Question about Craftsman 42 in. Precision Cut Plus 24hp Lawn Tractor
It leaves the center uncut - Craftsman 42 in. Precision Cut Plus 24hp Lawn Tractor
    Brigadier General:
  • 3,911 Answers
I think i would raise the whole thing up on jack stands and take a look at the bottom of the deck. do not start it of course, but the problem should be evident. 42 inch generally means only 2 blades which are cutting on the outside leaving you a mohawk. so something is blocking the grass from being cut in the center. if it is by chance a 3 blade deck , then something is wrong with the center blade, if it is there i would guess a broken key.
Posted on Aug 23, 2010
  • Bernard Welch May 12, 2012
    TRY CHECKING THE MANDREL. YOU MAY HAVE HIT A FOREIGN OBJECT THAT STOPPED THE BLADE AND AS A RESULT STRIPPED THE GEAR ON ONE OF THE MANDRELS.
Cant get blades to full RPM replaced all idlers all belts greased spindles new elec. clutch new blades when cutting grass it leave rows of uncut grass
if the blades wont get up to speed or not cutting grass you have a belt that is slipping. could be the pulley is damaged or just a worn out belt. if it is leaving a strip of uncut grass you have a blade that is wore down on the ends not cutting the full path
Aug 05, 2017 | Garden
Husqvarna yth24v48ls leaves streaks of uncut grass
What are the size of the streaks? and where in the 48 inch swath?
Aug 06, 2014 | Husqvarna 23 Hp 48" Deck Yard Tractor
Why is my husqvarna zero turn leaving a strip of uncut grass on the left side of the deck
I have a 2014 HUSQVARNA RZ5424 that I just changed the blades on for the first time now 2017. I got new gator blades because of all the good reviews on them. They are about as good as a screen door on a submarine at 300 feet deep. There the same length as the original blades but leaves two rows of uncut grass about a inch wide regardless of how you try to cut it. Only 240 hours on mower, deck clean ,spindles kept greased . Went back to new Husquvarna blades like the ones made for it. PROBLEM SOLVED. HAPPY HAPPY HAPPY. REL.
Mar 24, 2013 | Husqvarna Rz5424 Zero Turn Lawn Mower...
Uncut grass in center & higher grass cut on right.
Hi, this may sound obvious but make sure the new blade is the same type as the old one and make sure it is not fitted upside down. Spin the blades and make sure the tips are level with each other, this will tell you if the deck is straight where the blade spindles mount. Regards Phil.
Jun 24, 2012 | John Deere Garden
When mowing with my John Deere riding mower, it leaves a narrow strip of grass uncut in the center.
try sharpening the blades on the mower. dull blades can sometimes cause a strip of uncut grass
Aug 19, 2011 | John Deere 22HP VTwin 48" Riding Mower
Toro 42 " Zero Turn; In tall grass and even in moderate grass it is leaving a double strip of uncut grass, that lines up with the division between the centre blade and both outsice blades, resulting in...
Your blades may be erroded on the edges? Or the center blade hub might be damaged or worn.
good time to inspect all the blades and spindles for wear or damage.
Jun 26, 2010 | Toro 42'' Zero Turn Lawn Mower 22hp Kawa...
I have a Craftsman Lawn tractor. Blade leaves grass uncut.
Hi Tom,
Check your spindle shafts for loose play. If your bearings are worn out and sloppy, the belts pull the spindle to one side and an angle cut results... close cut grass at outer edge and high in center will leave this grass trail you are describing. I'd replace the bearings next year for sure.
I hope this helps... Good luck!
Oct 04, 2009 | Garden
I have a 19hp craftsman 42 deck. It has two blades. It does not cut the grass in the center. It leaves a strip uncut. What adjustment should I do
You may be running too fast on ground speed for the mower deck to cut completely. It may be time for some new blades. The blades may be worn down to where they are shorter than when they were first put on.
Sep 26, 2009 | Craftsman 20 hp 42 in. Deck Lawn Tractor -...
Mower leaves a uncut srip of grass through the center of the mow area!
The blades need inspected and sharpened,one could have a bent tip or just dull,if youve had someone else pull them off and reinsall them already check to make sure one of them isnt installed backwards,dont laugh,Ive seen it happen.
Aug 08, 2009 | Husqvarna 22 Hp 46" Deck Yard Tractor
42 inch craftsman. Replaced bades and now have a row of uncut grass in the center of cut.
OOPS! I hate to tell you but you most likely put new blades on that were too short. Check your manual and get the proper length blades. If you still have the old ones, check them against the new ones and you will see that they are shorter resulting in the uncut grass in the center.
Jun 23, 2009 | Craftsman 20 Hp 42" Deck Lawn Tractor
Craftsman 42 in. Precision Cut Plus 24hp Lawn Tractor Logo
187 people viewed this question
Top Craftsman Garden Experts
Wade Mobley
Wade Mobley
Jim Parker
Jim Parker
Dennis Key
Dennis Key
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
