Question about Brother CS-8150 Computerized Sewing Machine
I have brother NS30 ,which start sewing or pushing the fabric rear to front.
  • sqs1011 Aug 23, 2010
    Need a better explanation of what's wrong before I can help you.
5 Suggested Answers
  • 96 Answers
SOURCE: stitching loose. won't thread the fabric
try to rethread the machine all the way back to the spool of thread and check the top and bottom tensions on scrap of same fabric
Posted on Dec 13, 2009
  • 1116 Answers
SOURCE: Sewing on reverse of fabric
There has to be thread on both sides of the cloth in order to form a stitch.
Refer to the maintenance section of your machine and clean the machine as recommended.
Did you change the thread or needle?
Check the manual to be sure the threading is correct and was done with the presser foot up.
Is the needle is correctly installed?
Check the bobbin to be sure the thread is feeding in the correct direction and through the guides on the side of the bobbin case.
Posted on Apr 29, 2010
  • 54 Answers
SOURCE: Suddenly started sewing backwards (fabric feeds
is your machine sitting in button hole.
Posted on Aug 17, 2010
Tally Girl
  • 1133 Answers
SOURCE: My Brother CE55000 sewing machine
Does it sew okay on a single or double layer as this sounds like the threading up is not correct to me. The grinding may be that the bobbin case isn't in correctly.
However, best way to diagnose is to start fresh, take off the thread, remove the bobbin case, clean out the rotary hook (under the needle plate) clean the feed dogs and remove the needle. Clean the tension discs too (turn to zero and floss between the metal discs with selvage edge of a clean piece of cotton scrap fabric, until its clean, no gunk coming out). Turn tension dial back to 4 or 5, your normal setting.
Now wind a fresh bobbin making sure it winds nice and smoothly, keep tension onto the thread spool to achieve this and watch as the thread goes onto the bobbin, give it a nudge so it fills the bobbin smoothly across the whole core, top, middle and bottom.
Now put bobbin into bobbin case and ensure it goes into the tension spring correctly. I can't see an image of your machine to know if it is top loading or front loading bobbin, sorry. But refer to your manual to ensure you get the thread fully into the tension device. With a front loading bobbin, there is a removable bobbin case. Ensure that this is holding the thread with enough tension, if you suspend the bobbin and bobbin case and just hold the thread tail there should be enough tension on the thread that the case just hangs, but if you give it a litle jolt, it should release some thread. Adjust the tension spring with a little screw on it in 1/4 turn increments until you get it to this point.
Try this link for some images and trouble shooting help on bobbin case. http://www.sewusa.com/Sewing_Machine_Repair/Thread_Tension_Settings.htm
If you can't get the tension right on the bobbin case at all, then take it to the Brother shop and buy a replacment one, sometimes the springs do fail on them.
Now put in a new needle and make sure you have used the right size needle for your fabric, ie medium weight woven you need a size 80 universal, but if it is a knit fabric like jersey you need a ballpoint 70 or "stretch 70" if its got a lot of lycra in it.
Now thread up the top thread and pay careful attention to getting the thread into all the thread eyes, particularly the take up lever and make sure it goes into the top tension discs fully (always thread with the pressure foot raised so the tension device is open). Lower the pressure foot and pull the thread just before the needle, it should feel very firm if the top tension is working right. If there is no resistance there, you've got a dodgy tension dial, take it for service/replacment.
Continue threading to the needle, bring bottom thread up to the top by turning the flywheel through one cycle towards you. Now hold both threads together at the back and test stitch a seam.
If you are still getting the noise from it and thread jamming up underside then the fault may be more timing related in which case you'll need to take it to a sewing machine technician too.
Posted on Sep 21, 2011
Does my Brother SQ9185 sew backwards other than the push button backstitch?
Use the reverse button. That's what it is for. Sew forward and then push the button and sew in reverse.
Machine Darning Jeans Shirt
If you have a darning foot, you can use it (drop the feed dogs) and then you manually move the fabric around while stitching.
Learn How To Mend Clothes with Machine Darning
Oct 01, 2016 | Brother Sewing Machines
I need an automatic needle threader for a Brother NS30 Le
Fixya does not sell replacement needle threaders.
Aug 05, 2016 | Brother Sewing Machines
How do i get a manual
Try brothers .com. They should have a manual to download or have sent to you.
Oct 21, 2014 | Brother Sewing Machines
Fabric get stuck in feed. I had to cut fabric then unscrew the plate and remove the fabric. This is Brother 1355
This happens to the best of us now and then, usually at the start of a seam with slippery or thin fabrics. If this is the case try to gently pull the fabric through by the loose threads at the start as you sew. Or start your sewing a bit further in from the edge to get a grip then sew backstitches carefully to fill in the space left.
Nov 03, 2013 | Sewing Machines
My brother started making a loud noise when sewing pant fabrics
Your machine is complaining because it doesn't have the power to push through the layers of fabric. That clunking noise is the gears in the machine skipping and being sheered off (or it will be eventually) STOP!
If you feel that you need to continue... stop when it does this noise and use the HAND WHEEL. You'll also need to make sure that the presser foot remains level while going over thick seams.
Jan 02, 2013 | Brother Sewing Machines
Feed dog is not working.
Think of it as if it as two sets of fingers, behind and in front of where you are making the stitch. The numbers on the indicator should be thought of as X to one. 1 is always the rear hand, and X is the front one. If you go to a lesser number (like 0.5) with your front hand (feed dog) it means that they only feed the fabric one half as far as the rear one, so you are stretching the fabric at the point where it is being sewn. If you go to a larger number (like 2) that should be read as 2 to 1. In other words, your front hand is pushing the fabric twice as far as the rear one is, so it is compressing the fabric where it is being sewn. Wonderful invention!
Jan 22, 2009 | Brother CS-8150 Computerized Sewing...
My xl-5700 the needle keeps breaking or the thread keeps getting all bunched up plus I lost my instruction manual can I gat a new one
About the needle problem, Brother's FAQ gives the following response:
Make sure the needle is correctly inserted with the flat side facing the back and pushed up into the machine as far as possible.
The needle could have been damaged or bent. If so replace with a new one.
Make sure the fabric is not pulled excessively when sewing. Let the feed dogs move the fabric. Do not pull the fabric.
The combination of needle size, thread size and fabric is incorrect.
Be sure to use the correct needle and thread size for the fabric you are sewing.(example: Denim-size 16 needle and 40-50 heavy duty thread).
As for the manual, here's the link:
http://welcome.solutions.brother.com/BSC/public/files/dlf/doch000063/ps21xl55565700ug02en.pdf
Dec 05, 2008 | Brother XL-5700 Mechanical Sewing Machine
Brother CS-8150 Computerized Sewing Machine Logo
144 people viewed this question
Top Brother Sewing Machines Experts
Tally Girl
Tally Girl
Irene Tulloch
Are you a Brother Sewing Machine Expert? Answer questions, earn points and help others
