Question about Nokia N70 Cellular Phone
I forgot my lock code i tried my old lock code but i wont open, so i turn it off. after a few minutes i opened it again i enter my lock code again but still it wont open, what do u think should i do???
  • majesy May 07, 2008
    give me unlock\remove security codes
    President:
  • 1,017 Answers
SIM pin code:
This is a pin code that locks the sim card until you enter the correct code. This protects your account, even
if your sim is put into another handset. To reset it, you need the PUK code:
Pin Unlock Code (PUK)
If you miss key (or forget) your SIM pin code, and enter the wrong one 3-5 times in a row, the SIM will lock up, and you’ll need to enter the PUK unlock code to release it. You should ask your Network Service Provider for this code when you need it. Don’t try to guess it, because after a few wrong guesses, the SIM card will be permanently disabled.
"One day, I'm going to procrastinate..."
Posted on May 07, 2008
RE-SETTING THE CODE
You need a key to unscrew and remove the lock cylinder on the inside of lock. Enter the old combination. Look inside the hole where the lock cylinder was and turn the metal part in there to the right. Then turn the knob or lever to clear the old combination.
Enter your new combination and turn the knob or lever to insure it works. Try it again to be sure, then replace the change plug. Always test combo with the door open.
Apr 22, 2014 | Ilco Kaba 101126d41 Lock Combination
Lock code forgot
You will need to insert a mastercode. There are several tools for this but you always need the IMEI code for the mobile.
Try the website Security master-code calculator for Nokia mobiles. Haven't tried it myself but was referenced to me by a friend.
May 15, 2013 | Nokia C5-00 5MP Unlocked QuadBand GPS...
I set a code in the master lock speed dial 1500id, and it will not open. I cannot reset the code and do not know how to get this open. I have read the other suggestions and nothing has worked yet. Anyone...
Try 2 options:
1. just squeeze the shackle twice and pull it out. This is in case you forgot to enter new combination.
2, Make the 2 combination together, the old and the new as one sequence. This in case you forgot to squeeze the shackle before enter new combination
Ity
Sep 06, 2011 | Office Equipment & Supplies
Remove security code with out restoriing phone to factory settings
Try this:
I refused to do that hard reset trash and erase all of my information. This method is also just in case you don't have anyone to call you or you're too impatient to wait:
This is inspired by the many posts that tell you to frequently press home while someone's calling.
1. I hit the emergency call button then repeatedly hit home (pic of the house) while opening and closing the phone and went to the home page. It worked repeatedly.
2. Then I went in and took off the pattern request in settings.
3. In settings, make sure Google sync is checked.
4. I changed my password on the computer in Google (with same account).
5. Wait some time 5-10 minutes or less (make sure you have internet service where you're located on your phone).
6. Then it will tell you to enter your password. Enter your new password.
7. Close your phone or hit the red power key.
8. The same locked screen will prompt you for your username and password again. Enter the new password and it will log you in.
9. It will tell you to put in your old pattern or put in a new pattern (I forgot? sorry).
10. Then, you can go into settings and security once you unlock and remove the pattern. You have to enter the old pattern to remove the security.
Try this too:
******This will work and you wont lose any data!!****** Get someone to call you. After answering, flip the screen open and shut repeatedly, tapping the "home" button every few flips. Eventually you'll drop through to your home screen. This may take a few tries.
Go into your security settings and disable the unlock pattern. You can now bypass the lockout just by opening the keyboard. Change the password on your account, which may be your Google Apps account if you have one. In a few moments, your phone will fail to sync with email and prompt you for a password. Enter the new password. You can now log in with the new password. Lock your screen, press menu to try unlocking it, and enter your new information. This should unlock your phone.
src: http://www.google.com/support/forum/p/Google%20Mobile/thread?tid=02b67be6b56ae6e3&hl=en
Apr 14, 2011 | HTC G1
Forgetten unlock code
Hi
hi here is the simpliest application that s attaching through this post just transfer the file and install in phone memory and open the application and the application show the unlock code which you forgoted but be patient it take 10 to 20 minute to get code.
Application Link click here
or
Enter the code: *#7370# and press Yes to confirm initialization.
Important Notice: It is recommended that you save all important information on your phone (e.g: memo, contacts etc)
Note
To make a Hard Reset on a Nokia phone that is not willing to turn on, just press simultaneously these 3 buttons:
on/off + * + 3
Before making a Hard reset better backup all your important information: contacts , memo...etc
Sep 07, 2009 | Nokia N70 Cellular Phone
My security code and i want to unlock it
Enter the lock code instead of the security code. After then to change the security code.
  1. Go to menu and there open settings.
  2. There open security settings.
  3. There will options such as change lock code or change security code etc.
  4. If you have forgot security code then you can't change it, better change lock code as your desired password.
  5. To change first get into change lock code and enter old lock code and after that input new password and its all done.
Aug 14, 2009 | Lands Phones
ELectrolux frontloader EWF1090 door wont open
Make sure you drain the machine first by setting a spin cycle manually and see if it releases the door after a few minutes. If that fails then switch off the machine and leave for 5 mins, door should release but you could end up with water on the floor. After this clean your filter and check you water pump, then try a short cycle without clothes.
Apr 11, 2009 | Electrolux Washing Machines
How to unlocke my phone?
sometimes if u insert wrong code three or more times ur phone will be locked for 15-20 minutes.... dont enter any code for that time......after 20 -25 minutes try to remeber ....what code u inserted and try it again and again....i also unlocked my phone.....like that by inserting all that codes i inserted.....if it doesnt work go the care centre of the mobile company and they will surely open it....
Mar 18, 2009 | Nokia 3110 Cellular Phone
Recorvery mobile lock code
download nokia unlocker from google search........
May 06, 2008 | Nokia N70 Cellular Phone
Nokia N70 Cellular Phone Logo
162 people viewed this question
Top Nokia Cell Phones Experts
Computer Repairing
Computer Repairing
