Question about Linksys Wireless-G WRT54GS Router (e125894)
I have a linkys wireless 54gs. I can not get internet access from my modem to my router. Only from my modem to my computer directly. Can anyone help me with this problem. Thanks
SOURCE: configure WRT300N wireless Router to connect internet using PPPoE
Often the nets and subnets are NOT the same.. ie The Fixed connection often uses 192.168.0.1, 192.168.1.1, however sometimes the wifi is setup 10.1.1.1, or 10.0.0.1 etc, have you checked this? Esentially tho ya router is an "Acess Point" and ya Lappy etc is ya "Client" the links below has a lot of tutorials to help have a look. http://portforward.com/routers.htm http://portforward.com/guides.htm
Posted on Aug 05, 2007
  • 218 Answers
SOURCE: Computer says I'm connected to wireless but no internet connection...can connect directly through modem.
A few more thoughts:
1. Have you installed or changed any firewall or security settings?
2. Try resetting the router, turning off the modem for a minute. Then turn them back on and give it another try.
3. Are you sure that your laptop is connected to your router and not your neighbor's? (Look at "Network Connections" in control panel.)
4. If you have another ethernet cable, connect to the router with a cable and then try to reach the internet.
5. If none of this helps, then look under the couch cushions for some cash to buy a new router.
6. Good luck!
Posted on Jul 16, 2008
shoran
  • 54 Answers
SOURCE: cannot access internet with a linksys router
Make sure DHCP is turned off on the modem or else you will get ip conflicts. Also make sure it is plugged into the wan port on the router
Posted on Jan 15, 2009
Joed911
  • 4338 Answers
SOURCE: No more internet thru router after new modem installed
Router setup
Go to the control panel and un-install the program that the Comcast cd installed. then:
Shutdown your PC. Unplug the power from the router and the cable modem.
Wait 30 sec. then plug in the power to the cable modem, wait 30 sec. then plug the power to the router. Wait till you have "Internet" light then restart your PC. The PC should pick up an IP address and you should be able to get on-line.
Did Comcast reset you wireless router settings? If so, you may need to set up your SSID and security settings.
Customizing Wireless Settings of the Router
Having default wireless settings on the Linksys router may cause conflict with other Linksys routers within your network range. Linksys suggests changing the SSID (network name) and the Wireless Channel of your router. Also, if it is possible, enable the Wireless Security of your router.
To change the router’s SSID or the wireless network’s name, click here.
To change the router’s channel, click here.
To enable the wireless security on the router, click here.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
Posted on Jun 06, 2009
Wi fi is on but still can't connect to the internet
Not only does Wi-Fi have to be on, but it has to be connected to a wireless access point (sometimes called a wireless router), and the wireless access point has to be properly connected to the internet.If the wireless access point/router has empty ports on it, plug your computer into one of those ports, and see if you can connect to ther internet then. If you can, the problem is somewhere between the wireless access point/router and the computer. Could be the transmitter part of the wireless router, could be the wireless network adapter on your computer, or could be the driver that runs the wireless adapter on the computer. If you cannot access the internet when you plug into the wireless ap/router, then you need to go one step "upstream." This would likely be the cable modem or DSL modem. Plug directly into that with your computer, and reboot both the modem and the computer (just unplug the power from the modem and then plug it back in to reboot the modem). If you can connect to the internet then, the problem is the wireless router/ap. If you cannot connect to the internet then, contact your ISP.
Feb 09, 2012 | Gateway 7330GZ Notebook
I can connect to my di-614+ through wireless connection but i don't have internet access
sounds like the router and modem arent talking what kind of internet connection are you using and have to tried accessing the internet with the ethernet cord that runs from the modem to your computer. if you cant access the internet with that direct connection to the modem you might have a bigger issue
Mar 21, 2011 | D-Link AirPlus DI-614+ Wireless Router
I am installing linskys to my home computer. I follow al of the directions on the linkys cd but when i switch the wire from the modem to the router and plug it back into the tower i wil not have an...
I think you need an extra cat-5 wire.
1.
Plug one CAT-5 LAN cable into the port labeled WAN on Linksys then the other end into the cable Modem where your PC is normally
2.
now take a separate Cat-5 LAN cable adn plug it into port 1 on the linksys - the other end into your PC NIC
3.
Power cycle Cable Modem (remove battery), linksys, PC this will clear the MAC addresses
4.
turn on modem, linksys then pc
5.
loging to windows - open IE on address bar type 192.168.1.1 - this should be the default address of your router (unless you've changed your subnet) in which case I recommend you factory default the route and use default settings. after typing teh 192.1386.1.1 you should see the linksys login
6.
Now try yahoo.com in IE, the routers factory setting for DHCP should work fine without any end user programming from you.
please rate me, good luck
Aug 24, 2010 | Linksys Wireless-G Broadband Router
I have linkys wireless router model wrt54g2v1.after i back up my computer i lost the linkys file. i cannot find cd for installation. now i am unable to open internet.
mpshyla
The reason for the CD is to configure the router to your cable modem. So if you reinstalled your computer you do not need the CD again. All you need to do is set the computer's Gateway back to your router. The links below will help you do this.
http://www.fixya.com/support/r4602477-check_change_computer_ip_address_in
Let me know if you have any more problems or questions.
Issken
http://www.fixya.com/users/issken
Aug 09, 2010 | Linksys WRT54G2 Wireless Router
Computer will connect to internet when connected
Make sure that your computer is able to go online through the modem.
If your computer is not able to go online through the modem then you will need to call ISP first.
If your computer is able to go online through the modem
then you need to connect the computer to the router and the modem to the router.
open the set up page of the router and change the settings of the router according to the ISP.
Click Here for step by step by instructions
May 21, 2010 | Linksys WRT54GX2 Wireless-G Broadband...
Cannot connect to internet via router WRT 54GS
May 08, 2010 | Linksys Wireless-G WRT54G Router
Cannot access internet with a linksys router
Jan 15, 2009 | Linksys Wireless-N WRT150N Router
Linksys Wireless-G 2.4Ghz Broadband Router Problem
You have to check if your computer can connect to the modem with an Ethernet cable. This will tell you if the ethernet port on the modem is working. if that does not work call your cable provider.
Next thing after you get the instructions above done.
Press the reset button on the back of the router> press it in for 30 seconds then let go and pull out the power. Connect the router up the way it should be before you reset by the way. check if you have internet if you do not follow hte directions at teh link below.
CABLE SETUP
If you need more info just message me
Aug 29, 2008 | Linksys Wireless-G Broadband Router
This is a common problem with linkys wireless g routers, as you say that you modem works fine with usb..no problem with your isp, so go head and first upgrade the routers latest firmware..reset and reconfig your roter your issue will get fixed..try it out.
Feb 28, 2008 | Linksys WRT54GX2 Wireless-G Broadband...
Linksys Wireless-G WRT54GS Router (e125894) Logo
23 people viewed this question
Top Linksys Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a Linksys Computer and Internet Expert? Answer questions, earn points and help others
