Question about Cycling
How do i reconnect the front brakes after putting the front wheel back on
  • 366 Answers
Do you have v-brakes or disk? If you have v-brakes, just squeeze the brakes together, pull back on the corrugated dust boot and find the slot at the bottom of the curved metal cable tube and slide it into the metal retainer.
Posted on Aug 23, 2010
Can flipping the front wheel cause brake problems
check that a brake pad hasn't fallen out when you put the wheel back on the bike
Jun 24, 2017 | RIM Cycling
How to replace front brake pads on a How to replace front brake pads on a 2000 Chevy S10 4WD pickup?
First you want to remove brake fluid from brake resovoir, raise front wheels off ground and set park brake or block rear wheels. Remove front wheels, keep steering wheel unlocked so you can turn rotors side to side. Loosen bolts that hold caliper end gently pry caliper free from rotor, remove caliper and remove pads, use bungy cord to hang caliper away from rotor, have rotors measured to see if they are thick enough to have machined, replace if out of specs. Match up pads with old ones, use anti- squeak red liquid and put layer on back of pads, let dry. Use tool to put pistons back into calipers, slowly put pistons back into bore while opening up bleeder screw so ABS won't be damaged. After rotors resurfaced, wash with rubbing alchohal to remove any oils from hands, install rotors and reverse putting pads back onto caliper and reinstall, torque caliper bolts to factory specs and tighten bleeder screws. Install wheels, torque lug nuts to factory specs and replace brake fluid in resovoir. Lower car carefully to ground and press brake peddle without pumping it. Any air in system should bleed out, if not get someone to help with bleeding system. Road test to ensure no squeaks or pulling, burn brakes in slowly.
May 10, 2014 | 2007 Saturn Aura XR Sedan
My abs, traction, and brake lights are on after a front brake and bearing job were done
By "were done" I am guessing someone else did the job for you. It is a common error at garages to forget to reconnect the sensors so that is my first thought but then you say you changed the front sensors, was that after the brake job and do you have 4 wheel ABS? The plugs for the sensors should always be cleaned if not replaced after a brake job in my opinion (high dirt area). More info will get you a better answer if you post back I may be able to help more/better.
Mar 26, 2014 | 2011 Ford Focus
My brakes stay stuck and the car wont move
sounds like your emergency brake cables are stuck raise your car one wheel at time starting with the front (block the back wheels for safety) put the car in neutral and see if the front wheels spin by hand if so the e-brake is the problem try rocking the brake handle a few times if that dont do it put the car back down find the cables under the car and try to move them around the cable may release itself doing this
Apr 18, 2012 | 1994 Honda Accord
Wheel Bearing needs repair Front passenger side vibrating, pulling & humming. How difficult is this to do on my own?
You'll need to remove the wheel hub, seperate it from the strut and ball joint. Remove the brake caliper and tie rod end. Most likely you'll need to have the bearing pressed out by a machine shop.
Apr 24, 2010 | 2000 Pontiac Grand Am GT
How do I replace the front brake pads on my 2009 Mazda 6 2 litre? Can I do it myself?
Step 1 Park the Mazda 6 on a flat surface. Put the emergency brake on and put wedges behind the wheels to prevent the vehicle from rolling. Disconnect the negative battery cable. Using a syringe, turkey baster or similar tool, drain two thirds of the brake fluid from the master cylinder. Remove the wheel.
  • Step 2 Remove the bolts attached to the brake pipe. Remove the bolt cap attached to the caliper top. Swing the caliper, pivoting it downwards. Suspend the caliper from the frame using mechanics wire. Remove the M-springs, the pads and the shims.
  • Step 3 Press the caliper pistons back into the cylinders. Install the brake pads. Lubricate the exterior of the pads using anti-squeal. Install the shims. Install the M-Springs. Reinstall the caliper. Using a torque wrench torque the bolt to 36 to 39-ft. lbs. Install the cap.
  • Step 4 Reinstall the wheels. Add brake fluid to the master cylinder. Bleed the brakes. Reconnect the negative battery cable to the battery. Start the engine and pump the brakes 3 to 4 times to seat the brake pads. Test drive the Mazda 6 at slow to moderate speeds to ensure that the maintenance was performed correctly.I hope this helps you and please have a merry xmas
  • Dec 18, 2009 | 2009 Mazda MAZDA6
    Front brake pads need to be changed, how?
    Jack the vehicle u. Support it on jack stands. Remove front wheels. There are two bolts that hold the brake caliper on. Remove those. use a C-clamp to push the caliper piston back in. Install the new pads in the caliper brackets (pop into place). Put caliper back on, then wheel back on. Put vehicle back on the ground. Press brake until firm. Done.
    May 15, 2009 | 2005 Pontiac Montana SV6
    2006 dodge ram 2500 4x4 diesel replace brake pads front and back
    Straight forward job. Remove wheels, remove 2 caliper bolts per wheel, check bolts,and bushings for wear/corrosion and lubricate, remove calipers, remove brake pads, push caliper pistons into calipers, replace anti-rattle clips, put new pads in, put caliper and bolts in, put wheels on. Start truck and press brake pedal several times to take up slack and you're done.
    Apr 25, 2009 | 2004 Dodge Ram 2500
    Cycling Logo
    104 people viewed this question
    Top Cycling Experts
    Michial Gueffroy
    John Egan
    John Egan
    Are you a Cycling Expert? Answer questions, earn points and help others
