Question about Sunbeam Grill Series 550
Only 1 half of the element works with both valves on. We bought this bbq off of craigslist. it had never been used. Rock were still in the bag and the grilles have never been used.
    Scholar:
    New Friend:
  • 80 Answers
By "element" you mean the burner? each valve will control one side of the burner but if unused for so long it is Very likely the orifices and valve (small cavity behind orifice when installed) are plugged. Although not common in general this is fairly common in barbecues unused for long. small insects can crawl inside the orifice hole to live in the valve and sometimes packing grease gets hard in the tiny orifice opening.
Posted on Nov 07, 2013
4 Suggested Answers
  • 494 Answers
SOURCE: Bought a used BBQ Galore Turbo BBQ CG4tdbrn
Hello, I wasn't able to find a manual, but I did get the manufacturer's toll free customer service # 1-800-752-3085. See what they can do for you.
Posted on May 21, 2010
  • 54 Answers
SOURCE: do I need to use lava rock with this grill?
http://www.charbroil.com/ProductSupport/463240904/Commercial-Series.aspx Heres the link to the page you need at Char Broil
Posted on May 30, 2010
SOURCE: cadac Carri Chef bbq replacement gas valve.
Remove grey plastic cover by removing two screws inside cooking area, then pop handle off valve, undo nuts to release valve body, carefully remove two screws in body, watch out for spring!
Take the small hexagon jet out of other end, find a small straight item that will pass through hole where jet was, tap the internal part out of the main body , clean everything up, probably carbon on it! Apply a tiny bit of oil to the plug you tapped out, avoid the tiny hole in plug! Now reverse the strip down, making sure that the valve goes back together the right way and still turns through right sequence! Normal cause of it sticking is not pushing it in whilst turning off!
Email me at grundy
Posted on Sep 30, 2011
Are lava rock forBBQs the same as for gas fireplace inserts?
lava rock is lava rock so it should be suitable for either applications
it will have on the bag what it can be used for or talk with a gas fitter or BBQ retailer
Oct 27, 2017 | Grilling
Is there a support for lower oven element a peace of metal/ or it seats on the inside of the oven bottom,on own curve?
It depends on the oven model.
A cheap DIY solution is old BBQ rack, either as is or cut as needed and rest element on it. BBQ racks are built with material which can handle very high temperatures made by oven elements.
Apr 03, 2017 | Ovens
BBQ valve leak
check and see if there is a rubber gasket inside of the piece you screw on to the tank sounds and looks like you are not getting a good seal. if you do not see a rubber gasket inside of that black nob go to lowes or home depot tell them your situation and i bet they have a new attachment piece or a gasket hope this helps
Jul 05, 2013 | Grilling
BBQ was working great last time I used. Next time
yes turn off bbq at inlet valve , open control knobs let out gas pressure or undo line after control tap reconnnect then turn on slow should work
May 30, 2010 | Napoleon Gas Grill
May 21, 2010 | Barbeques Galore Turbo STS 4-Burner with...
No gas getting to bbq
I switched to the new style 20# tank with the new turn-on knob.  I couldn't get enough gas pressure to the BBQ burners for all three burners to light or to keep a strong flame on even one burner.  The new style tanks have a safety valve on the inside of the tank that shuts the gas off if you turn the knob on too fast because the safety valve thinks there is leak.  Shut everything off and then try turning the knob on real slow, especially at first, before turning it all the way on.  If that doesn't work (it didn't for me), then replace the large plastic connection valve knob (female end) that attaches the regulator to the tank.  Mine was for the old style tank and was black (low pressure).  I went to a propane company and had them replace it with a green knob (higher pressure).  Took it home and WALA!  Everything works fine now.  But it was very frustrating trying to figure why I couldn't get any gas to the burners after buying a brand new tank.  I hope this helps solve your problems.
Sep 15, 2008 | BBQ Guys BBQ400C/G42 Grill
Gas BBQ - Won't light
hi Be sure the thermostat or heat dial is set properly. If the appliance has a pilot light, be sure it's working. make sure that you connected the pipeline correctly open the faucet of the tank try to fire it up ? working ? good... NO???? close everything(faucets,plugs...) your new tank that you connected is empty.... it happens.... have a good 1
Apr 06, 2006 | Barbeques Galore Turbo Classic 3-Burner...
Grilling Logo
Top Sunbeam Grilling Experts
Gil Shultz
David White
Steve Pack
Steve Pack
Are you a Sunbeam Grilling Expert? Answer questions, earn points and help others
