Question about Janome 4618 Mechanical Sewing Machine
What setting for twin needles - Janome 4618 Mechanical Sewing Machine
  • 109 Answers
Just put it on STRAIGHT stitch and insert your needle flat side to the back and you're off!
Posted on Aug 23, 2010
Can I use a twin needle on a Pfaff 2056
Since your machine can do decorative stitches, I would think it can take a twin needle. Just BE SURE you have installed the needle plate with the wide hole for the needle and do NOT set a wider stitch than the twin needle can accommodate on it's widest setting without checking by turning the handwheel--the twin needle will overreach and either hit the presser foot or needle plate and sent needle shards flying!!! The manual should have instructions.
Apr 26, 2018 | PfaFF Sewing Machines
Can I use a twin needle on a Singer Trafition? It seems to only sew one line of stitches.
Probably depends on the model. Was a twin needle included with your starter kit?
This one indicates it will take a twin needle:
2277 TRADITION
Your owner's manual or the product specifications are probably the best source for information.
Instruction Manuals
BTW, you are using 2 spools of thread, right? You need to thread both needles with separate spools (do not twist the threads when threading!).
Double Needle Tips Video Demos
How to Use Twin Needle on Your Sewing Machine
Be sure to verify the machine is set to straight stitch. Any zig-zag could break one or both needles!
You also will have to thread the needles manually as the needle threader will not work on twin needles.
ALWAYS RAISE the presser foot when threading the top thread!
Jun 22, 2017 | Singer Sewing Machines
I inserted the twin needle and threaded it. However, I don't know what what stitch I should use.
we have no idea here either try someplace that gives sewing classes locally
Feb 16, 2017 | Sewing Machines
How to thread with double needle
You'll need to use two separate spools of thread. Machines that take a twin needle will usually have separated thread guides and two separate tension disks. Just make sure the threads are not twisted when threading. Might be better to thread one all the way through and then thread the second.
How To Use Twin Needles
Be sure to check the width of your stitch when using a twin needle. Because the needles will be wider than a single needle, it is very easy to hit the needle plate if setting it too wide.
Jun 11, 2016 | Elna 1010
How do I thread my twin needle on my SQ9185 machine correctly so as not to break the needle again. The diagram in the manual is a little "sketchy".
with twin needles
you thread the first needle like you would a single needle and then you thread the 2nd needle then same way
make sure the setting are fixed for a twin needle
Feb 28, 2015 | Brother Sewing Machines
Code E8 on brother Model Ns40
Yes the manual for Brother sewing machines are available from their support site: http://www.brother-usa.com/manuals/default.aspx?ProductGroupID=3#.TyH3fIFtNG9 . I believe the NS40 is the Brother Innov-is 40. The direct link to the manual is http://www.brother-usa.com/ModelDocuments/Consumer/Users%20Manual/UM_Innov_%C3%ADs%2040_%20NEW%20Limited%20Edition_EN_1114.PDF . An E8 error means that a stitch was selected after the twin-needle setting has been selected. Cancel the twin-needle setting and then select a stitch. Then if you are using a twin-needle setting, adjust the machine for the twin-needle setting.
I hope this helps.
Jan 26, 2012 | Brother Sewing Machines
Using twin needle with Janome dc3050
you can just use the straight stitch.If you want to use a fancy stitch you have to be careful that the throw, as I call it is not too wide as you could break the needles and put the timing out. Also use a longer stitch than normal.Also use the stretch twin needle.
Jan 30, 2010 | Janome Sewing Machines
Will the Elure ESL model accept a twin needle
The site shows a twin needle setting.
http://www.babylock.com/embroidery/ellure/
Have you looked at your manual or bought the more expensive book from your dealer? I have found my book for my Evolve a VERY good investment (70 bucks, but worth every penny these past 2 years!)
Baby Lock have very good cust. service either on the web or right at your dealer. Most dealers will give free lessons upon request.
I hope this helped
Jan 20, 2009 | Baby Lock Ellure
Twin needle
Any universal twin needle should work, there is no attachment. Just don't set your stitch width too big if you are in zig-zag!
I hope this helps and good luck.
Dec 15, 2008 | PfaFF Hobby 4260
Janome 4618 Mechanical Sewing Machine Logo
76 people viewed this question
Top Janome Sewing Machines Experts
Tally Girl
Tally Girl
Douglas Plant
Douglas Plant
Eva Hack
Level 1 Expert
Are you a Janome Sewing Machine Expert? Answer questions, earn points and help others
