I have a 561c central air unit. I just replaced the fan motor and capacitor 6 days ago. The unit ran great for just that long now the fan won't come on and the outside unit is hot to the touch, I can assist the fan and it starts and runs great until it reaches the thermostat temp. When it turns off it won't come back on. Is it the start relay switch?
  • dmle22 Aug 24, 2010
    Turns out it was a defective fan motor. I replaced the contact relay and that wasn't it either. Finally broke down and called someone to test it.. ( a woman trying to fix her own unit)
  • 674 Answers
Sounds like you need another capacitor since it will run if you turn it by hand to get it started. If you have a clamp on ammeter check the current draw on the fan motor.
Posted on Aug 23, 2010
  • 1 more comment
  • dmle22 Aug 23, 2010
    Could the cap be wired wrong?
  • Brian Niten Aug 24, 2010
    If you had the capacitor connected to the run winding instead of the start winding the fan would run backwards.
  • Brian Niten Aug 25, 2010
    Glad to hear you got it.
I have an older amana central ac/heating unit, fan not turning outside, did pencil test, turns slowly then stops. changed capacitor a month or so ago all was fine. started making a humming noise so ran and...
Sounds like the fan motor has reached its endpoint. It will have to be removed and replaced. Find the dircuit breaker in your electric panel that supplies power to the air conditioner unit. When you have found the right one, even the humming sounds will be absent. The fan usually is at the top of the unit. You must have opened this to change the capacitor. Remove the fan band motor as a unit and take it to a store like Grangers and determine if they have a motor that would replace the one from your unit. If the motor has a model number on it, you may find a replacement available onlilne by Googling that number and the name Amana. Put electricians tape over the wires that led to the motor, just in case someone turns on the circuit breaker before you have completed the job
Oct 04, 2013 | Goodman CLQ36AR49 Air Conditioner
Central air problem
Try spinning the blower motor. If it does not spin freely then the motor is bad. The capacitor being bad will cause this to happen. If the capacitor was not the right microfarad that will also cause the motor to go bad. Also you can just put you nose to the blower motor and try to smell if it smells burnt
Apr 27, 2013 | Heating & Cooling
Condenser fan replaced one year ago, fan not turning but can hear motor
the answer to your problem is most likely the motor start capacitor. A AC motor can run in both directions. The start capacitor is used to cause the current to lag behined the voltage which determines the direction the motor will turn. Its posible the start and run capacitors are in one can. so changing one will change the other. However look for a wiring diagram. Do not asume that both capacitors are wired in properly. They may be fighting one another causeing premature failure.
Sep 18, 2012 | Carrier 38CKC036 Air Conditioner
Central air conditoner outside unit
Well, the answer is yes. I have seen a bad capacitor cause a fan motor to run backwards. BUT..... After replacing the capacitor and WIRING it up the right way, everything should be fine. A lot of aftermarket condenser fan motors are reversible, so it can run counter-clockwise (CCW) or clock-wise (CW). However, most factory fan motors come one directional and on your specific unit, the air should always push out of the top. Running the unit with the fan going backwards will actually some-what do it's job, but damage other components like the compressor because it runs at higher operating pressures than what it is designed for.
Have someone else look at it! That's going to be the best advice I can give you. If they can prove that a capacitor caused the motor to permanently run backwards..... I want to know! Hope this helps and good luck with your unit.
Jun 22, 2012 | Heating & Cooling
I have a Bryant Model 593C central air - 6 years old - the fan on the outside unit won't run. I checked the breaker and it is fine.
Hello, this could be either a bad capacitor or bad fan motor. If the fan starts by giving it a push then replace the capacitor, if it does not start the motor needs to be replaced.
Jul 07, 2011 | Bryant Heating & Cooling
I have a all in one or complete unit the fan motr
hopefully you replaced motor with the same Rpm HP Volts and made sure the rotation of fan was correct.. Might have a bad/defective motor I would take it back to whomever you purchased it from as the should exchange it. Good Luck
Jul 21, 2010 | Heating & Cooling
My air conditioner fan is not working
Check the outside fan and make sure it rotates freely. If it doesn't spin freely it needs to be replaced. If it does spin freely then check the capacitor. If the capactitor is OK the check the fan motor windings for continuity with an ohmmeter. Let me know what you find.
Jul 18, 2010 | Heating & Cooling
The condenser fan motor has stopped working for the 3rd time. This unit is only 10yrs old.We have already replaced it twice.
Is it the motor or capacitor? If the capacitor is bad the motor won;t run, it will just hum or run real slow.
If it is the motor and it's the 3rd one then you need to go to a more heavy duty motor, for instance if it's a 1/4 horse power then go to a 1/3 hp. etc.
May 31, 2010 | Ruud Central System Air Conditioner
Fan will not start. Has been making noise but now will not move unless I push the blades, but feels stiff. Can it be repaired or must it be replaced?
Depending on the age of the unit/Fan there may or may not be oil ports, at the end of the motor, (Little plastic pull out's) Would use mechanical oil 3n1 ect.
Also The capasitor usually goes bad over time, which can be purchased at a local Hvac supplier usually less then $20.
If the Motor will not turn freely, several turns with just hand spining then more then likely you need to replaice the motor. Let us know how it goes. Can follow up with additional simple test for you if you need.
Oct 24, 2009 | Heating & Cooling
Heating & Cooling Logo
96 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Donni Steen
