Question about Texas Instruments TI-30XA Calculator
Calculate 28 cot 30 - Texas Instruments TI-30XA Calculator
  • Texas Instru... Master
  • 7,993 Answers
If you remember that by definition cot(theta)=1/tan(theta) your expression can be calculated as 28/tan(30). Use parentheses if necessary to enclose the whole tan(30) factor.
Before calculating any trigonometric function make sure that the angle unit is set correctly. In your case I presume that 30 means 30 degrees. Use the [DRG] key to cycle through the angle units.
Posted on Aug 23, 2010
Is it possible to calculate factors using a TI-30x IIS
I believe factors can be calculated on any basic calculator.
Starting with 1, increasing by 1 until you get to square root (number) + 1
Let's do an example.
28
square root (28)+1 = 6
Factors
1, 28/1=28
2, 28/2=14 14*2 - 28 = 0 (when you divide, you get no decimal)
3, 28/3=9.33333 - not a factor - doesn't go in evenly
4, 28/4 =7
5, 28/5=5.6 - not a factor - doesn't go in evenly
6, 28/6=4.66666 - not a factor
So now we can list our factors - 1, 28, 2, 14, 4, 7
Putting them in order, we get 1, 2, 4, 7, 14 and 28.
Good luck,
Paul
Jul 13, 2016 | Texas Instruments TI-30 XIIS Calculator
How do i get sec csc and cot on my fx82ms calculator
Use the cosine, sine, and tangent buttons on your calculator and invert them with x ^ -1 key.
For example, csc = 1/sin. So for csc 30 degrees, so sin 30 degrees, then hit the x^-1 key.
Good luck.
Paul
Nov 10, 2015 | Casio FX-82MS Scientific Calculator
How do I find out the cubic feet for Maytag washer model A412?
Calculate it yourself: Place a straight edge across the top of the unit. Measure the height from the bottom of the tub to the bottom of the straight edge. Then measure the width of the inside center of the tub and take half that number. Then use the formula below to calculate it. For example. Height 30 inches, Width 28 inches (half of 28 = 14).
V = (3.1416 x (14 x 14) x 30)/1728
= (3.1416 x 196 x 30)/1728
= 18498.48/1728
= 10.70 cubic feet.
Mar 02, 2015 | Maytag Washing Machines
How do you calculate sec174?
SEC, CSC & COT are the INVERSE of COS, SIN & TAN and are usually require hitting the "2nd F" or "Func" key of the calc to make:
SIN button work as COSEC,
COS button work as SEC
TAN button work as COT
Formulas are below:
sec x = 1
cos x
cosec x = 1
sin x
cot x = 1 = cos x
tan x sin x
Feb 05, 2013 | Sharp EL531 Scientific Calculator
How to calculate the sides of a hexagon?
Well it depends. If the hexagon is irregular (sides are not equal) there is no formula to calculate the sides as they can have arbitrary values. You must measure them.
If the hexagon is regular you may be able to relate the measure of a side to the radius of the circle in which it is inscribed. If you have the radius of the circle, the side is equal to the radius. If you have the value of perimeter you divide that value by 6.
There is also a formula that relates the area of the hexagon to the measure of the side s. The formula is Area=(6/4)(s^2)cot(PI/6), where cot is the cotangent function, its angle is in radian. In degrees Pi/6 is 30 degrees.
Dec 31, 2011 | Office Equipment & Supplies
How do you enter the inverse of cot(-4)
well there is no cot function on this calculator so you have to use the identity. Cot is 1/tan so the inverse cot is 1/inverse tan which is on this calculator so = 1/arctan(-4)
Mar 08, 2011 | Casio FX-270W Calculator
What is 28 times cot 30
Use the relation cot(30) =1/tan(30).
Press [DRG] to set the correct angle unit (degree, radian, or grad). If you are working with degrees the DEG display indicator should appear on screen
You then type
28 [/] ( 30 [TAN] ) =
Aug 27, 2010 | Texas Instruments TI-30XA Calculator
How do i get my casio fx-115 ES to let me use sec csc cot
The calculator doesn't have those functions built-in. Use the relationships sec(x) = 1/cos(x), csc(x) = 1/sin(x), and cot(x) = 1/tan(x).
Aug 22, 2010 | Casio FX-250HC Calculator
How to use the cot function
I don't have a Cot button but Cot x = 1/Tan x so enter
1/Tan 78 = 0.212556 etc if you have a fraction button you can write it that way too:
1 frac button Tan 78 = 0.212556 etc
Jun 16, 2008 | Sharp EL-531VB Calculator
Texas Instruments TI-30XA Calculator Logo
259 people viewed this question
Top Texas Instruments Office Equipment & Supplies Experts
k24674
Stevan Milanovic
Are you a Texas Instruments Office Equipment and Supply Expert? Answer questions, earn points and help others
