Question about Intex Automatic Salt Water System for Above Ground Saltwater Pool
Green water - Intex Automatic Salt Water System for Above Ground Saltwater Pool
  • Intex Master
  • 8,404 Answers
Green water is indicative of copper in the water ... let the CL go down (the lower the better) add a sequestering agent according to package instruction ... then introduce CL again.
Conversely, the filter will eventually take it out.
Thanks for your interest in FixYa.com
Posted on Aug 23, 2010
Water is not getting to the ice maker
As long as water is coming to the dispenser you can try this.
Access the water valve on the back of the unit, remove the green wiring connector from the green valve(green is the im valve). Leave it loose and take the dispenser wire(yellow) from the yellow valve and place it on the green valve body electrical connector. Disconnect the tubing from the green valve and press the dispenser, if water does not come out you have a bad green valve. If water does come out you have a blocked water line possibly frozen. If neither the dispenser or im get water check for 60 to 70 volts at the brown valve and 120vac at the yellow and green. If voltage is present then you should get water from the brown valve when the tubing is removed and the dispenser is depressed. If you get water through the brown valve then you need to disconnect the clear tube on the front of the valve and press the dispenser again, water should come out and if it doesn't change the filter if you haven't and check for a frozen water line. The line from the green valve(which goes to the ice maker) can be checked by simply disconnecting the green tube from the valve and blowing through it.
Oct 31, 2013 | Electrolux FFUS2613LP Side by Side...
The heat exchange on my AQ 125-BNG is green does that mean it was leaking?
Green can indicate a water leak .you would have to check for a leak to be sure
Feb 15, 2018 | Bosch AquaStar Indoor Natural Gas Tankless...
My aquarium water is green, is it ok?
The phenomenon of green aquarium water is caused by unicellular algae. To fix it, you should cut back on the light and use Acural E algae. The best cure for green water is the U.V. sterilizers are the best cure with no down side.
Aug 02, 2012 | Fish
Getting same green film on top of water that is the same color green as the copper piece in the salt water pump has turned
The two green colors may be associated somehow but when you say anything about green water I think it is more likely the water is turning green from algae. The best way to rule this out is to test the chlorine level and then shock with vinyl shock to about 10 ppm. If it is algae then the it may be cloudy but should turn more blue rather than green. If other chemistry is good such as salt concentration and stabilizer then running the pump, filter and chlorinator according to the Intex manual. When a pool is shocked the filter can get dirty quickly and then reduce the flow. For this reason make sure you clean the filter. I hope this helps.
Please vote on this answer. Thank you.
Aug 26, 2011 | Intex Automatic Salt Water System for ...
We just up graded the pump and have the salt water system hooked to it for days now the the water is a light green color It looks clean not algae green Could it be to much salt or not enough? When I test...
Did you have to put more water in than usuall before you noticed the green? If you filled the pool with well water it could be iron in the water (which gives you a clear green look). If thats the problem then next time run the hose into the skimmer or into the filter pump suction. That way the fill water will be filtered before going into the pool. If it is iron in your pool and you shock the pool it will turn brown.
Jun 17, 2010 | Intex Automatic Salt Water System for ...
Changing light after installing new water filter
Water Filter Status Indicator Light
(select models)
The Water Filter Status Indicator Light serves as a
reminder to replace the water filter. A green light
indicates that the filter is in good condition. A red light
indicates the filter should be changed. Once light turns
red, it will remain red until function is reset.
To Reset Indicator:
• Press and hold both the LOCK and WATER
buttons simultaneously for four seconds. The
green filter status indicator light will flash
three times when the function has
successfully reset.
Aug 12, 2009 | Jenn-Air 21.6 cu. ft. Side-By-Side...
Green screen on mobile
dear the water in has damaged its LCD and also its internal IC has dsturbed due to water thats y its turn into green.so plz chek it to mobilr repair shop.
May 28, 2009 | Samsung Cell Phones
Water pipes at back of machine need cleaning. They are green inside.
hello i hope i can help you? may i please ask you when you say the pipes at the back are green is this green pipes or green with not being cleaned? if they are green due to not being cleaned. open the machine up and check where the pipes are connected. remove the pipes and give them a good clean with with a old toothbrush. and you can use a old rag just push this through a couple off times make sure the rag is soaked in warm water.i hope this will help you?
May 07, 2009 | KitchenAid Artisan
Its gone off!
The green light indicates the unit thinks it is out of water. Take of rewervoir; make sure the inlets are not plugged. Open the little plug on side, clean tank w/ clear water only, and shake out all water completely. Put it all back together, but leave reservoir off. Turn on and run unit "dry". Your should hear a "flutter" sound as the unit trys to pump water from missing reservoir, the heater/steamer should be sizzling hot & pressurizing. THEN the green light if ome ON, asking you to switch it off, refill & install the water reservoir. If things don't happen in that sequence, you should be able to determine what is wrong.
Dec 27, 2007 | Rowenta Perfect Iron
Intex Automatic Salt Water System for  Above Ground Saltwater Pool Logo
170 people viewed this question
Top Intex Pool & Spa Experts
avionik99
Level 1 Expert
Jay Finke
Jay Finke
Mike
Are you an Intex Pool and Spa Expert? Answer questions, earn points and help others
