retaining nut back on.
Aug 09, 2009 | Vacuums
Blowing stuff out the back
It sure sounds like your filter broke. Replace the filters.
May 29, 2009 | Shop Vac 925-09-62 QSP Plus Wet/Dry Vacuum
My shop vac won't turn back on after emptying
I'm afraid you'll need to take it apart. the switch is mounted in a plastic holder in the top. While you got it apart and without it plugged in, check to see that both brushes are touching the commutator. there should be sufficient spring tension to hold the brushes against the spinning part [commutator] if even one brush isn't making contact it won't spin.
Sep 10, 2007 | Shop Vac 925-13 Canister Wet/Dry Vacuum
Vacuums Logo
Top Vacuums Experts
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
