Question about HP Vs17 17" LCD Flat Panel Monitor
Hp vs17e silver monitor goes to sleep as soon as it is turned on.. Not connected to computer.
    Problem Solver:
  • 11 Answers
I know this post is old, but for anyone coming from google ill answer it.
Most likely the CrapXon... I mean CapXon capacitors took a dump. Located at 822-824 on the main board. Replace those with some good authentic Rubicon, Nichicon or Panasonic 10V 1000uf caps and this thing should last till the CCFL tubes fail. If you are repairing this yourself, you might want to get a 10uf ceramic cap as well, since the white glue stuff that HP put on these things to keep them intact after a meltdown, might break your 10uf cap's insulation off at location 821.
Posted on Oct 04, 2010
When I start the computer the Windows XP Logos light up on the Monitor (HP w1907) when the computer starts the Logo disappears and the monitor goes to sleep
If this monitor (HP w1907) is going into sleep mode the normally blue power led will change to yellow. This indicates loss of video signal or possible out of range resolution. If the picture goes dark and the power lite stays blue, you have a backlight malfunction. It can be an inverter power fault but this model mostly has worn out backlights causing a shutdown condition.
Monitor Mike
Aug 19, 2010 | HP vs19 (Silver) 19" LCD Monitor
As soon as i turn on my computer the monitor goes into sleep mode
try another cable I have tis problem on mine & I have to do them up solid, also check for bent pins in the cable & bend the back carefully & unplugged.If not you may need to set up the computer to output, try another monitor to rule that out.
Hope this helps!
Sep 22, 2009 | HP Pavilion F1703 17" LCD Monitor
Hp vs17e monitor says it's in sleep mode then goes blank
If you are running Windows Vista,do the following,
  1. Click start,Control panel,
  2. Double click Power options,
  3. On the left menu bar,Click Change when the computer sleeps,Change "turn off the display" to never,
  4. Go down to the botton and select "Change advance power settings,
  5. Scroll down to Display and click the + symbol,
  6. Click the + symbol beside "Turn off display after" change to never,
  7. Click on the next plug + symbol beside Adaptive display and change to off (You may or may not have the adaptive setting)
  8. Click apply ,click ok,
  9. Restart your computer.
If you are running windows Xp
  1. Right click on an open area on the desktop
  2. Click properties
  3. click the screen saver tab
  4. Click the power button at the bottom
  5. Change the "Turn off monitor settings"To Never
  6. Retart computer
if this doesn't fix your problem,please let me know
Please rate this a fixya
Feb 02, 2009 | HP Vs17 17" LCD Flat Panel Monitor
check the board postings for the HP f1903 monitor.I recall seeing a problem of the same there and a solution or fix. As it is only a newer version of the same model, it may be the same fix. Appears HP has a big problem with QA and this particular model. Lots of people have same or similar problems, and all appear to have a similar fix or solution. Tricky part... figuring out how to "Open" the monitor to check it inside!
Good Luck.
PS - if you figure out the opening part, let us all know!
Feb 02, 2009 | HP Pavilion F1703 17" LCD Monitor
My hp w2207h goes to sleep
Turn off the "powersaver" feature on your monitor by pressing <menu> then <management>then <powersaver> select off.
Nov 20, 2008 | HP f2105 21" LCD Monitor
Monitor in sleep mode
my computer is on but screen is black and has power. How can I fix it?
Aug 27, 2008 | HP Vs17 17" LCD Flat Panel Monitor
Goes to sleep
Hi
Pls check the power option settings in control panel.
Also pls check if the power management options for keyboard and mouse in device manager are enabled or not.
Pls try to create a new profile and check if the sleep mode is working in the new profile.
Pls try a System restore if the above steps don't work.
Dec 24, 2007 | HP Vs17 17" LCD Flat Panel Monitor
Going to sleep
(if you have an orange light) Turn off your computer and unplug all of your devices, printer, scanner etc... Only your monitor, mouse, keybord and monitor should be connected. Now turn on your computer. It should work now. You can attach your other devices if you are successful.
Nov 15, 2007 | HP Pavilion F1523 15" LCD Monitor
HP Vs17 17" LCD Flat Panel Monitor Logo
358 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
