Question about Acer TravelMate 292ELMI Notebook
Can't start when the start button is pressed, lights blink for few secs, but the system neither get started nor gives any responds......plz help me out dudes..................
    Guru:
  • 1,342 Answers
Try removing the power adapter and battery. Then hold the power button in for up to 60 seconds to discharge the laptop.
Plug it back in and see if it will boot.
Posted on May 04, 2008
Kid 60 s10 please give fault codes
Hi Roger, Hope this helps......CHEERS..
KENMORE DISHWASHER ERROR CODES
Kenmore Dishwasher Error Code = Start Resume light blinking slow
When the dishwasher door opens or electrical power is removed during the cycle then the dishwasher will not start again. The door is detected as being closed and the Start Resume button is being pressed
Kenmore Dishwasher Error Code = Clean light is blinking 7 times
Heater circuit fail. Control panel did not detect the water getting hot. Did not detect heating element was energized to heat the water during the wash cycle
Kenmore Dishwasher Error Code = Sanitize LED blinking at end of cycle
Control panel could not detect if sanitation has been achieved
Kenmore Dishwasher Error Code = Console light blinking rapidly
There is a stuck button on the control panel
Kenmore Dishwasher Error Code = Clean light is constantly illuminated
Dishwasher cannot start a wash cycle until it sees that the door has been opened after the previous washing cycle
Kenmore Dishwasher Error Code = Control lock LED is ON but not responding to pressing of the keys
Turned on by accident or there is a control detected key pad problem
Mar 31, 2016 | Kenmore Dishwashers
I have problem with remote control, my remote control gives me blue light to switch the dashboard on but there is no lights coming on the dashboard. what is the problem
Hi, your remote has probably lost its coding. If you have the owners manual check page 65 learning additional remotes. If not do the following 1. Plug in the 6 pin hopped coded plug to control unit under drivers seat. 2. Press unlock button twice to disarm. 3. Press learn button on hopped coded plug. this erases all pre learnt codes. The led on dash should start blinking once per sec. 4. Press learn button on hopped coded plug again. The led on dash remains on for 4 sec. and then starts blinking faster. Ensure to do step 5 within 25 sec. 5. Press any button thrice on your remote that has a problem. 6. In response led on dash remains on for 4 sec and then blinks once per sec.This indicates that the remote has been learnt. Hope this helps.
Mar 09, 2015 | 2006 Tata Indica LSi
I can't get the control panel to reset. The wash cycle light comes on but it just beeps and the dishwasher won't start. I press the start button and it stops beeping for a minute but it still...
II might need the actual model number. However, you can go to page 9 on this manual and check if the flashing options can fix the problem. I am assuming you have already tried to turn the power off and back on.
The ohter thing to try is the reset sequence. Within 6-7 secs press High Temp/ Heat Dry/ High Temp/ Heat Dry/ High Temp/ Heat Dry. All lights should light up, press Start button to exit.
Jun 24, 2011 | GE Nautilus 24" Built-in Dishwasher
Green light is blinking over "start & resume"
It sounds like he didn't run it completely through try holding the cancel button down for a few secs.
Mar 22, 2011 | Magic Chef DU6500 Dishwasher
Have a dell inspiron 1545 laptop(2 yr old).i cleaned 2 weeks back with colin cleaner meant for cleaning itafter i did n started it started to beep continuously for few secs and the screen blinked.So i kept...
If you cleaned it when it was powered on and in use there is a chance that you have accidently hit a control function that has enable / disabled an unwanted feature. If not this then the cleaner may have damaged the logic in some way - best bet now would be to call DELL support and give them the support product key on the base of the laptop - a new keyboard is easy to install - look up you tube and you will see a demo.
Mar 21, 2011 | Dell Computers & Internet
The remotes for my system do not operate when I press the lock or unlock or remote start buttons. Is there a way that I can reprogram the two remotes to work with my remote start sytem. It is the python...
The "pair" the remote with your system:
1.PRESS AND HOLD the f button on the remote UNTIL the transmit LED lights solid (approximately 10 seconds)
2.PRESS AND HOLD the remote start button (circle arrow) UNTIL the LED blinks 3 times and the amber transmit LED lights up. Your remote is now ready to pair.
3.. Turn the key to the on position
4.Within 5 seconds PRESS AND RELEASE the control button on the antenna.
5. Within 5 seconds PRESS AND HOLD the control button. The status LED will flash one time and the siren will chirp to confirm that the system is ready for remote pairing.
6. Press lock button on remote. System will respond with chirp toconfirm pairing.
Oct 28, 2010 | 1401 Remote Start/Keyless Entry System
Password to avoid the unauthorized Use
press the exposure light button for 5 sec n after that the indications wiil apear n on the display there will b 2 dashes blinking so u input 10 n press stars after that the no wiil blink 100 so u have to make 101 by pressing start then press c n then input 11 start n when 3 dashes blink input ur code only 3 digit n press start n press the expossure botton n cm out if there is any prblm call me on 9923483607
Jan 31, 2009 | Sharp AR-5320 Black and White Copier
The tv wont turn on
hello 2 blinks on this tv means you have this issue below
PT-44LCX65
2 blinks 5 secs you have your lamp cover open
check for this
hope this helps
Dec 14, 2008 | Panasonic PT-44LCX65 Television
Kenmore front load washer won't start. Lights just blink
I had same problem........push options and select button at same time, hold for 5 sec.......choose option.....machine stuck inbetween cycles.
at least it worked for me!
Dec 26, 2007 | Washing Machines
Blue screen and shut off by self
You will need to reset the Netcommand and tuner settings in the set. The little indented button in the front of the set needs to be pushed in (when the set is off). The front light will blink for about a minute or minute and a half. Then, reprogram the Netcommand settings. This should solve your problem. If you need more information, then, reply to this post and I will respond.
Sep 23, 2007 | Mitsubishi WD-62525 62" Rear Projection...
Acer TravelMate 292ELMI Notebook Logo
Mohammed Ebrahim M
Mohammed Ebrahim M
