Question about GE Spacemaker JVM1640SJ Microwave Oven
I have #jvm1870sfc02 ge microwave .120v , 60hz , 1.5kw , 950w serial#mg900231s. i am looking for magnetron (om75p(10)). 46nc069177 i don't know what's this number. magnetron has this number. where can i get this magnetron?
  • 95 Answers
SOURCE: ge spacemaker microwave jvm/1650
Mmmm it's so easy,
First disconect the power, take the cover off, moslitly there would be 5 screws and two tab's on the top.
inside on the right hand side the magnetron it's a sylver box measuring about 4 in x 4 in x 5 in. It will have a plasic cover moslitly that would have to be remove first then on the magnetron there is 4 crews and one connector.
It should fall downard after.
If you have a power supply after the secondary , that may also be your problem.
Regards
Bob
Posted on Jan 22, 2008
  • 10865 Answers
SOURCE: I need to find an incancent 40w 120v bulb for microwave
This is a common item. Take the bulb to a home depot and they will match it for you or direct you to a local source.
please mark my answer as a fixya!
Posted on Mar 10, 2009
Rob2008Owen
  • 11 Answers
SOURCE: Hi I have a GE JVM1533WD 002 spacemaker microwave
It was the upper thermostat. I switched with a identical one below to get results, Magnetron seems to be burnt out as well.
Posted on Sep 12, 2009
beltronic205
  • 1461 Answers
SOURCE: GE Spacemaker Microwave is not heating, replaced
Check thermal fuse cut out gone..
Posted on Apr 06, 2010
localwonder
  • 6784 Answers
SOURCE: the GE microwave still runs,
HI. Your symptoms are a strong indication of Magnetron failure. This is the principal heating device, that is used to produce microwaves that , essentially, excite the water molecules in the food, thus, producing the heating effect. When this device fails, generally, the unit will run, but not heat. This device is very fragile, and can injure you if you are not qualified to handle this type of component. There is a High Voltage Capacitor, that is used to help provide the necessary current for optimal Magnetron operation. This capacitor must be discharged correctly. If not, you could risk serious injury, during the repair, if it is accidental touched.
The Magnetron is linked to a cut-off fuse. If the magnetron becomes unstable, this fuse will shut the device down. It is standard procedure to have this fuse test for continuity. If the fuse has blown, this will be the culprit. Replace the fuse. Now, if the fuse continues to show continuity, this will confirm that the Magnetron has failed. I would advise to inspect the Capacitor, and HV diode for visible burn marks, or swollen top(Cap).
Access can be ac hived to these parts by removing the outside cabinet screws. Once the screws are removed, the cover can be removed, as well. Once the cover is removed, the internal components will be exposed for testing, and visual inspections.
WARNING: IF YOU ARE NOT A QUALIFIED SERVICE TECH, THIS WILL NOT BE A NOVICE DO IT YOURSELF JOB. MICROWAVES ARE VERY DANGEROUS, AND CAN CAUSE SERIOUS INJURY. I RECOMMEND TO CALL FOR SERVICE, IF YOU ARE UNCOMFORTABLE WITH HANDLING THE CAPACITOR, OR MAGNETRON.
Posted on Aug 31, 2010
I have a GE profile oven/microwave combo appliance. Microwave is 1.4 cuft and needs megatron and transformer. Will those parts for any ge 1.4 cuft microwave work in my microwave?
GE profile is a series, not a model. Look inside the microwave and you will see a sticker with the model number on it. Take that number and look it up online you will find many options for the part for your unit. Why do you need both? typically with GE it is usually the mag and maybe the rectifier. If a transformer goes bad it typically burns up and smells horrible. I mostly find bad mags on GE, the ones they use are not very good. OM75P = junk
Aug 12, 2017 | GE Microwave Ovens
GE JES1290SK microwave magnetron is arcing
I don't know about a recall, but if your unit is under warranty parts and labour are included in most cases.
Sep 03, 2012 | GE Microwave Ovens
My oster 1000 watts microwave is not getting hot
There is a semiconductor device called a triac, if food is warm the microwave is not running at full power because the triac is defective.
Apr 09, 2012 | Microwave Ovens
Heats up barely 2 oz water lukewarm in 60 seconds. JE1140/JES 1142 microwave. HV Diode appears open. Should it look open one way and conduct the other as a normal silicon diode on a meter ? Magnetron...
Probably bad magnetron, GE uses the worse mags OM75P is Junk. They go out frequently. And they charge a LOT for them. Find a place called Global MicroParts. They are in Texas. www.allapplianceparts.com They may sell wholesale only, Im not sure. But their parts work great and last.
Aug 18, 2017 | GE JE1140 Microwave Oven
I need a magnetron OM75P (21) to fix Oven,plus a copy of manual
Check this link to find the magnetron. The manual should be search by microwave model number.
Let me know if you need further assistance.
Apr 03, 2010 | Microwave Ovens
I am planning to replace my 240 volt microwave oven with an 120 volt. Can I use a converter?
You might be able to use a 120v to 240v inverter, but may still get problems as the inverter doesn't alter the mains frequency. In the UK and Europe, our 240v / 200v are supplied at a nominal 50Hz. Most 120v systems use 60Hz.
For many devices this doesn't matter, but a microwave oven uses an internal inverter to boost the incoming voltage to the much higher one needed to operate the cavity magnetron: the bit which makes the microwaves. Although it actually runs on dc power, the ac to dc conversion does not produce a smooth dc output,. Since the magnetron relies on an oscillation process to produce microwaves, the wrong oscillation can result in weak or no microwave power, or it can cause the element to overheat and fail.
In simple terms, it will work or it won't. If it doesn't it may blow the most expensive single internal component which usually renders the microwave economically unrepairable. If it does, it may underperform or gradually stress the magnetron causing premature failure. Considering the cost of a suitable inverter and the risks to the oven, it makes more sense just to buy an oven of the correct voltage to start with. New ones cost peanuts these days and used ones are often offered free on FreeCycle or Freegle, usually just needing a good clean before being re-used.
Mar 12, 2010 | GE Advantium SCA2000B Microwave Oven
What's the difference between the following
The power is just the same. The initial letter subscript
could signify the mounting position of the magnetron.
Oct 05, 2009 | Smeg S43KIT3750EB Microwave Oven
Microwave does not heat
It looks like the magnetron failed on your microwave.
This something that you may be able to do it yourself, just need to keep some good safety measures when it comes to the high voltage capacitor.
This may be the magnetron for your appliance: http://cgi.ebay.com/OM75P-GE-Samsung-Microwave-Magnetron-Tube-WB27X10017_W0QQitemZ170195128083QQihZ007QQcategoryZ150140QQcmdZViewItem
Good Luck.
Feb 20, 2008 | GE Spacemaker JVM1640SJ Microwave Oven
GE Profile JE1660GB01 magnetron failure?
It pass the resistance tests and still be bad, and I suspect it is.
I would also suggest that you check the high voltage diode to be sure it's not shorted.
If the filament voltage and high voltage are both present at the magnetron terminals, and not loaded down, but there is no heat, then it's the magnetron.
As a pro with over 20 years of expereince, I have always measured the high votlage, but I will never recommend it to a non-professional. Without the right equipment and procedure, you and your equipment can be "fried". No kidding.
Here are some good links to safety & troubleshooting:
http://www.gallawa.com/microtech/cap_test.html
http://www.gallawa.com/microtech/diode.html
http://www.gallawa.com/microtech/mag_test.html
http://www.gallawa.com/microtech/xformer.html
We're happy to help and we appreciate your thoughtful rating of our answer.
Dec 17, 2007 | GE JE1660 Microwave Oven
GE Spacemaker JVM1640SJ Microwave Oven Logo
93 people viewed this question
Top GE Microwave Ovens Experts
D. E. Hev
 Larry
Larry
Shekar Avadhani
Are you a GE Microwave Oven Expert? Answer questions, earn points and help others
