Question about Yamaha DSPE390 Amplifier
When I play surround sound movies from my blu-ray or DVD or LaCie players my speakers crackle at certain tones. I connect my devices via fibre-optic cables and digital cable. The tones that are most affected seem to be fairly low, sustained tones. An example is the long, orchestral music when the credits are rolling in Enemies of the State. I have tried changing from surround sound mode to the various other sound settings and the problem disappears when I switch to 2 channel stereo, 5 channel stereo, 2 channel enhanced and 5 channel enhanced. It remains on all the other audio modes. I have tried lowering the volume and this does not help. I have also tried switching off and unplugging my sub-woofer and this doesn't help. Any ideas what the problem could be?
  • 1 more comment
  • andrewr895 Aug 23, 2010
    One correction - my surround amplifier is actually a Yamaha RX-V361. For some reason FixYa picked up the wrong link.
    I have tried multiple formats from my DVD, Blu-Ray and LaCie player...they all have crackling when my amp is set to Dolby Digital or other surround settings.
    I have tried turning the subwoofer off and there is still a crackling in the front/centre/surround speakers. The crackling is not the same as distortion.
    There is an adjustment for my amp that allows me to control the frequency that it crossed over to the subwoofer - the choice is between 40hz and 200hz (its currently set at 80hz). What crossover frequency will reduce distortion in the front/surround speakers?
  • 4,924 Answers
Try to reduce the bass value from the equalizer (graphic) for that ..and this will cause to stop distorting ...the issue is that in the surround mode the sound is splitting in bass ; mediums ;and trebles ..and sent to the speakers by frequency category ...this may cause the bass woofer to distort cause the intensity is not balanced but only the low values being played back on it ...It can be though a issue of physical nature with it ..but usually it is just a matter of position ...(be sure where it is posted cause the bass only vibrate in a different way ) ..and of course it is a problem of graphic equalizer...so ..in short reduce the bass and mediums..at high volume ..until the vibrations disappear ...
Posted on Aug 23, 2010
  • Catalin Turcu
    Catalin Turcu Aug 23, 2010
    the front surround setting is the same with the sub-woofer ..cause in this case they are paired..the woofer with the front ..center ..the rear both ..and the front ...there are 3 lines ..with double function to the speakers..this is the cause that turning the woofer off will not fix..but reduce the frequencies ..between the 80 and 400 ..there is the area for the bass and the low mediums..
  • Catalin Turcu
    or if you do not have the possibility to equalize it from the amplifier ..try from the exit signal of the playback device ...reduce the volume from the DVD ..or computer ..and increase it from the amplifier..
    Usually if the signal that you insert into an amplifier is too high level ..it will make noises and stuff..its ..reduce the input signal and increase the amp volume ..for a better control ..
  • 332 Answers
This may not be from your speakers. This could be caused by the disc itself or from the dubbing of the movie. Try playing a different CD entirely.
Best regards
We have a new TV, old surround sound, old dvd player & want to get Blu-ray player with component video output to work with our surround sound. Is this possible & Which Blu-ray player?
component video output is not going to help you hook it up to a surround system. component video is just that - video. No audio signal is carried on it. You would be better served hooking your blu-ray player to the tv via hdmi cable and then running an optical cable from either your blu-ray player or your tv to the surround system (assuming your surround system has an optical input).
Dec 24, 2016 | Televison & Video
Panasonic TV does not play through surround speakers
so it is a connections problem I think. Check if video and audio cables are properly connected. Use color codes as your guide. Also from menu check if all settings are ok. Good luck
Dec 01, 2013 | Panasonic DMP-BDT220 DMP-BDT220
How do I connect my DISH, TV and Blu-ray. Right now I have my DISH satelite HD cable connected to the TV, and a HD cable connected from my TV to the Blu-Ray. The problem i'm having is the sorround sound...
hi,
Is there is any optical digital output in your satelite HD. Then connect that optical digital output of satelite HD to the optical digital input of your surround system (blue ray player) using an optical cable.
Then press the function button on the remote of surround sound system (blue ray player) and select D.IN. (D.IN means DIGITAL IN). You will get the audio through the surround sound system. if you need any more assistance fell free to contact me through fixya.
ok
Jan 27, 2011 | Samsung HTC5500 Theater System
My surround sound will not work through the TV, only the DVD
If your tv and surround has an optical input/output.Then you can connect with an optical lead.This will then play the sound from whatever you are watching.You normaly select dig1 or input1 on the surround system.
Nov 12, 2009 | Panasonic Televison & Video
I have a 5.1 jvc dvd surround system and have just bought a 37'' new lg tv. The system plays in stereo when listening to just tv. It does not have an HDMI connection on the DVD. Can i update with a blue...
Your LG tv should have an optical output socket,if your surround system has one as well,(input) then connect an optical lead from the tv to the system,then select either input 1 or opti 1(depending on your system) you will then get the sound from whatever you are watching on the tv
Nov 04, 2009 | Televison & Video
My subwoofer stop working
I have a Sony 46" LCD TV. I have a Direct TV HD converter box, a Sony Blu-Ray BDP-S360 Blu-Ray player, and a Pioneer DVD-Audio player connected to my Pioneer Elite Home Theater receiver. I have my Pioneer DVD-A player connected via Fiber-Optic cable. When i play a DVD or a DVD-A on my Pioneer DVD-A player, all of my speakers work fine, but when i play a dvd on my blu-ray player, all the speakers work except my subwoofer. How can I fix this problem?
Jul 03, 2009 | Aspire Digital AD-225PSC Subwoofer
No sound from TV to home theatre system
hdmi does sound to,,,try if the reciever has hdmi,,unhook the optical cable and try it by itself,,and vise versa
May 17, 2009 | Panasonic AG-VP320 DVD Player/VCR
Blu ray connect to my sc-pt660
as far as hooking up your blu ray player to the sc-pt660, the only real way to utilize the surround sound (with true surround sound) is through the optical audio out. You need to connect your blu ray player through hdmi to your tv and then connect your blu ray player to your surround sound using the optical audio out/in. I, personally have the sc-pt660 hooked up through component cables so I don't waste an HDMI input on my TV. Except for cd's, there is no reason for you to use the actual dvd player part of the surround sound considering you have a blu ray player. In conclusion, hooking your blu ray player and the sc-pt660 up to get better video simply isnt possible (your blu ray player alone gives the best possible resolution, 1080p). As far as audio goes, run an optical audio cable from your blu ray player to your sc-pt660 to get true surround sound.
Mar 23, 2009 | Panasonic SC-PT660 Theater System
Kenwood DVR - 7000
Hi, same thing happened to my one of the above. I bought a cheap dvd player to view movies and run the audio through the kenwood to use the surround speakers.
Feb 21, 2007 | Kenwood DVR-505 DVD Player
Yamaha DSPE390 Amplifier Logo
46 people viewed this question
Top Yamaha Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Yamaha Audio Player and Recorder Expert? Answer questions, earn points and help others
