Question about Honeywell Programmable Thermostat Heater
What is permanent hold? - Honeywell Programmable Thermostat Heater
  • Honeywell Master
  • 43,501 Answers
When you set a temperature and then push the "hold" it will keep the temp. at that point until you manually change it.... forever....
heatman101
Posted on Aug 23, 2010
Engine sin appearing permanently also hold alarm light blinking what might be the issue
There is a problem with the ECU and needs to be cleared and reset by a workshop that has a diagnostic machine
Apr 13, 2014 | 2006 Chevrolet Aveo
Tip
Permanently delete
If you are sure that you do not want an item, you can bypass the Recycle Bin and permanently delete it.
Select the item you want to delete. Hold the 'Shift' key down and hit the 'Delete' key. The item bypasses the Recycle Bin and is permanently deleted.
on Apr 21, 2010 | Computers & Internet
Using Windows 8-How to delete e-mail permanently?
Go to settings
Email+accounts
Found the accounts you want to delete
Press and hold on it
Will give you two choices sync and delete
Click delete and viola...
Dec 18, 2013 | Computers & Internet
Permanent Desktop icon removal for Symbol MC9090 scanner
Right click the icon. Hold the shift button while left clicking the delete option in the menu. Click ok on the permanent delete.
Oct 19, 2012 | Symbol MC9090 Barcode Scanner
If we enter a specific temp while using the hold button will it keep that temp without doing any additional programming?
If you set a permanent hold yes otherwise it will revert back to the program on the next cycle change. Press and hold "hold" and see if a number of days or permanent option comes up.
Feb 25, 2011 | Heating & Cooling
My hp laserjet P4014n is giving an error message 68.2 permanent storage write fail what can i do to clear this massage?
Hi! I will be glad to assist you in this issue.
Usually all you have to do is initialize hard disk even if you do not have one. Just turn off the printer. Turn the printer back on and when the memory starts to count hold down the menu key until all three lights come on. When all three lights are on solid release the menu button and press the arrow back button and initialize disk should appear in the menu. Just hit the check mark button again and it should take care of the problem.
Here is the link just incase you need more solution:
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} http://h20000.www2.hp.com/bizsupport/TechSupport/Document.jsp?lang=en&cc=us&objectID=bpl12422&jumpid=reg_R1002_USEN#A46
Oct 26, 2009 | HP LaserJet P4014n Printer
Honeywell TH8320U1008
simply push cancel. That clears the hold feature.
Pushing hold once gets - permanent hold.
Pushing hold twice gets - days of permanent hold. So you can set it if you are going away on a temp and at the end of the days it goes back to normal operation.
Jul 21, 2009 | Heating & Cooling
Permanent hold message on thermostat
press run program.... from there, set the schedule for maximum efficiency. permanent hold only shows up after the hold button has been pressed 2-3 times. If this does not fix the issue, there is a master reset button on the thermostat that will set all settings back to factory default.
May 16, 2009 | Honeywell Programmable Thermostat Heater
HP laserjet 3330 Permanent Storage Init.
Switch of the printer press and hold down menu and cancel button turn on the printer keep holding these two buttons and turn on the printer.
As soon as printer display shows permanent storage init. release both the button.
May 11, 2009 | HP LaserJet 3330 All-In-One Printer
Heating & Cooling Logo
334 people viewed this question
Top Honeywell Heating & Cooling Experts
Bill Long
Paul Carew
Brandon Berry
Brandon Berry
Are you a Honeywell Heating and Cooling Expert? Answer questions, earn points and help others
