Question about Panasonic PT-50LC13 50" Rear Projection HDTV
Don't have the remote
I am experiencing the same issue where the bulb meter is expired but the bulb has been replaced recently. Unfortunately, the remote doesn't work and I tried doing the meter reset with my Universal remote with no luck. Any suggestions?
Thanks!
  • 19 Answers
Hate to say this, but special buttons on the remote are needed for service functions that a universal remote would not have.
There are plenty of places on the internet to buy an original remote.
Posted on Jul 29, 2008
Sears garage door opener wall switch works properly (I do NOT have to hold button in to close door), remotes don't work. Sensors are solid green and door reverses when beam is broken when activate
If you recently changed the light bulb in the unit, try changing it back to a basic clear bulb. I just had the same problem, and after research, found that changing bulb to a new type LED bulb messed up the remotes. A good test, is to try the remotes when the garage door light is "OFF". My remotes worked as long as the light was "OFF". I changed the bulb back to basic bulb, and everything works fine!!
Mar 22, 2013 | Sears Craftsman LiftMaster Chamberlain...
I replaced the bulb in my Sony TV . when it powers on there is a warning that the bulb is about to expire
With the model number either Google "lamp timer reset" or call Sony; note that the lamp timer reset should be in the owner manual and is done with the Sony remote control.
Apr 16, 2012 | Sony Televison & Video
I have a 2005 Chevrolet TrailBlazer 4.2 with only 60,000 KM, always maintained at the dealer's. Recently I noticed that the Engine idle is fluctuating where it was always stable at 600rpm. I took it to...
I am a gm dealership tech, and I'm not saying that is for sure your problem as I don't have your vehicle to diagnose myself, but last week I replaced the cylinder head and valves on a 2005 with the same engine, I have done many in the past also.. many fail under warranty, but some don't.. it is a design flaw in the valve seats, and should be covered for the life of the vehicle.. unfortunately, if I were you, and able, I would trade it in for a newer model as this problem has been fixed, or a different vehicle all together..but just my advice, and opinion... sorry for the bad news..
Jun 22, 2011 | Chevrolet TrailBlazer Cars & Trucks
I have a pioneer usx-405 reciever for a PDf407. It used to work just fine but recently whenever I power it on in keeps flashing "muting". I looked it up online and a forum said I need a remote...
You mean Vsx 405, right? Model numbers are senseless enough without typos.
Are you saying you DON'T have a remote? How did you ever set it up? There are several CU-VSX105 remotes available on eBay, one at $9.99 and expiring in a few minutes (17:12 PDT). If you get this in time you could snipe it at the last 10 seconds.
http://cgi.ebay.com/Pioneer-CU-VSX105-Remote-Control-Receiver-/170642335146?pt=LH_DefaultDomain_0&hash=item27bb1365aa
Many a Pioneer receiver will come up MUTING if it powered down Muting. It's not clear if you have been experiencing unwanted shut-downs. Unwanted Muting or any other command could well originate with an unintended remote control source. Mask the receiver so it can't see other I/R sources.
May 21, 2011 | Pioneer VSX-405 Receiver
I looking at a 2000 Protege but only one head light works. both bulbs light when tested seperately. Does this mean electrical problems with the car or is it something simple?
Yes it could be an electrical issue with a electrical wiring, or it could just be a bad headlamp assembly. get a multi meter and test for voltage and the light bulb connector and at the headlamp connector (black on metal frame and red at connection) if you don't know which is positive just test both at least one lead will show 12.-14volts. (make sure your lights are on) If you dont get power at the headlamp connector its a electrical harness issue and stay away. if you loose power at the bulb connector its just a bad headlamp. a multi meter is an electrical testing tool that you can get at any hardware store.
May 03, 2011 | 2000 Mazda Protege
After just recently replacing the bulb I am
Here is proceudre to reset lamp timer in your TV..
While pressing the VOL Down button on the projection display, hold down the PIP or SPLIT button on the remote control at same time for more than 5 seconds.
When reset procedure is complete, the screen message ' lamp time was reset to 0' will appear.
Hope this info will help you.
Thanks.
Nov 18, 2009 | Panasonic TY-LA1000 Projector Lamp for...
NEC MT850
As there were no indicator lights lit I focused on the AC. The projectors work as they should in another location and as such I am fairly certain the problem is associated with the AC power in the particular room. I haven't isolated the exact condition as yet.
Thanks
May 20, 2008 | NEC MT850, MT1050, MT1055, MT1056...
I have recently (31/03/08) purchased a renewal for my Norton anti virus package which expires in approx 20 days time. My order number is 4159998515. The problem started because AOL is unable to handle...
apparently , you are experiencing subscription issues.
if you have already installed your norton on your pc but having a hard time activating it, you can try uninstalling and re-installing it.
howerver, since that may seem to be NOT the only issue here...
please call customer support ...
Telephone:
800.721.3934 or 541.335.7023 Business Hours:
7AM-6PM EST (m-f) Language:
English this is for free. free call, free service, free remote desktop access...
Apr 03, 2008 | Symantec Norton AntiVirus 2004 - (Open...
Panasonic PT-50LC13 50" Rear Projection HDTV Logo
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
