I have a Dell Vostro 1310 laptop. Its problem started while I was working on it; suddenly, the backlight began alternating on and off. Nothing worked so I just turned it off. Now when I turn it on, I only get a black screen, I can't get to the BIOS. I checked the video output by using another LCD. I can see the screen when the laptop is connected to another display, but there are many small black lines on the screen. This problem doesn't occur every time, but it's happening much too often.
Mark_Webber
  • 472 Answers
SOURCE: blank screen
Check the fan on your video card if it has one. If it does have one and it's not working correctly then it will overheat very quickly.
This sort of issue can be caused by a million things but your description points to the card overheating or the memory on the video card dying.
Posted on Apr 10, 2008
  • 998 Answers
SOURCE: Laptop won't boot (display problems)
If the diagnostics displays on the LCD screen but you get no display when Windows starts to load, it sounds like you have a video software driver problem. Try tapping the F8 key when you power on your laptop and boot in Safe mode. If it works in safe mode then you need to check you driver. You can also try connecting the laptop to an eternal monitor and see what happens.
Your responses are intended to improve the level of service provided. Please show your appreciation by rating your experience.
Thank You.
Posted on Nov 09, 2008
ginko
  • 19396 Answers
SOURCE: Dell Vostro 1400 LCD Showing Black Screen
If you connected the laptop to an external monitor via VGA and the display, then it is not "an NVIDIA GPU defect" .
The video chipset connected to the LCD screen is the same connected to the external VGA port, and is working fine since picture is OK on monitor.
More likely the problem is either LCD ribbon cable, or LCD display, the fact that the backlight is working means that the inverter is also working.
Posted on Apr 18, 2009
frankzjm
  • 191 Answers
SOURCE: NO VIDEO OUTPUT FROM LCD OR EXTERNAL MONITOR ON TOSHIBA SATELLITE L20 LAPTOP
you may do follow steps
1) eheck memory : reseat all RAM or change other same model RAM
2) take out wireless card at back of laptop MINIPCI. try it
3) still nothing run, your otherboard hardware damaged, need to change the motherboard. the parts please reference here
http://shop.ebay.ca/items/__Toshiba-Satellite-L20-motherboard_W0QQ_kwZToshibaQQ_kwZSatelliteQQ_kwZL20QQ_kwZmotherboardQQ_ckwZlaptop?_trksid=p3286.m104.l1200
hope help you something fixed, please take a rating let me know how much helped you thanks! keep in touch your question
Posted on May 22, 2009
gzuz1010
  • 5 Answers
SOURCE: I am having a problem with my Nvidia Geforce 5500
Maybe it's a temperature related problem.Youll have to clean the Video Card and CPU heat sink (better with compressed air) :
>Disconect the computer.
>open it up
>carefully take the video card out, watch for screws and plastic lock at the AGP/PCI/PCI express slot.
>spray compressed air to clean the heatsink.
>attemp to take the cpu heatsink out too. if not possible just spray the air to the heatsink inside the computer.
>spray every slot and port with the compressed air
>reinstall vid card and CPU heatsink.
>accomodate al the cables to increase airflow
>check everything properly conected
>close everythinkg
Also I would replace the flat IDE cables with round cables to increase airflow.
If that is not helping, maybe its better to monitor your CPU, RAM and vid card temp.
Posted on Jun 29, 2009
Dell vostro 1310 coin cell problem
If the clock won't keep time or the date is wrong, replace the depleted coin cell battery.
Dec 14, 2013 | Dell Vostro 1310 Notebook
Tab key not working
use the software diagnostic coming with DELL, this will indicate you if the keyboard is faulty. or the driver is corrupted. You need to uninstall and install the new driver update.
God bless you
Jun 15, 2013 | Dell Vostro Computers & Internet
Laptop goes blank on startup but still display logon screen
Have you upgraded the OS? At boot start tapping the F-2 key, do not wait for the Dell screen. Take a look at this forum:http://www.computing.net/answers/windows-95/dell-s-bios-startup-screen/85976.html
Nov 22, 2012 | Dell Inspiron Computers & Internet
How to put SD Card in Dell Vostro 1310 PC Notebook SD card reader slot?
You will find the SD card holder to keep the SD card. then keep the sd card holder in the laptop slot.
You need to install the drivers of sd card reader also to work.
Jun 18, 2011 | Dell Vostro 1310 Notebook
The lock sign with a 9, flickers when i start the computer.\r\nCant proceed further. I haver a Dell vostro 1310 laptop computer
There are 3 LED lights that are used for Diagnostics. Here is a link to your laptop's manual: http://support.dell.com/support/edocs/systems/vos1310/en/SM/html/trouble.htm#wp1092170
May 08, 2011 | Dell Vostro 1310 Laptop Computer PC...
How to make internet connection in dell vostro 1310 ? I use USB Internet Broadband
install your usb broadban kit on your laptop, now its reaady to use...
Mar 12, 2010 | Dell Vostro 1310 Notebook
My Dell Vostro 1310 won't turn on. I get a black screen (well actually, a bit of colors are coming, but nothing else ...). Tried again and again to turn on, seems to be a problem with the video card....
check for led lights if they come on.
note down the lights.
If you are able to remove the connection of the lcd to the laptop do so for instruction refer to www.dellsupport.com click on manal
Oct 05, 2009 | Dell Vostro 1310 Laptop Computer PC...
i dont think theres anything wrong with the laptop but who's ever is using it could have done smth wrong
Mar 08, 2009 | Dell Vostro 1500 Notebook
Dell Vostro 1710 display problem
Hello My Dell Vostro Laptop Display Not Working Correctly it showing Dim but in other desktop when i connect to the Laptop Of Mine it showing Correctly With No Dim Problems? How can I fix the Problem?
Nov 19, 2008 | Dell Vostro 1500 Notebook
Computers & Internet Logo
67 people viewed this question
David Payne
David Payne
