Question about Mitsubishi WD-52525 52" Rear Projection HDTV
No picture on any device/input
See attached picture. I dont think its a lamp issue. Can anyone help?
  • kerot May 04, 2008
    you can't see it well in the picture - but its alternating green and gray boxes all over the screen,
  • cvmed Aug 04, 2008
    I recently replaced the lamp of Mitsubishi WD-52525. It worked well for several weeks. And, one day, it suddenly failed to display any picture from the input device, including DVD, Wii, VCR.... The TV with signals from the antenna did not function normally either. There was also a fuzzy, greenish band flashing horizontally in the middle of the screen.
    Could anyone suggest a solution? Thank you.
    Michael
  • Mitsubishi Master
  • 8,617 Answers
The FMT board has 3 bad 1000uf capacitors that need replacing. Let me know if you need more info on the TV.
Posted on May 04, 2008
We have a sony grand wega KDF-E42A10. The picture is clear but we are not getting any input of red color. I'm sure it is out of warrenty.
I'm sorry that the TV is not displaying red color. Please follow the troubleshooting steps and check the operation:
  1. Please make sure that the connections are secure and proper.
  2. Try connecting a different video source like DVD player or VCR and check the operation. If it works with another device, the issue might be with the input device currently.
  3. Also try connecting the device to a different port in the TV if no other devices are available.
  4. If the issue persists, try with a different cable.
  5. Perform a power resetting and check the operation. To perform the power resetting, unplug the TV from wall outlet for more than 2 minutes and then reconnect it.
  6. If the issue persists, please change the Lamp of the TV to resolve the issue. XL2400 is the replacement Lamp for the TV. Please refer page # 86 of the Instruction Manual of the TV to get the instructions to change the Lamp. I'm providing the link to download the Instruction Manual for your reference. Click here to download the Manual.
Thanks for understanding. Please let me know if you require any clarifications.
Nov 24, 2011 | Sony Grand WEGA KF60XBR800 60" Rear...
I have a HD50LPW175 tv with sound but no picture can anyone help
Do you see any display on tv screen like Menu etc?
Does tv give no picture in all inputs like tv/ cable, dvd input?
How old is this tv and when did you replaced its lamp last time?
Thanks.
Aug 26, 2010 | RCA HD50LPW175 50" HDTV
TV will turn off then turn back on by itself the input shows up at the top when it comes back on. The start up sound does not play when the picture restores. Has happened when watching TV (HDMI) and play...
The first thing to do is disconnect ANYthing that is connected via HDMI and then use the component, composite or s-video inputs and see what happens. If it works ok then most likely what ever is connected to your TV via HDMI is causing the issue (it does happen). The second thing if that doesn't solve the issue is replace the lamp if its getting really dar and has never been done before. If the emmisions of the lamp are low (darker picture) the set thinks the lamp is not on and will force a restart..Please take a moment to rate my answer...Thanks
May 18, 2010 | Samsung HLP5067W Television
My Mitsubishi 65 inch DLP will not turn on. I tried to turn it on last night and the tv seemed to power up but no picture was present. I tried to reset, and the same thing happened. I pressed the Menu...
looked up owners manual that was a waste of time, hmm the number one issue on this type of set is issues with the lamp. How old is it? Has it ever been replaced? Sometimes a visual inspection of lamp can fool you, but typically as they age a milky haze develops on the lamps glass or if it popped the lamp will be shatttered inside. Can't hurt to check it. make sure set is unplugged first just to be safe.
Apr 30, 2009 | Mitsubishi WD-65732 65" Projection HDTV
Unable to receive input device signal
Can you post a picture of the screen so I can properly diagnose it. It sounds like the caps on the FMT PWB but a picture would help me be certain.
Aug 04, 2008 | Mitsubishi WD-52525 52" Rear Projection...
Picture is green.
I also have this problem, anyone get a fix yet?
May 19, 2008 | Samsung HL-R6167W 61" HDTV
Status Light Flashes Red
first did you getthe lamp from miths and if notyou could have bought a bad lamp. you need to get a lamp form mits if you did not buy from them. if you did buy from mits have them replace the lamp it has a 90 day warranty. try hitting the menu and device / input buttons for 5 sec and repost the blink code. it is a 2 digits blink code. (ex. 23 or 33 or 26 like that)
Apr 20, 2008 | Mitsubishi WD-62525 62" Rear Projection...
Permanent Coloured tint
When the image turns pink, we find that replacing the cable between the projector and the lap top fixes the problem.
Sep 10, 2007 | Sanyo PLC-XU47 Multimedia Projector
Location of MIrrors in projection tv
wd-52525 This is a DLP, I dont suggest taking it apart to clean anything, this is what we call a MICRO display, the imaging device is about 1" square and blown up 50X to the size of the pix you watch, anytime anyone I know has taken stuff appart where the mirror is at has ended up worse off, you say that there is dust on the mirror, what does it look like in your picture? If the spots are quarter size or so and fuzzy edges the dust is inside the lightengine and you want a factory cleanroom to service the LE, the one thing I think you can safely do is pull the lamp and check for dust on it as it can cause issues in pix, other than that I dunno what to tell you, hope this info helps.
Jul 09, 2007 | Mitsubishi WD-52525 52" Rear Projection...
Mitsubishi WD-52525 52" Rear Projection HDTV Logo
59 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
