Question about D-Link DI-604 4-Port Cable/DSL Router (DI-604) Broadband (di-604 (dont quote)) Bridge
Hi, My d-link dl-604 suddenly stopped working. When I plug it in, only the power led and #4 lights are up. None of the other leds are responding nor the internet is not working as well. Please help. Thanks
    Scholar:
  • 122 Answers
The following reset procedure will completely restore the default settings on your D-LinkHi, My d-link dl-604 suddenly - mag-glass_10x10.gif device including your password. This procedure applies to the DI-514, DI-524, DI-604, DI-614+, DI-624, DI-754, DI-764, DI-774, DI-784, DI-804V, DWL-700AP, DWL-800AP+, DWL-900AP+, DWL-1000AP+, DWL-2000AP, DWL-2100AP, DWL-6000AP, DWL-7000AP, and DWL-7100AP.
Step 1 Locate the reset pinhole on the back of the unit.
Step 2 With the unit powered on, press and hold the Reset button.
Step 3 Hold the Reset button for about 10 seconds.
Step 4 Release the Reset button.
Step 5 The unit will reboot. Allow 20-30 seconds before reconnecting.
Step 6 The device is now at factory defaults.
Note: Do not recycle power during the reset procedure.
The default user name for most D-Link devices is admin and the password is left blank.
Hope this helps! Give me thumbs please!
Posted on Aug 23, 2010
My tp-link wa5210g suddenly stopped. no any led gets on while i connect it to the power lan on poe. it is just off totally.no any configure page is displayed on my computer. no any led becomes on . w
Try plugging in the power supply that is included in the box.
2 4GHz High Power Wireless Outdoor CPE TL WA5210G
If this works and you get LED's on then you have lost your POE power and possibly the connection.
If not, it looks as if your router is faulty.
If it is under guarantee still then return it for a free exchange.
Feb 12, 2015 | TP-LINK Computers & Internet
I have dlink di-604,,the prob.is when i turn it on the led lights from WAN to 1234 continue blinking..i cant able to connect to the internet
This looks like the firmware has failed on the unit as a firmware reset displays 1-4 flashing.
You can try holding the reset in while powered on for 10 sec, failing that it would be cheaper to replace the unit. You can pick up cheap routers from a company called TP-Link which are ok.
Hope this helps!
Jul 10, 2011 | D-Link Express EtherNetwork DI-604 Router
I have a whirlpool quiet partner i dishwasher (model DU1055XTSQ2) that has suddenly stopped working. Control panel has partial functionality. All of the buttons on the control panel have a green LED...
The control board has failed.
CLICK HERE to see the parts breakdown.
CLICK HERE to see/order the part
Open the door & remove the 8 or so allen screws. The board is simply plug and play.
Bad design - the vent is right by the board - so its subjected to moisture.
Thanks!
Nov 14, 2010 | Whirlpool DU1055XTSQ Built-in Dishwasher
DI 604 worked fine last night. This morning it has no power light at all. Do these routers wear out? I have had it for some time.
Yes all the hardwares wears out in somedays.
Please check if the power supply is proper to the equipment or not
Please check the power LED on the box
If nothing is working , please check if the product is still under warrenty then you can get this repaired by the Vendor.
Oct 31, 2010 | D-Link DI-604 - 4-Port Broadband Router [...
Only the printer led is lit
Are there any lights on? If not, then have you checked the power supply, and the wall sockets. Sounds like that may be your problem?
Feb 25, 2010 | Draytek Vigor 2910G Dual WAN secure...
Have 604 router. all of a sudden only two computers can be active through the router and it does not allow the other two to work. things were working fine with all computers getting browser access... now...
On the computers that are not getting Internet access, check the LAN cables to the router. Does the Link LEDs on the router for these computers are ON?
If the LED lights are off then the LAN cable and/or network cards are faulty.
Check Device Manager on these computers to see if the LAN card is working and enabled. If not re-install the LAN drivers. If the driver installation cannot detect the LAN card then most likely the LAN card is faulty and needs replacing.
Get back to me with the results of these tests and I can advise what to do next.
Nov 16, 2009 | D-Link DI-604 4-Port Cable/DSL Router...
Wd-52525 lamp light not resetting
Good Day;
1. Check for an open AC fuse F9D00, if open check for a short on the 340v line to the lamp ballast between pin 1 an 5 at connector PL on the Power PCB, if shorted replace PWB-POWER LAMP (Ballast) part # 939P978010 and F9D00 part # 283D131040 2. Check for open AC fuse F9D00 part # 283D131040, if open check for proper seating of connector K1 on the Power PCB
Dead unit wd52525 mits
NO POWER
1. Red status LED, self-diagnosis error 44, check for open F9A06 on the Power PCB part # 283P128050 on the Power PCB 2. Red lamp LED, self diagnosis error 34. Check for 5-volts DC at J-9 connector pin 1 and 2 on the Engine Driver PCB if missing replace the Power PCB part # 930B921002 3. LED stops blinking after 70 seconds of plug in but will not power on. This model is equipped with a keyboard lock feature, this can be mistaken as a no power condition. To unlock the keyboard press and hold the "menu" button on the front panel for 10 seconds 4. LED stops blinking after 70 seconds of plug in but will not power on. Check for 3.2 volts DC at connector LE pin 3 and 4 on the Control PCB, if low suspect problems with the switches/buttons on the Control PCB part # 935D776001 5. LED stops blinking after 70 seconds of plug in but will not power on. Keyboard is not locked and key inputs at connector LE pin 3 and 4 check good. Suspect the E2P PCB part # 934C121001 6. (LED does not stop blinking after plug in) Disconnect the USB connector from the card reader to the front from the Chassis, if the LED stops blinking after 70 seconds replace the Card Reader part # 299P271010. 7. (LED does not stop blinking after plug in) Disconnecting the USB connector from the Card Reader did not help. Remove connector FC from the FMT PCB and plug the unit in, if the LED stops blinking after 70 seconds with FC removed suspect a problem on the FMT PCB (part # 930B924002), if the LED keeps blinking with connector FC removed suspect a problem on the DM PCB (part # 934C116002). 8. (LED does not stop blinking after plug in) On the DM PCB (part # 934C116002) check C81A2, C81A3, C81B3 and C81B4 (1000 UFD, 16V, 105C), if any are bad, replace all of them with part # 181P734030 (680 uFD, 16V, 105C). See Service Tip VS-78A 9. (LED does not stop blinking after plug in) On the FMT PCB (part # 930B924002) check C8F19, C8F21, C8F22, and C8F27 (16V 1000 UFD 105C), if any are bad, replace all of them with part # 181P734030 (680 uFD, 16V, 105C) See Service Tip VS-78A 1. Red status LED, self-diagnosis error 44, check for open F9A06 on the Power PCB part # 283P128050 on the Power PCB 2. Red lamp LED, self diagnosis error 34. Check for 5-volts DC at J-9 connector pin 1 and 2 on the Engine Driver PCB if missing replace the Power PCB part # 930B921002 3. LED stops blinking after 70 seconds of plug in but will not power on. This model is equipped with a keyboard lock feature, this can be mistaken as a no power condition. To unlock the keyboard press and hold the "menu" button on the front panel for 10 seconds 4. LED stops blinking after 70 seconds of plug in but will not power on. Check for 3.2 volts DC at connector LE pin 3 and 4 on the Control PCB, if low suspect problems with the switches/buttons on the Control PCB part # 935D776001 5. LED stops blinking after 70 seconds of plug in but will not power on. Keyboard is not locked and key inputs at connector LE pin 3 and 4 check good. Suspect the E2P PCB part # 934C121001 6. (LED does not stop blinking after plug in) Disconnect the USB connector from the card reader to the front from the Chassis, if the LED stops blinking after 70 seconds replace the Card Reader part # 299P271010. 7. (LED does not stop blinking after plug in) Disconnecting the USB connector from the Card Reader did not help. Remove connector FC from the FMT PCB and plug the unit in, if the LED stops blinking after 70 seconds with FC removed suspect a problem on the FMT PCB (part # 930B924002), if the LED keeps blinking with connector FC removed suspect a problem on the DM PCB (part # 934C116002). 8. (LED does not stop blinking after plug in) On the DM PCB (part # 934C116002) check C81A2, C81A3, C81B3 and C81B4 (1000 UFD, 16V, 105C), if any are bad, replace all of them with part # 181P734030 (680 uFD, 16V, 105C). See Service Tip VS-78A 9. (LED does not stop blinking after plug in) On the FMT PCB (part # 930B924002) check C8F19, C8F21, C8F22, and C8F27 (16V 1000 UFD 105C), if any are bad, replace all of them with part # 181P734030 (680 uFD, 16V, 105C). Good Luck big IRISH.
Oct 08, 2008 | Mitsubishi WD-52525 52" Rear Projection...
No response from the DI-604 D-Link Router
The cable must be of parrallel type......(not cross)... connecting router and the modem or PC...
Dec 23, 2007 | D-Link DI-604 4-Port Cable/DSL Router...
Open Questions:
See all D-Link DI-604 4-Port Cable/DSL Router (DI-604) Questions
D-Link DI-604 4-Port Cable/DSL Router (DI-604) Broadband (di-604 (dont quote)) Bridge Logo
529 people viewed this question
Top D-Link Computers & Internet Experts
Prashant M
Prashant M
Are you a D-Link Computer and Internet Expert? Answer questions, earn points and help others
