Question about HP Pavilion Slimline S3020N PC Desktop
When i turn on my computer it will light up but will not come on
  • 75 Answers
1. check your power supply and power source (220v or 240v?) May be you plug it in (110v)- if power supply is in good condition go to #2
2. check your Memory RAM - Clean the contact of RAM using eraser or a fresh dollar bill then test. if RAM is in good condition go to go to #3
"Once installed and configured, memory seldom causes problems. When problems do occur, they may be as obvious as a failed RAM check at boot or as subtle as a few corrupted bits in a datafile. The usual symptom of memory problems is a kernel panic under Linux or a blue-screen crash under Windows. Unfortunately, that occurs so often with Windows that it's of little use as a diagnostic aid. When troubleshooting memory problems, always do the following:
  • Use standard antistatic precautions. Ground yourself before you touch a memory module.
  • Remove and reinstall all memory modules to ensure they are seated properly. While you're doing that, it's a good idea to clean the contacts on the memory module. Some people gently rub the contacts with a pencil eraser. We've done that ourselves, but memory manufacturers recommend against it because of possible damage to the contacts. Also, there is always the risk of a fragment from the eraser finding its way into the memory slot, where it can block one or more contacts. Better practice is to use a fresh dollar bill, which has just the right amount of abrasiveness to clean the contacts without damaging them.
  • Before assuming memory is the problem, check all internal cables to ensure none is faulty or has come loose.
The next steps you should take depend on whether you have made any changes to memory recently.
When You Have Not Added Memory If you suspect memory problems but have not added or reconfigured memory (or been inside the case), it's unlikely that the memory itself is causing the problem. Memory does simply die sometimes, and may be killed by electrical surges, but this is uncommon because the PC power supply itself does a good job of isolating memory and other system components from electrical damage. The most likely problem is a failing power supply. Try one or both of the following:
  • If you have another system, install the suspect memory in it. If it runs there, the problem is almost certainly not the memory, but the power supply.
  • If you have other memory, install it in the problem system. If it works, you can safely assume that the original memory is defective. More likely is that it will also fail, which strongly indicates power supply problems.
If you have neither another system nor additional memory, and if your system has more than one bank of memory installed, use binary elimination to determine which modules are bad. For example, if you have two modules installed (one per bank), simply remove one module to see if that cures the problem. If you have four identical modules installed (one per bank), designate them A, B, C, and D. Install only A and B and restart the system. If no problems occur, A and B are known good and the problem must lie with C and/or D. Remove B and substitute C. If no problems occur, you know that D is bad. If the system fails with A and C, you know that C is bad, but you don't know whether D is bad. Substitute D for C and restart the system to determine if D is good.
If you haven't enough banks to allow binary elimination, the best solution is to remove the modules, wrap them if possible in a static-safe bag (the pink plastic that most components arrive in), and take them to a local computer store that has a memory tester.
MS-DOS, Windows 3.X, and Windows 9X do not stress memory. If you install Windows NT/2000/XP or Linux, memory errors may appear on a PC that seemed stable. People often therefore assume that they did something while installing the new OS to cause the errors, but that is almost never the case. Such errors almost always indicate a real problem with physical memory. The memory was defective all along, but the more forgiving OS simply ignored the problem. "
3. check the processor - is in good condition go to Check your Motherboard..
Clean the CPU Fan. brush the dust.. then test, if failed.. check the processor for burn..
Posted on Aug 24, 2010
How do I reset the computer on 2001 Mitsubishi after replacing the alternator it is a petrol 4 x 4 a 3litre
Not sure what your meaning of why need to reset the computer, the alternator has nothing to do with a check engine light so if that is the issue with check engine light need to scan vehicle find what code is fix that if what to know how to dead boot computer 1.pull + battery cable leave off 2. Get in vehicle turn lights on yes I know there not going to come on we are draining the capacitors in computer 3. Leave light switch on depress brake several times 4. Insert ignition key turn like cranking vehicle couple times. 5. Turn everything off lights key an reinstall + battery cable start vehicle check engine light should be off. Basically that is a dead boot for computer draining all power for it.
Oct 29, 2016 | Mitsubishi Cars & Trucks
Hard drive led light stays on after i turn off computer
have a look at p28 of the set up guide
http://downloads.dell.com/Manuals/Common/inspiron-560_setup%20guide_en-us.pdf
and read this for an idea also
Power LED stays on when computer shuts down
(I searched the internet on "Red led light in front of computer stays on after i turn off computer " to obtain many results, this is just one)
23.February.2015
Apr 29, 2014 | Dell Inspiron 560 PC Desktop
RESET USERNAM AND PASSWORD
Resetting the linksys router in just six easy steps..
1. Turn on the router.
2. Reset the router, wait until the power light is blinking and then press and hold the reset button for 10 second.
3. Turn off the router and turn on again.
4. Wait for the power light to stop blinking, if the power light does not stop blinking, turn the router off, wait approx 30 second , and then turn it on again.
5. Connect the router to your computer, when it is connected to a computer with an ethernet cable, the ethernet port light will light up.
6. Connect the router to your modem, the modem is connected to the internet port is your computer. The router is connected to the modem.
If you are not able to reset the linksys router password then call linksys router support phone number 1-888-494-1155 (Toll-free) USA.
Apr 18, 2014 | Linksys Wireless-G WRT54G Router
Turn off the service engine light
If the Service Engine light is on, you need to scan your Engine Control Module and retrive the fault codes to see why the computer has turned the light on. The fault codes will tell you which one of the many systems monitored by the computer is malfunctioning. Once you have that information, then the faulty system can be diagnosed to find the actual cause of the problem. After the repairs are made, the computer needs to be reset so the light will go off. Restting the computer and turning the light off without properly diagnosing and repairing the cause of the problem will only result in the light coming back on again.
Jan 15, 2011 | 2002 Ford F150 Regular Cab
1985 190e Engine turns over, won't start
when the car ignition is turn on all accessory lights should lite up telling the computer everything is in good contact. If none of the dash lights is not lighting up you don't have a good ignition contact and computer is not getting any power. your stater will crank and turn the engine over only but the fuel pump and ignition module and other accessary is not turn on, the car will not start. What turn everything on is your computer, computer; control all items like fuel pump, sparks etc. You have to get all dash light working again in order for computer to turn on. Check all the fuses and relay under the hood, next your ignition switch in your steering wheel may be faulty allowing only starter to work and not others. this unit wear out and common problems to all cars, parts is 35 buck to replace and you going to have to take the steering columns apart to get to it. Not easy but it will take time. Get all the dash light working and you will be back in the game. good luck and hope that help some
Aug 06, 2009 | 1985 Mercedes-Benz 190
Dell 17" monitor is not turning on.
1. Check the cable with the blue connector. Make sure it's plugged well to the back of the computer.
2. CHeck the light on the CPU's power button. If it's solid green, press the numlock key on the keyboard. Tell me, if the numlock light on the keyboard turned off or on. You can press it again if you didnt catch anything.
3. If there are no lights on the keyboard or the computer when you turn it on, the computer is the problem.
Just post here what lights are present or what happens when you press the numlock key.
Jun 16, 2009 | Dell P793 17" CRT Monitor
The LCD screen doesn't turn on when the computer is turned on
Does the power light stay on? You should see the Hard drive light blinking for quite a while after the computer is turned on if the computer is working and the display isn't. Is there a hot key for your laptop that sets lightness and darkness for the display? You might mess with that. If those don't work then you need a professional.
Jun 01, 2009 | Sony VGN-NR185E/S VAIO NR Series
Hardlocked;beeping and red light on motherboard;will not restart
Something on the motherboard has failed, and the RED light confirms it.
Turn your computer off.
Remove ALL of the RAM. Turn your computer on.
Do all the fan(s) start to spin?
Do you get the _same_ "beeps" as before, or some different pattern of beeps?
If it has more than one stick of RAM (and the RAM is _NOT_ labelled 'DDR2'),
then remove all but one stick of RAM, turn your computer on, and try to reboot.
Same beeps?
Turn your computer off, try a different single (or pair of) sticks of RAM.
Caution: before doing any of the above, your computer could be within the "WARRANTY" period,
i.e., it could be fixed/replaced for free!
May 26, 2009 | Abit GD8 Motherboard
HP Media Center Power Up Problem
replace the power supply-from a computer store, should be no more than 30 dollars
Nov 02, 2008 | HP Media Center m1080n (PC099A#ABA) PC...
HP Pavilion Slimline S3020N  PC Desktop Logo
26 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
