Question about HP PSC 2110 Color Printer
Scanner initialization error -scanner does not stop moving to right. eventually stops but will not function.
    Guru:
  • 731 Answers
Error messages might appear during scanning. Click here to see the document which was developed to help HP customers resolve these error messages.
Regards
Riztech
Posted on Aug 23, 2010
Scanner error 14
the problem with scanner assembly
Mar 20, 2013 | HP LaserJet M1120 MFP All-In-One Printer
A1E error code. We have a fi - 5900c scanner and its throwing a A1E error code. it will not initialize correctly. I sounds like the motor that moves the exit try will not stop moving up and down. we took...
I think you mean E1A which is the code of Death for a Fujitsu 5900C
It normally means get your big fat wallet out and buy a big fat large PCB for £1000's of pounds . But there is a Cheaper fix by miles .
Jun 11, 2012 | Fujitsu fi-5900C Pass-Through Scanner
After turning on computer, reoccuring grinding sound till eventually stops, printer denotes 'scanner failure' and prompts power off then on again!
Whats going on from the sound of it is something stopping moving the scanner up and down OR your scanner cant find its referance point. These dont normally bust a gear but do get dusty
You need to look at the scanner and see what it is doing on power up, is it trying to move as if threw the edge of the machine? (no white reference) so keeps trying and thats the noise the scanner movin a mm then another trying to find home but failing.. usally due to dirty mirrors or blown lamp..
Either way I'd watch a few times,... y0u know the lamp under the lid that moves up and down;0..
Yuor HP should turn on lamp and shine it in the inside edge of the machines copy glass near after power up
You can manual move it with power off to the other end and then after removing your hand plug it in and turn it on and see what the scanner does, I bet it moves fine untill it get near home then starts dancin untill it gives up throwin your error (aka dirty mirrors, just use clean lint free soft somethin, no chemicals just good clean of mirrors. or somethings stopping the carriage movin.
Let us know how you go.. Cheers
The Fix... if Im guessing right that is..... is to remove the Torx screws that HP use (need a a torx driver) that hold on the glass, it needs to come out so you can clean the scanner mirrors reflector and lamp (DANGER 240v live UNPLUG;) and ensure the systemt runs well up and down the scan rail, i think you have to fight to remove the plastic cover from the operations panel too,and on some the Doc feeder has to come off, but on yours I think its the op panel to go so you can get to a screw or something.
Dec 23, 2011 | HP OfficeJet 6110 All-In-One InkJet...
Printer m1522n ,the scanner does not stop moving,then eventually comes with error 5
Check my tips section. This error is covered by HP for almost all machines. It is a known issue and the repair cost is covered entirely by HP.
Apr 27, 2011 | HP LaserJet M1522nf Multifunction Printer...
I have third party software to initiate scanner functions on the Motorola but they do not work. In fact I cannot even scan without using the "Rapid Deployment Client" provided with the hardware.How do I...
DataWedge is an Application provided by Symbol/Motorola to enable the scanning module also for application without the driver. Scanned barcode is sent like an usual keyboard input.
There can be just one active application using the barcode scanner. If you are running DataWedge, you would need to stop it before starting any other application with built-in scanner drivers.
To stop DataWedge just click on the barcode icon in a right down corner and select - Disable DataWedge
Sep 22, 2010 | Zebra Symbol MC5590 Wireless Enterprise...
Nois from the scannermecanism under initalizing
The problem is not in stop sensor.It's in scanner section.The scanner is not initialization couse inside in section has a to much ash on mirrors and the scanner lamp.Replace the scanner section or clean up it.
Sep 28, 2009 | HP OfficeJet 6110 All-In-One InkJet...
Scanner Faliure
Fiend your solution direct from hp. Here is your solution...
http://www.hp.com/printer/prob676ijt65/solution
8011
Jan 16, 2009 | HP OfficeJet 6110 All-In-One InkJet...
Loud ratchet noise
Have you been using ink cartridges other than store bought? Reason I'm asking is that i used a refill kit, and tried those half price refill places, only to find ink was leaking out when not in use & clogged up the ends where the cartridge moves across. take a flashlight & look at the ends of the track that the cartridges slide across on, you may see a build up of ink, that won't allow the cartridge to travel as far as it needs to go to run properly.
Nov 06, 2008 | HP LaserJet 3330 All-In-One Printer
Error Code 009 Scanner out of paper
Right-click the VRS icon in the system tray. Select QC Modes and uncheck Hardware Errors. This will stop VRS from flashing the out of paper message.
(Also, ImageNow has it's own prompt when the scanner is empty. You can turn that off in the Scanning Profile on the Properties page.)
Oct 16, 2007 | Canon DR-9080C Path-Through Scanner
HP PSC 2110 Color Printer Logo
140 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
