We have model SS9K342 portable floor model A.C.window vented. It blows cold when first turned on but blows warm during the night. Also cannot find instructions, sre rhty available on line or by mail?
  • 43,501 Answers
Here is a tip about troubleshooting your air conditioner...
There are many things that can cause your air conditioner not to cool…
Air Conditioner Trouble -Review the Possibilities
http://www.fixya.com/support/r3571569-air_conditioner_trouble_review_the_possi
heatman101
Posted on Aug 23, 2010
2005 Honda Accord Ex (4 Cyl.) - Heater Vent to Floor doesnt seem to work
You need to look under the dash there are plastic pipes going to those vents sounds like they are not properly connected
Jan 06, 2014 | Cars & Trucks
I have a 1999 Caddac DeVille . The AC works fine during the summer but in the winter it won't blow out hot air unless I'm driving. I've let the car run in the morning to warm up but the inside...
your heater core is possibly stopped up if there has been a radiator leak and stop leak has been poured its definetly clogged or could be a faulty thermostat
Jan 07, 2013 | Cars & Trucks
My heater does not blow in floor in a dodgeram 1500
the heater vacuum motor and lines needs to be checked.Also get the blend door checked.
NO HEAT ON FLOOR VENTS
As per your problem mentioned. There are few solved help links to troubleshoot these problems. Go through the list and Click the link below:----
2000 Toyota Avalon: No heat on Passenger Side?
http://whatisbyme.blogspot.in/2012/05/2000-toyota-avalon-no-heat-on-passenger.html
No heat on Oldsmobile Silhouette?
http://technoanswers.blogspot.in/2012/02/no-heat-on-oldsmobile-silhouette.html
Heater blows cold?
http://schematicsdiagram.blogspot.in/2012/02/heater-blows-cold.html
Heat blows cold on drivers side and hot on passenger side?
http://schematicsdiagram.blogspot.com/2011/12/heat-blows-cold-on-drivers-side-and-hot.html
Hot air on the driver's side vents only?
http://repairhelpcenter.blogspot.com/2012/01/hot-air-on-drivers-side-vents-only.html
Temperature gauge does not move and no heat when heater is ON?
http://technoanswers.blogspot.com/2012/01/temperature-gauge-does-not-move-and-no.html
1992 Toyota Camry: A/C Control light Flashing and A/C not Blowing Cold?
http://technoanswers.blogspot.in/2012/04/1992-toyota-camry-ac-control-light.html
No heat, blower blows only cold?
http://technoanswers.blogspot.in/2012/02/no-heatblower-blows-only-cold.html
Ford F150 Ac only blows through defrost vents?
http://technoanswers.blogspot.com/2012/01/forf-f150-ac-only-blows-through-defrost.html
Dodge A/C come out of defrost vents only?
http://technoanswers.blogspot.com/2012/01/dodge-ac-come-out-of-defrost-vents-only.html
Ac vacuum line on dodge cummins?
http://technoanswers.blogspot.com/2012/01/ac-vacuum-line-on-dodge-cummins.html
Ford ranger AC blows cold through defrost vents instead on cabin vents?
http://technoanswers.blogspot.com/2012/01/ford-ranger-ac-blows-cold-through.html
2005 Chrysler PT Cruiser: A/C Blows Warm?
http://whoisbyme.blogspot.in/2012/06/2005-chrysler-p8t-cruiser-ac-blows-warm.html
2009 Mercury Grand Marquis: A/C blows Cold From Defrost Vent Only?
http://whoisbyme.blogspot.in/2012/06/2009-mercury-grand-marquis-ac-blows.html
AC not blowing through Vents on 2007 Chevy Trailblazer?
http://schematicsdiagram.blogspot.in/2012/04/ac-not-blowing-through-vents-on-2007.html
Passenger side temperature is warm air out of dash vents?
http://schematicsdiagram.blogspot.in/2012/04/passenger-side-temperature-is-warm-air.html
These will help.
Thanks.
Nov 28, 2012 | Cars & Trucks
Brand new delonghi PAC C120e, I got everything installed easily with the unit rite next to the window, I have it turned all the way down and it still does not cool my small room at night. It seems to blow...
Since the unit is new and under warranty and hopefully you have registered it with Delonghi. Your best bet, is to contact their Customer Support Rep 800-322-3848. Doing it this way has you totally covered.
Jul 12, 2011 | DeLonghi PAC C120 12000 BTU Portable Air...
I have an Amana side by side refrigerator. Last night I noticed water running from underneath and the ice cream in the freezer melting. I found dog hair clogging a vent and cleaned it. This morning the...
usually when the bottomof the freezer is cold and the top isn't it's the evap fan motor isn't working and all the cold air sits at the bottom.when you open the freezer door you should hear the fan running inside the freezer,also tried to look up your model but it didn't come up.open the fridge door,look up on the right and hear the cieling and you'll see a tag with the model and serial numbers,i just need the model number and i can help you better
Jan 30, 2011 | Amana ARSE66MB Side by Side Refrigerator
01 dodge 2500 v8. Air conditioner started out strong, blowing cold air..temporarily would start blowing warm and then back to ice cold...Noticed when stopping and turning corners a hissing noise coming...
Hi. Have your car aircon evaporator cleaned. Check also the drain hose. All water should go out of the car through the drain hose. There might be something clogging up the hose that is why water will run out the floor and that causes also the aircon to work intermittently.
Have a good one!
Aug 13, 2010 | 2001 Dodge Ram 2500 Truck
A/C blows from defrost and floor vents, nothing from dash vents.
the switch where you turn it to blowing at your head is probably out. you will need to replace the switch control where your defrost, foot, head etc. what make, model, year is your vehicle?
Jul 09, 2009 | 1994 Toyota Camry
1995 Chevy Silverado 4X4 cold air blows through floor vent
none of the above, the vent door is stuck inthe open position most probable cause is vacum leak look closer to your fire wall and you will see a very thin vacum hose going into the vehice which seems to be unpluged!!
Nov 13, 2008 | 1999 Chevrolet Silverado 1500
Heating & Cooling Logo
377 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
