Question about Hitachi Computers & Internet
Hitachi XL500 Install CD is missing? Need to do a reinstall on new hard drive. How do I go abouth with a reinstall?
TampaNative
  • 778 Answers
SOURCE: hitachi-lg cd-rw gce-8487b device driver corrupted or missing error code 39
You may find your driver here: http://us.lgservice.com/ or here: http://www.kauaikeepsakes.com/computerguy/
Good luck
Posted on Mar 22, 2008
  • 119 Answers
SOURCE: Dell Dimension 5000
you problem is most likely that your bios is out of date. download the latest bios updates for your motherboard and then when you install windows format you HDD with the ntfs system (using the long formatt system not the quick format). Then you should install the bios update. then your mboard shoud no longer have the problem of recognising your large capacity HDD. thanks
Posted on May 19, 2008
Pyrhyc
  • 2028 Answers
SOURCE: New Hard Drive, system recovery problem
The systems disc is for the drivers and utilities, and, yes, there should have been two discs with the machine. The A45 is new enough that it should have come with an XP disc, not 98. I believe there was a mix up and you have the wrong disc. If you can get the operating system to load with the recovery disc you have, then you can get the drivers at the link below. Some two disc sets will not load an operational system unless you have both discs. Since you were running XP before, I don't think you're going to be happy with 98. I'm going to suggest that you purchase an XP disc, or contact Toshiba, and let them know that the wrong disc came with the machine, they might send you the right disc. If you do have to purchase an XP disc, simply load the system, then go to the link bellow and download the drivers. If you need any further assistance, feel free to ask.
Posted on Aug 14, 2008
  • 157 Answers
SOURCE: new hdd with bootmgr missing while trying to install os
Are you sure you are booting from the CD? Does the CD light go on when you reboot? Watch the information on the screen when you reboot, you may have to press the F12 key to get to a boot device list and then select the CD Drive.
If this solves your problem, please take the time to leave feedback.
Posted on Feb 21, 2010
cirocpatel
  • 524 Answers
SOURCE: I need to install a new hard drive .. how do I do
  1. urn the laptop over. Position your laptop in the direction so that the Toshiba label, on the bottom of the hard panel, is facing you. Your Toshiba label is positioned correctly if it is positioned on the upper-left side of the external hard panel. Remove the battery pack from the bottom your Toshiba laptop to be sure it is powered off.
  2. Step 2 Remove your laptop's external hard panel. This panel is the external plastic layer on the back of your computer to cover and protect your computer's most important hardware components. The screws you need to remove are located on the four outermost corners of the bottom of your laptop. Follow the chart guide listed in Tips for screw and screw driver compatibility and removal. Distance your screws from your workstation to avoid mixing them up and/or losing them.
  3. Step 3 Locate your hard drive panel drawer door when you have totally removed the external hard panel. It is located where the smaller door in the bottom-right panel was before your removed the external hard panel. Your hard drive will be locked into this specific drawer door and the computer itself. Completely unlock the hard drive and remove the drawer from your laptop.
  4. Step 4 Remove the entire hard drive from the drawer door. Hold the hard drive on all sides to ensure that you do not drop it. Place the removed hard drive in an enclosure area to avoid damage of any kind.
Place the new hard drive in and put it back up.
Please let me know if you have any further questions or concerns.
Thanks.
Posted on May 04, 2010
I have an asus netpad for daughter but its missing ntldr file and keeps repeating cntrl- alt-del and wont go to boot up squence? i was originally trying to put larger hdd inside but same model though .is...
When you install a new hard drive into any computer, the operating system needs to be installed because new drives typically come blank. So when it says Ntldr is missing that is the computer bios telling you that there is no operating system for it to boot, or if there is one on the drive it is damaged beyond repair and must be reinstalled. So get your Windows install disk and boot from the cd (usually will automatically when disk is in the drive) and reinstall the OS. If there is no optical (CD) drive, then you'll have to make a USB boot drive on a flash drive with the install CD on another computer and use it to boot from and install the OS.
Aug 06, 2014 | Computers & Internet
I have a new H HD directly from box. Had problem with the windows install. Re-format, delete all files from new sata HHD. Use disk from toshibu, restore back to out of the box state. Now, missing...
make sure there are no disks in cd floppy usb drives
Test all leads that attach to your hard drive including electrical extensions IDE,SATA
the leads from your ((MOTHERBOARD TO YOUR HARD DRIVE)) make sure they have a secure connection and are not faulty or just replace them they could be faulty
make sure all leads that are attached to your drives dvd\cd 3 1/2 inch floppy have secure connections and are not faulty even the electic extensions or just replace them they could be faulty a computer needs its connections to continue its cycle and to have an end so any faulty leads will end up with a computer error
also make sure you have set it boot from you hard drive in BIOS
hope this helps
Jun 19, 2011 | Hitachi (0S00157) 500 GB SATA II Hard...
A required cd dvd drive device driver is missing
i think you need a new windows cd that has no errors, your cd might have some files missing
Dec 08, 2009 | Sony VAIO VGN-NR220E/S Notebook PC
Error message NTLDR missing on formatted hard drive
You need to either reinstall windows, or take the hard drive out, hook it up as a spare drive to a working computer and copy NTDLR to the root of the laptop hard drive. It would be much easier to reinstall windows. You can always use the recovery portion of Windows, but if I were you I would just do a format and reinstall. NTDLR is just a startup file for Windows XP, that does not mean your hard drive is gone or anything. Please don't forget to rate!..Thanks
Jul 14, 2009 | Compaq Evo D500 PC Desktop
Hard Disk Drive not detected
when installing a new hard drive, there is nothing for the bios to read to run the operating system
go to the bios , boot section and change the boot sequence to boot from cd first
then restart the computer and reinstall the operating system disc in that cd when the computer is up and running change the bios back to hdd as first boot selection
May 07, 2017 | Sprint Hitachi P300 Cellular Phone
Dell Dimension 5000 - Installing extra Hitachi 500GB SATA Hard Drive
you need to turn it on in the Bios so the computer sees the drive, then format it.
Jan 20, 2008 | Hitachi ( 0A30229-20pk) 400 GB Hard Drive
Hard drive
Some hard drives will only work as a single device when jumper-ed as "stand-alone", try finding this option or alternatively, remove the jump altogether and try again.
Oct 23, 2007 | Hitachi Ultrastar 15K147 500 GB ATA-100...
Computers & Internet Logo
450 people viewed this question
Top Hitachi Computers & Internet Experts
AJMAL KHAN
Are you a Hitachi Computer and Internet Expert? Answer questions, earn points and help others
