Question about Sport & Outdoor - Others
I have a Pacemaster ProPlus. It is coming up with a Bad Scr error message after the motor runs for a second or so. I believe that this is indicating bad speed control. Any thoughts on repair or replacement?
  • 432 Answers
SOURCE: i have 1991 honda accord, heater blower motor does
If you have removed the blower motor, Connect it to a 12 volt power supply(your battery)with some jumper wires.It should turn fast, be careful when you connect it, have a good grip on it, it will jump just a little. If it dont run fast its junk. The other 2 things
1)The fan switch
2) The resistor that slows the fan at low speeds.
Posted on Jun 27, 2009
Nomodo4u
  • 863 Answers
SOURCE: 'bad disc' error message comes up every time I
Your optical pickup drive lens is dirty or needs to be replaced.  Run a DVD disc cleaning kit through it and see if that helps.  If not, then you have to open this thing up and clean the lens with a bit of rubbing alcohol and then try.  If that don't work you can either kick it to the curb or replace the optical lens.
Posted on Nov 13, 2009
maxtreadmill
  • 832 Answers
SOURCE: Getting a dead sensor reading on pacemaster pro plus treadmill
OPEN MOTOR SHROUD INSPECT THE COMPARTMENT ON THIS INSTANT I BELIEVE THAT THE SENSOR IS AT THE OPPOSITE END OF THE MOTOR THE LEADS GO INTO MOTOR CONTROL BOARD I WOULD FIRST UNPLUG AND PLUG THE CONNECTOR THIS WOULD CLEAN ANY OXIDATION OFF. IF NOT YOU SHOULD BE ABLE TO DO THE REPAIR
Posted on Mar 02, 2010
outfield502
  • 79 Answers
SOURCE: I have a problem with
just change the Diodes D4015L and SCR´s S4015L whit a caugting buy the new change and ready or is a MC-2100 w / transformer just change the MOSFET IRF250N
Posted on Sep 11, 2010
emissionwiz
  • 78267 Answers
SOURCE: Volvo P0717 Input Speed Sensor
The P0700 is not a true fault code, it just means that the powertrain control module has requested the Transmission control module to turn on the check engine light to alert you of a fault. The P0717 is the one you need diagnosed, it is the real problem,.
Posted on Jun 12, 2012
New Magnetic Key
Go to walmart and look in kitchen goods. Look for refrigerator magnets and find small one... It will work... Looks cute too.
Jun 22, 2014 | PaceMaster ProPlus II Treadmill Incline...
I have a Pacemaster Gold treadmill that will not hold elevation. I have no error codes. It will go to the proper elevation and then immediately start descending. If I change the elevation setting it will...
Run the utility software calibration for easy diagnostic, and fix it.
Go to HOOD open the cover motor and follow the steps indicated. or your owner manual.
God bless you
Sep 30, 2013 | PaceMaster Gold Elite Treadmill Upper...
Pacemaster treadmill err 133
I just fixed the same 133 error, it's about the communication between motor module and upper panel. There is an 8 wires cable, uses standard RJ45 connectors. In my case, one of the RJ45 connector to motor module is poorly done by the manufacture, so the connection is not reliable, I re-do the connector, problem fixed.
Apr 15, 2013 | Treadmill Doctor Pacemaster Platinum...
Error message 133
It is an error code that refers to a black cable that attaches to the main circuit board located by the motor. It looks like a fat telephone wire. Unplug it and reinsert at both ends but try the bottom one first as it is easier to get to. If doing this does not work you can meter the pins on the cable to make sure that there is not a problem with it or you can replace it. If the cable is good and you continue to get that error then you will have to replace the power circuit board. I hope this isn't the case because they cost around $450.
Jan 25, 2013 | PaceMaster Premiere EXT Treadmill
Looking for a user manual for a pacemaster proplus treadmill
I have a pdf of the Owners Manual for a PaceMaster Pro-Plus Treadmill. I am attempting to upload it to www.manualsonline.com, so if you still want it, hopefully they will have it soon.
May 08, 2012 | Exercise & Fitness
I have a problem with my MC-2000ES motor control board. The HV BUSS LED is not on and therefore no DC voltage to run the motor.I have checked the diodes and SCR circuit and all look OK. I believe there is...
Aug 31, 2010 | Proform Crosswalk 500 Treadmill
Mar 02, 2010 | Exercise & Fitness
Error message
N~ 1.SCR looks like a truncaked screen saver name (when a name is longer then 8 characters, it comes up with the ~) the .scr is a screen saver extension.
Just as something to try, disable any and all screen savers you have running and see it the error stops.
Please inform after trying this.
Jul 20, 2008 | Acer Aspireā„¢ T180 PC Desktop
Sport & Outdoor - Others Logo
148 people viewed this question
Top Sport & Outdoor - Others Experts
Bill Eager
Are you a Sport and Outdoor - Other Expert? Answer questions, earn points and help others
