Question about Health & Beauty
Hv model no. din 32928-h-0.3-0.6 - need instructions to pump air into mattress.
Pump on my Intex air mattress shuts off before the bed is inflated
Pump is ng and needs replacement. Take it back if under warranty.
May 03, 2017 | Intex Pool & Spa
Instruct on how blow mattress with vacumn
There aren't many vacuum cleaners these days that you can use to blow up a mattress. You need to be able to harness the 'blow', which is the byproduct of the suction. You used to be able to do this with cylinder vacuum cleaners. The air is sucked in one end and blows out of the other. The bag in the middle collects the dirt.
Get a manual foot pump or an electric mattress pump.
Feb 02, 2016 | Furniture
I don't know how to deflate a air mattress with a electric pump. the brand name of the bed is lit-minute
I was looking for the same question and these two links useful
http://www.mademan.com/mm/how-deflate-air-mattress-using-pump.html#vply=0
http://www.ehow.com/how_7480261_deflate-air-bed.html
Hope this helps...
Jack
Feb 22, 2013 | Furniture
What is an air mattress?
An air mattress is a mattress that is blown up using an electric pump, manual pump or with your breath. They are then plugged and support the weight of the sleeper like a balloon.
Feb 20, 2013 | Camping, Backpacking & Hiking
How do I fill up my air mattress?
Most air mattresses come with either an electric or manual pump. You simply attach the pump to the valve on the bed and inflate your mattress.
Jul 31, 2012 | Camping, Backpacking & Hiking
An air mattress is a mattress that is blown up using anelectric pump, manual pump or with your breath. They are then plugged and support the weight of the sleeper like aballoon.
Jul 09, 2012 | Camping, Backpacking & Hiking
I cannot find a manual for a blue magic super pump
See the instructions near the bottom of this web page: (picture at the top of pasted instuctions on th link)
http://www.abcwaterbed.com/pump2.htm
  1. IMPORTANT! - Unplug waterbed heater for safety
  2. Remove cap and seal and put aside in safe place.
  3. Remove any excess air from mattress - slide forearm or broom handle from the head of the bed toward the fill hole to move air pocket
  4. Attach the heavy duty hose to the hose valve coupling, connect to the waterbed mattress and other end to the pump intake side. Be sure to include O-rings. Gently push the coupling deep into the mattress.
  5. Attach garden hose to the discharge side of the pump, this hose goes to a tub, or a deep sink.
  6. Plug in the pump. When it starts it should have a low whirring sound, not a high whiny one. If water is not pumping immediately unplug the motor and check hose connections for tightness, verify there is no air in the mattress.
  7. As the pump removes the water, be sure the hose valve coupling at the mattress is pushed down in the mattress to maintain suction. Heavy phone books or other like items will help maintain proper position deep in the mattress.
  8. Keep pumping the water out and continuing to maintain the hose valve coupling position low in the mattress so it can keep pumping.
  9. Do not leave the pump or the area until finished. A dry pump can burn up.
  10. When the mattress is part way empty, you can place pillows under it at the head to help the water run downhill towards the hose valve coupling.
  11. Continue pumping until water flow stops or pump changes sound. The more water you get out, the easier your mattress will be to handle.
  12. If you are satisfied you have got as much water out as you can, remove the hose valve coupling and quickly replace the mattress seal and screw the cap on.
  13. If the mattress is to be stored for a period of time, pour in a large bottle of waterbed conditioner into the mattress before you cap and seal the mattress.
  14. We recommend rolling up the mattress from the head to the foot and carefully sliding one end into a wardrobe box. Another wardrobe box can be worked over the top of the mattress. Work one box into the other and seal both ends and tape the boxes together in the middle. You can now safely move the mattress.
  15. If you don't get enough water out, the fiber layers can easily slide out of position during moving and you may not be able to get them back into position when you fill the bed.
Nov 18, 2010 | Magic Pool & Spa
I have a Coleman Guest Rest Sleep System and I cannot get the air out of the mattress. I have taken the pump out of the casing and inserted it in the hole for deflating and I can't get it to work.
Is it battery or electricity operated? You might need to replace the battery or hook it up to the right outlet. Follow the instructions in inserting it to the hole. Make sure you press the deflate button and not the inflate button.
If the pump device is really not working, you can temporarily manually deflate the air bed by unhooking the air release nozzle. Press it slightly to allow the mattress to deflate faster. Step on the mattress lightly to force air out a bit.
Source: http://www.bestmattressreviews.com
Aug 11, 2010 | Coleman 10' X 10' Sundome Tent 9160K101
How to use the tire pump tool on the quickpump.
I have the instructions if you send me your e-mail address i will send them to you.
Jul 10, 2009 | Air Tools & Compressors
Health & Beauty Logo
103 people viewed this question
Top Health & Beauty Experts
Robin Hill
Robin Hill
Jeff Tilburn
Jeff Tilburn
Are you a Health and Beauty Expert? Answer questions, earn points and help others
