Question about Sony Cyber-shot DSC-W80 Digital Camera
My camera can't capture photos.. when i turn it on its says that turn off then turn on again.. and the lens opens then close.. again and again..
  • 6,831 Answers
Hello
The problem is that the lens has become stuck in the barrel after dropping it. There are some DIY solutions you could try, but the probability is that you will have to get it fixed by a professional.
Use these at own risk as it may further damage the camera.
Firstly , try connecting your ac adapter or usb cable.
Try holding the shutter button while switching on the camera.
Look at the lens , and if some of the lens 'circles' is misaligned or not concentric then try wiggling it (while holding camera lens down).
Try gently pushing or pulling the lens when it extends but this is risky as it may cause the lens barrel to slip out of its guidance system.
Another way to do this is to place the camera lens down on a hard surface and then power it up. Be sure to use a soft cloth or something similar as to not scratch your lens or casing. Let the lens push the camera up and down a few times and sometimes the little resistance provided by the camera is enough to get things going again.
Try hitting your camera near the lens on the body with the soft tissue on the palm of your hand.
Other than that , I would take the camera to a repair center for a evaluation to see if it would cost more to repair than to replace the camera.
If it is still under warranty I would suggest you take it in before trying any of these steps and remove any off-brand batteries or accessories as some stores are really fussy about warranty repairs on camera's with non-brand accessories.
Hope the advise is useful.
Regards
Andrea
Posted on Aug 23, 2010
Testimonial: "thank you!"
  • 59 Answers
SOURCE: Shutter won't open/close, and blank screen on "capture."
It prolly took a bump at some point or has crud inside...try cleaning it GENTLY with alcohol NOT WATER.
Posted on Aug 27, 2007
  • 188 Answers
SOURCE: when turn camera on lens opens and close
there is a friction in the movement of the lense assembly. It is not reaching to its proper position. This happens if you drop the camera, or the camera is exposed to sand. a repair technician can fix it.
Posted on Mar 21, 2009
  • 98 Answers
SOURCE: lens will not open to take photos screen says to turn camera off and on.
You have an defective lens assy is it fallen on the floor o ris it shove
Otherwise there some contamination in the gearbox of the zoom assy It can only retosred by an repairshop. They clean the lens assy or change it.
Regards,
Rob NL
Posted on Apr 19, 2009
SOURCE: MY CAMERA LENS OPEN CLOSE E READY ACSESS NO
so i charged my battery, and same thing happends. Bought a new battery, didnt chatge it fully, but had one charge bar on it and the same thing is going on??????? ANy suggestions
Posted on Jan 16, 2010
Kensolutions
  • 455 Answers
SOURCE: turn the power off and on again message
Error: TURN THE POWER OFF AND ON AGAIN is displayed on the LCD screen when the Lens Mechanism is stuck or when affected by any malfunction. If turning the power on and off again does not resolve the error message, try doing a power reset and Initialize option.
Performing a manual power reset
Turn off the camera.
Remove the battery pack.
Press and hold the power button for 30 seconds.
Allow the camera to remain without power for 60 seconds.
Reinsert the battery pack.
Turn on the camera.
To reset the Camera back to factory default, select the INITIALIZE Option from the Main Settigs 1 Menu of the Camera to OK.This will set the user defined settings back to factory default. The images and videos will not get deleted.
If the issue persists, service may be required.
Thanks for contacting FixYa
Posted on Apr 01, 2011
Camera not displaying images as seen through viewfinder. The screen is black. Image controls and info can be seen but the picture is just black. Takes photos which are also black; but previous photos...
A stuck shutter is another common failure mode for digital cameras, particularly for the SD1000. The symptoms of a stuck or "sticky" shutter are very similar to CCD image sensor failure. The camera may take black pictures (for shutter stuck closed), or the pictures may be very bright and overexposed, sometimes with lines, especially when taken outdoors (for shutter stuck open). To confirm a stuck shutter, put the camera in any mode other than "Auto", and turn the flash OFF (you don't want to blind yourself for the next step). Next look down the lens and take a picture. You should see a tiny flicker in the center of the lens as the shutter opens and closes. If no movement is seen, then you likely have a stuck shutter. If so, please see this link for further info and a simple fix that may help.
By the way, my wife's SD1000 also has this problem every once in a while. I easily fix it by using the following steps from the link: powering on the camera, opening and closing the battery door, and flicking the end of the lens barrel with my fingertip (or you can tap it with a pencil as discussed in the link).
Feb 06, 2011 | Canon PowerShot SD1000 Digital Camera
My kids accidentally dropped my Panazonic Lumix TZ-10 on the floor (not from a great height). The lens at that moment could only half close, but after turning power on and off a few times, now it opens and...
The warranty is unlikely to cover accidental damage but you could check if you have any insurance cover, perhaps in house contents or travel, or you might ask the retailer if he would help under 'goodwill'. It sounds as if the lens extension mechanism was pushed out of kilter and cannot now complete its opening cycle so...as a last resort...you could try taking out and replacing the card or gently waggling the extended lens to see if this could help. Hope you can get it working again!
Dec 26, 2010 | Panasonic Lumix DMC-TZ3 Digital Camera
The diafragm it´s closed not
I dropped the camera and got the same problem, until I read somewhere in this site that open the camera and then tapping on the ring around the lens while power on and off several times, it will work again. I did for me. I took it apart with phillips screwdriver and I used a hard rubber caulk spreader to tap it; it has some weight but will not damage the lens if its it by mistake. Try this and will be surprised. I am the 3rd person I have read that solved it doing this. Web ready Video is good in this camera. Good luck.
Oct 29, 2010 | Pentax Optio MX4 Digital Camera
Turn the power off and on again message
Turn on the camera.
Feb 15, 2010 | Sony Cyber-shot DSC-W170 Digital Camera
Lines on screen and photos, too bright photos outside
Lines across your pictures or pictures too bright are due to the shutter not closing correctly or at all.
to check this- turn camera on, turn off flash, turn camera around and look into the lens. Adjust the zoom so that the shutter and internal lens comes up to the end of the lens and whatch as you take a picture. You should see the shutter close completely over the lens. If it doesn't move or does not close over completely then there is your problem.
If camera was dropped it could have jammed the shutter open or obstructed it in some way from closing completely.
camera will require repair/ service.
You may have some luck if you power up and down your camera numerous times before taking a picture. The action of the lens opening and closing may free the shutter.
Aug 07, 2009 | Fuji FinePix V10 Digital Camera
Lens will not open to take photos screen says to turn camera off and on.
Regards,
Rob NL
Apr 13, 2009 | Sony Cyber-shot DSC-W55 Digital Camera
S800 lens won't close, can't take photos
The lens was bent to one side, so bump with my palm to straighten it back. I was able to start using my Samsung again.
Mar 21, 2009 | Samsung Digimax 800K Digital Camera
Not able to shoot photos
OK, I have this camera and it started doing this to me about a week ago.  I assumed it had reached the end of it's life after many, many excellent photos.  As a last resort when the lens popped out after first switch on (when it's doing the clicking business) I grabbed the lens and wiggled it gently back and forth (as if zooming a conventional SLR).  It appears to have been fixed, remarkably!  I switched off and switched it back on and all seems OK.  (I'm not holding my breath and will probably keep looking for a new one but for the moment it's sorted out.)
Mar 17, 2008 | Sony Cyber-shot DSC-W50 Digital Camera
Aug 27, 2007 | HP Photosmart R727 Digital Camera
Lens won't retract : /
Another common problem. Lens troubles. You have either knocked your lens out of alignment or you have a foreign body jamming up the works in the lens control unit. There have been many so called fixes for these problems but usually end up causing more problems than curing. You could check that you have fully charged new batteries. Some cameras need that extra kick to get them to open the lens fully. Worn out batteries can stop a sticky lens in it's tracks and tell the processor there is a problem and to close down. It's well worth trying before writing it off.
Jul 06, 2006 | Panasonic Lumix DMC-FX8 Digital Camera
Sony Cyber-shot  DSC-W80 Digital Camera Logo
320 people viewed this question
Top Sony Cameras Experts
james laughton
james laughton
JonSnell Electronic
JonSnell Electronic
Are you a Sony Camera Expert? Answer questions, earn points and help others
