Question about Dometic Rooftop RV Air Conditioner
What color wire is GL or GH for thermostat - Dometic Rooftop RV Air Conditioner
1989 Honda GL 1500 Gold Wing thermostat location
Hi, Joe for this scenario you will need your service manual that has all fastener torque specs and a wiring diagram on the back pages, parts fiche, and owners manual if you can't find the best tool you ever bought for your Honda, despair not, for a mere zero $0 you can download another one.
For more information about your issue and valuable "FREE" downloads that you will need for viewing or printing please click on the blue links below. Good luck and have a wonderful day.
1989 Honda GL 1500 Gold Wing thermostat location Google Search
GL1500 thermostat housing GL1500 Information Questions goldwingdocs com
Honda GL1500 Service Manual
https://www.partsfish.com/page/oem-parts-for-honda
Honda GOLDWING GL1500 Owner Manual
May 16, 2018 | 1989 Honda GL 1500 Gold Wing
Color codes radio wire for 1984 Subaru gl wagon
Get a manual and get all your repairs done without depending on external sources. Here's the link to one of the websites that I use.
You're welcome :)
Complete Subaru Leone DL GL Loyale Omega Series GL 10 RX Isuzu Geminett II...
Nov 22, 2017 | Subaru Cars & Trucks
I am replacing wire that runs to control board to thermostat. New wire has 5 and old was 4
Colors don't necessarily matter. Just make sure what you have at one end is the same at the other. Take a pic or write it down
May 22, 2017 | Heating & Cooling
Why is my picture distorted, could it be a wiring problem?
mostly this for a bad connection or long cable distance you could increase the sickness of wires
Jan 21, 2016 | Aiphone GH-1KD 3.5" clear VIDEO HANDS-FREE...
Furnace wiring
w-brown
y-white
r-red
g-fan
gh-probly fan heat
gc-probly fan cool
or they could be for fan on and fan auto, you can these around a bit just fan control tho
Dec 08, 2013 | Bryant Electrical Supplies
My guiter will communicate with the frontman but it doesn't control the playstation. I have tried every way undere the sun to sink and it seems to sink with the fromtman cause it shows what color i am...
1. You need 3 other controllers besides the Nyko guitar (they can be the rockband instrument set, or just any PS3 controllers. I used a DS3 a RB guitar and GH3 guitar)
2. You need all 3 of the controllers assigned to the PS3 taking up spot 1-3 except the Nyko guitar (goal is to assign the Nyko to 4 or higher)
3. Plug in the Nyko dongle and attempt to link with the guitar (it will most likely make the Nyko button turn red which is the color that won't play)
4. Turn the switch on the dongle back and forth once or twice ending on GH setting letting the guitar link on it's own (It may not assign correctly on the first try, but keep switching between Rockband setting and GH setting. Always end on GH, because it will work with Rockband on GH setting)
5. After a few times it should link and allow you to play
Jan 06, 2011 | Nyko & FrontMan Wireless Guitar Controller...
I have an older Day & Night / Bryant / Carrier downdraft central heater. It was a heat only unit but has an aftermarket AC unit added onto it. I have the latest PCB that adds the AC cooling feature...
4 wire will not work properly.
You will need a 5 wire minimum.
Blue = common
green = blower fan
red = hot
white = furnace
yellow =AC
The wire from the thermostat to the airhandler would be like above.
The wire from the thermostat to the AC (via the airhandler) would be blue and yellow.
Aug 30, 2009 | Heating & Cooling
Why is my car running hot ? The fan wont kick on and we have replaced the high and low sensor
Assuming ALL fuses and connections are good..... test the "CONSTANT CONTROL RELAY MODULE" should be on the radiator support,a black box with wire to it.....test for voltage at the wires colored: R/LG, V, BK/O. pins-3-8-10-11-13.....when engine gets hot the output voltage to the FAN motor is wire color : R/O, pin- 1 &2.....if no output voltage it may be the CCRM.....the other is the PCM....hope this helps you..GL
Jul 08, 2009 | 1998 Ford Mustang
My unit is not being controlled by the themo, it just run
some are listed ac conventional and heat pump
how ever the r goes to red the blue to c for common the white to w for heat and the green to g for fan i guess strait air over electric heat due to no orange that would work the reversing valve on a heap pump hope this helps
May 31, 2009 | Heating & Cooling
RB2 drums not recognied on GH WT
that's because rb2 drums are different than the GH WT ones.
you see, rb2 drums only have 4 colors. (R, Y, B, G) Gh Wt drums have 5 colors (R, Y, B, O, G) plus the Y and O drums are cymbals.
did you buy just the disc or the big box?
Feb 06, 2009 | Nintendo Wii Console
Dometic Rooftop RV Air Conditioner Logo
114 people viewed this question
Top Dometic Heating & Cooling Experts
Bill Long
Tim Whalen
Dan Webster
Dan Webster
Are you a Dometic Heating and Cooling Expert? Answer questions, earn points and help others
