Question about Dell DJ MP3 Player
Dell dj won't connect to computer.....takes me into emergency mode.....flash bios, format drive reboot, etc....waht do I do? was working good, then froze up.....inserted pin to reboot the machine then nothing.
    Problem Solver:
  • 11 Answers
Originally Posted by gb07 from another site
"The solution, was to uninstall Windows media player. The first uninstall only let it roll back to version 9(the original version on my computer; yours may be different.) Then I went into control panel and removed it from my windows media components. Then, I went to the folder c:programfiles/dell/digitaljukeboxdrivers. There is a program in there called drvunins. I started it, and it removed all drivers for my dell dj. I then made sure the dj was unplugged. Restarted the computer, then I then downloaded the latest dell firmware, v. 2.20.07.
Found here-
http://support.dell.com/support/downloads/download.aspx?c=us&cs=19&l=en&s=dhs&releaseid=R107735&SystemID=PDA_MP3_DJ_2&servicetag=&os=WW1&osl=en&deviceid=9420&devlib=0&typecnt=0&vercnt=3&catid=-1&impid=-1&formatcnt=0&libid=31&typeid=-1&dateid=-1&formatid=-1&source=-1&fileid=139674
FINALLY, after all that, it did in fact connect, and load the firmware successfully."
I can confirm this does work mine is now working perfectly!!
Posted on Jul 15, 2011
Failed BIOS update
Download the latest BIOS update from your computer manufacturer's website onto a USB flash drive. Refer to your user manual to obtain the manufacturer's website address.
If the downloaded BIOS file is a zip archive, unzip the contents onto your USB flash drive.
Jumper settings may need to be reconfigured on some motherboards to enter BIOS recovery mode. Most Intel-based motherboards have a jumper setting or switch near the on-board
CMOS battery.
The procedure for setting the jumpers will vary depending on your motherboard make and model, so refer to the motherboard documentation for specific instructions.
Power on the computer and press "F2" to access the Setup Mode menu.
If you are unable to access the setup menu, you will not be able to proceed with this repair. Take your computer to a repair shop, as the motherboard may need to be replaced.
Use the arrow key to select "Boot Priority" or a similarly named field. Press the "Enter" key.
Scroll down until "First boot priority" or "First boot drive" is selected and press "Enter."
Select the USB flash drive as the first boot priority device. Press the "F10" key to save this setting and exit from the setup menu.
Connect the USB flash drive to an open USB port on your computer.
Then let your computer fully reboot.
The USB flash drive should be detected and the BIOS should update automatically.
When the update is complete, you may be prompted to restart your computer, or it may reboot automatically.
If you are able to use your computer without any further problems of overheating or failure to recognize drives, your failed BIOS update has been resolved.
hope this helps
Sep 11, 2012 | ASUS (P5RC-LA) Motherboard
Why won't my dell laptop cannot read the primary internal harddrive?
First - re-seat the harddisk and reboot the computer. If the computer does not boot up then reboot andgo into the BIOS configuration to see if the BIOS detects the hard drive. If itdoesn't detect the hard drive then it could be faulty.
Then the hard drive needsto be replaced in the computer/laptop, Windows installed and the computer orlaptop's device drivers plus your programs etc. to get a functioningcomputer/laptop again.
May 08, 2012 | Dell Inspiron 1545 i15-143P Jet Black PC...
Will only boot in safe mode won't connect to lan or wireless, locks up after a few mins, ran everything I can to repair..can't access dvd drive to do a complete format any suggestions?
You may need to pull the hard drive and connect to another computer as a external device to format the hardware, but if you can access bios, reset to factory defaults before pulling the hard drive and try again.
Mar 07, 2012 | Dell Inspiron 1545 15.6-Inch Laptop...
I can not get past the blue screen unmountable_ boot_ volume even in safe mode.
You Dell Latitude cannot detect the hard disk.
First - re-seat the harddisk and reboot the computer. If the computer does not boot up then reboot andgo into the BIOS configuration to see if the BIOS detects the hard drive. If itdoesn't detect the hard drive then it could be faulty.Then the hard drive needsto be replaced in the computer/laptop, Windows installed and the computer orlaptop's device drivers plus your programs etc. to get a functioningcomputer/laptop again.
Feb 16, 2012 | Dell Latitude D505 Notebook
Acer Aspire One BIOS hard drive password?
BIOS passwords are set individually for each computer, so even though two of them might be the same model or from the same company, they won't have the same password.
Generally, BIOS's don't have passwords, and they shouldn't have a password by default. If someone has set up the BIOS with a password, there is no way to recover the password other than remembering it.
If you can't remember the BIOS password, you'll have to have the BIOS flashed, which is like re-installing an operating system for the BIOS. I would suggest taking it in to a computer repair shop and asking them what they can do.
May 10, 2011 | Acer Aspire One D250 (99802378332) Netbook
Cant enter bios menu
The AA1 has a built-in BIOS recovery routine, which makes it possible to flash the The AA1 has a built-in BIOS recovery routine, which makes it possible to flash the BIOS even if the system doesn't boot anymore. It's only meant for emergencies, that's why it's also known as crisis disk mode. Use at your own risk.
First format an USB flash drive with FAT.
Download the latest BIOS, extract all files from the zip file, put both FLASHIT.EXE and the BIOS file with FD suffix in the root directory of the drive. The files must not be in a folder. Rename the BIOS file toZG5IA32.FD, that's important.
Turn the AA1 off, with the USB drive still connected, and make sure both battery and AC adapter are also connected.
Press Fn+Esc, keep it pressed and press the power button. Release Fn+Esc after a few seconds, the power button will be blinking. Press the power button once. The AA1 will now initiate the BIOS flash, do not interrupt it under any circumstances. After a while the power button will stop blinking, and the AA1 will reboot shortly after. Wait patiently.
The BIOS has been flashed and all settings reset to default.
If it doesn't reboot by itself, but the power button still blinks, wait a few minutes before turning it off, and try again. BIOSeven if the system doesn't boot anymore. It's only meant for emergencies, that's why it's also known as crisis disk mode. Use at your own risk.
if that doesn't work the link below sells help http://www.badflash.com/
Mar 13, 2010 | Computers & Internet
Firmware error
Try going into rescue mode by pressing the Play button while inserting the end of a thin object such as a straightened paper clip into the reset at the same time, then hold the Play button until your Dell Pocket DJ turns on.
Scroll to "clean up" and select. This just defragments your players hard drive, you won't lose any data.
If that doesn't fix it try replacing the firmware. Download the most current firmware from Dell's support website. Scroll to and select "reload firmware" in rescue mode. Connect to pc with usb cable and power on player. Double click the firmware file on your pc and let it do it's thing. This won't affect your saved data either.
If neither of those work you may need to reformat the players hard drive. This will wipe out anything you had on the player. Scroll to and select "format all" while in rescue mode. Select "yes" then just watch the progress bar. Good luck!
Feb 17, 2010 | Dell DJ MP3 Player
I cant get vista to recognize my 20gb pocket dj
Windows, eg xp and vista will sometimes acknoledge something is plugged in, but doesnt end up supporting the device until drivers are installed and working correctly.
First plug it in, and verify the symbol for attached hardware comes up on the lower right corner of your screen. If it does not, then there maybe something wrong with the computer plugin, chord, or the dj. try a different chord first, you are looking to just plug it in and have the system acknolege it is something plugged in.
If you are able to get the symbol, then check for conflicts and installation of the driver. Go to run, right click on my computer and click on properties. Look for the hardware tab, advanced and there is a list of your hardware and drivers supporting them. If you see any yellow exclaimation marks or other symbols it indicates a problem with the driver. Most times is is a conflict between your driver and other drivers. But it could also just be the wrong driver. You can delete the the driver with the exlaimation point, reboot and hope for the best, otherwise you can use my method.
My Method
Reboot, and hit the key or whatever gives you access to the bios. Once there find the menu item relating to pnp/pci, or pnp operating systems. Activate the function so that it will reset resources and cause the bios to reconfigure allocating resources after the next reboot.
Reboot, after the computer has been turned off completely, and push the f8 key repeatedly, you will come to a boot menu, asking what mode you want to boot up in go with safe mode. Once its booted and the screen looks strange, simply exit and rebook again.
What we have done is attempt to solve a drivers conflict by resetting and reallocating the bios hardware allocation. The operating system takes cues from the bios, and allocates memory and resources based upon that.
This is a good technique anytime you change your hardware configuration. It helps lessen the fragmented memory amonst other things.
If you find none of this has worked you need to try some other decvie in the same usb port. If it is plugged in and operates correctly, you have narrowed it down to the dj unit. Since the chord has tested good, we should go to the unit itself. Four tiny screws located on the outside of the case need to be removed in order to open it. Carefully remove the hard drive, then the battery.
Now with the cable hooked up to the usb port you will use a meter to check some voltages. Perhaps you have a friend who can help. The batteries should read 3.6 VDC. Measured like that its not a true indication of the state of the batteries, but tell us that the charging circuit is probably working okay.
Put it back together carefully, making sure every connection is properly seated and there is no damage. Try it again, making sure you hold down the button for 3-4 seconds. If you have done all of this, the problem is electronic and at a component level. Suggest you take it or send it to the repair shop dell has.
Ted
Dec 18, 2008 | Dell Pocket DJ MP3 Player
Hard Drive not found after installing software.
  1. Boot to the bios with the HDD connected
  2. Turn on all the lock lights on keyboard (SCROLL< CAPS<NUM)
  3. Press ALT+E (Wait for Beep)
  4. Press ALT+F (Wait for Beep)
  5. Press ALT+B to reboot
  6. IDE redetect should initialize on boot.
  7. HDDs should now be seen
Sep 29, 2008 | Computers & Internet
Firmware Problem
I had this problem as well and found help. I tried the suggestions below and the problem was fixed! What you can try is this: Open up Control Panel Click on Performance and Maintenance Click on System Click on Hardware tab Click on Device Manager button If you see a Yellow Exclamation mark beside something that looks like the DJ then double click on that. If you see something that says to Update the driver then do so. If it asks to checked Windows Update, choose this option!! If this fails then delete it from your computer by pressing the Del key then clicking OK. Restart the computer, connect your DJ and see if it works properly. If not, open up Device Manager again. This time remove ALL your USB ports, everything under Universal Serial Bus controllers. Restart your computer, let it reinstall your USB devices, connect your DJ with its done, hope it works... If not, open up Add/Remove Programs Click on Show Updates box in the top middle if your running Service Pack 2 Scroll all the way down until you see Windows Media Player 10. If more than one WMP 10 item is showing then remove those first. After your PC restarts remove WMP10. If removed successfully then your computer will now have WMP9 installed. Open up WMP9, click on Help, click on Check for Player Upgrade. WMP10 should be displayed. Let it update... After your computer restarts, install the Windows Media Format 9.5 Runtime from this sticky Restart your computer, connect your DJ and hope it works....... Or you can just take it to another computer running Windows XP and WMP10 and if it recognizes correctly then put back a v1 firmware, I recommend 1.02.01. Download it from this FAQ Hope this helps you as much as it helped me.
Jan 22, 2007 | Dell Pocket DJ MP3 Player
Dell DJ MP3 Player Logo
Top Dell Audio Players & Recorders Experts
Greg Cann
Greg Cann
Jax Planet
Jax Planet
Are you a Dell Audio Player and Recorder Expert? Answer questions, earn points and help others
