Question about Panasonic Microwave Ovens
Alfoil was put in microwave, now when used one if the small side panels inside glows bright red and starts to smoke. Can this be repaired????
  • Panasonic Master
  • 43,501 Answers
Here is a tip that will help you to figure out what is wrong with your Microwave Oven....
Microwave Oven Basic Troubleshooting Tips
http://www.fixya.com/support/r5508031-microwave_oven_basic_troubleshooting
heatman101
Posted on Aug 23, 2010
H 5040 BM has sparking/flashing coming from grill connection inside top of oven whilst microwave is in use causing this connector to glow red
take it in for repair as the connection is shorting out from the micro waves
get a quote as most repairs are more than the replacement cost
Mar 22, 2016 | Miele Microwave Ovens
Small metal-like plate against wall smokes when I try to use the microwave. Bought it last year. Afraid it will cause a fire so I don't use it. Pregnant with twins..need my microwave.
Shelley,
That is actually a mica plate and that can be replaced. I would suggest trying to find an appliance repair store near you and give them your make and model number of your microwave and they can probably order the part for you. Worst case scenario would be that you might have to order a piece larger than you need and you would have to trace out your old one onto the new one and cut it out yourself. It is not hard to do. What happens, is food grease gets splattered around during cooking, and it can get built up behind that plate and it will start to smoke after a while. You could try removing the plate and cleaning both sides real well, and if it has not charred the plate on either side, you might be able to get by with putting it back in. Hope this helps!
May 19, 2015 | Microwave Ovens
Miccrowave shorting out and smoking
According to the Maytag repair site, no. They list no microwave recalls at all.
If I can be of further assistance, or if you have questions about any of my response(s), please let me know before rating me.
If this solves the issue, please rate it accordingly. My goal is to earn a "FixYa" rating from everyone I help.
Thanks for using Fixya.com,
Jon
Apr 04, 2009 | Maytag MMV5000 Microwave Oven
Sharp R-510 FK dangerous noise
Hello. To me, it sounds like something is stuck to the inside of your cavity and it is arcing, as you are seeing a bright flash, and hearing it. I would take apart/clean everything inside the cooking area, something is causing a problem in there. Usually just a good cleaning is all it needs, as the debris is making a focus point for the energy. Try putting a small glass of water, only 1/4 full, and watch while you start it, to see where the arcing is, it won't hurt anything for a second or 10.
Hope that helped, and thank you.
Mar 29, 2009 | Sharp R-510HW Microwave Oven
GE JVM 1650 Microwave Night Light does not work
We see (and repair) this a lot. The problem is on the control panel, which we regularly repair nationwide by mail for $39.95 postpaid in about a week.
This light failure often occurs when a bulb goes out and the filament shorts, or when the bulbs are removed or installed without first unplugging the oven from the power line. Either can cause such a failure on the controller.
Sometimes this will also affect the exhaust fan operation, too. The lights and fan can be inoperable or stuck on too.
In your case, it may just be a shorted dimming diode, a black diode usually located between the light relay and the connector.
(Not to be mistaken for the tinier red-bodied diode on the other side of the relay that protects the relay coil).
If it is shorted, you will have bright lights in both the bright and dim settings.
In case you or someone you know has the tools and experience to desolder and solder small components, the replacement rectifier diode is not critical and can be any of these:
1N4001, 1N4002, 1N4003, 1N4004, 1N4005, 1N4006, 1N4007, NTE116, or NTE125 some of which are available form Radio Shack.
At our Web site, you can get details of our service, plus we have a video available showing how to remove a typical over the range control panel assembly in under 5 minutes.
There should be a "mini-manual" (tech sheet) hidden inside the unit behind the control panel or hidden on the left side behind the grille, which is very helpful when troubleshooting, testing, and locating components.
Feel free to contact me directly (and please remind me of your full model number) for more information & help.
William E. Miller
prototech@usa.net
http://www.microwavedisplay.com
Feb 13, 2009 | GE JVM1650 1000 Watts Microwave Oven
Smoke Coming from inside of Microwave even when warming for 10 seconds
Proberly wave guide cover at side it can get grease behind it,And when you used it with small load it tried to cook it and then burned the mica cover,Take mica cover off and try it without it to seeif problem resolved if ok,New cover can be obtained if req.Regards grandadfixer
Oct 10, 2008 | Thermador MBBS Microwave Oven
Microwave (inside on right hand side wall) has a plastic cover. Behind this cover while popping popcorn there was bright yellow/red flashing/light, it started to melted the plastic cover within seconds....
You don't say which make/model microwave you have, but on every model I have ever seen the thing that sits behind the plastic cover is the magnetron - the bit that actually generates the microwaves.
Unless the microwave was a fairly top-end model, you might well be cheaper to just buy a new one.
Hope this helps,
Matt
Mar 27, 2008 | Microwave Ovens
Fire in Microwave Using Sensor Control for Potato
Please contact your home insurance to have the problem logged as a failure of the microwave. The insurance company will most likely help you with the smoke damage to the house and will contact the manufacturer to get their money back... there might be an issue with the manufacturing of these appliances.
Jan 04, 2008 | Amana ACO1860 Microwave Oven
Microwave Ovens Logo
56 people viewed this question
Top Panasonic Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
Are you a Panasonic Microwave Oven Expert? Answer questions, earn points and help others
