Question about HP Pavilion dv6000z Notebook
Black screen,wifi bulb red,restart's automatic no image just black sreen.
    Sergeant:
  • 260 Answers
This is a common problem for several of the "dvxxxx" models from 3 years or so ago. It means that the video chip on the motherboard has gotten so hot that the solder holding it in it's socket started to liquefy and now there isn't a good connection between the video chip and the motherboard. You can get a replacement motherboard from the company for about $450 (give or take alittle), your could order a new one from ebay - but be sure that you order the exact type of motherboard that is in your computer, or you could take it to a shop that knows how to "reflow" the motherboard or "reball" the solder on the motherboard and video chip. If you can find someone to do a reflow or a reball it will likely cost your between $120 - $150. There's a risk though that it will happen again if you have any of those things done. If you get the motherboard replaced or get it working by someone doing a "reflow", then I suggest that you invest in a good laptop cooling pad\fan. I've repaired several of these computers and all of them have issues again after awhile; unless I have used a laptop cooling pad\fan all of the time. -madhatter639
Posted on Aug 23, 2010
How to widen my curtis 42 inch flat sreen top and bottom
Some TV's have a zoom function others do not. The program you're watching controls whether the top and bottom of the screen have black bars and is not the fault of the TV. Widening the picture cuts off a lot of the viewable picture and distorts the image. Circles tend to be oval. If your TV has a zoom function, use it.
Jan 21, 2017 | Top Computers & Internet
Camera screen is black no image appears to view to take a picture??
Time for a new camera perhaps ? Sreen is faulty, most likely and fixing may be too expensive.
Sep 11, 2014 | Kodak EasyShare MD853 Digital Camera
I have lenovo g550...my screen flickers in every 5minutes...
Failing Inverter An inverter, typically found inside a laptop computer, consists of a small board, which has impregnated electronic circuits stamped on it. Inverters look like thin boards about the of two sticks of chewing gum. The inverter and its bulb control the intensity of the liquid crystal display, which lights the screen monitor. The computer can control the output voltage of the inverter and either lighten or darken the screen. A special type of inverter can adjust the brightness of the screen by using an internal sensor to judge the room brightness, and then adjust the screen accordingly. Failing inverters give off some specific warning signs, which can be recognized by observing different screen characteristics.
Short Intermittent Display Upon turning on the laptop, the screen flashes on in the normal mode for a short period and then blinks to black. A very faint image appears in a dark background, which will be very hard to see almost invisible. After shutting off the laptop and restarting, the same mode occurs, where the screen appears normal for a few seconds then fades to black. This condition points to a failed inverter. To confirm this, plug in an operational external monitor; if the external monitor functions, the inverter has failed. b> Total Blackout with Ghost image b> The laptop turns on, as indicated by the power supply button, but the screen comes up black. The screen comes up black after restart. You might be able to detect a very dim or ghost-like image on the monitor. When you plug in a known functioning external monitor, the external monitor operates normally. This mode of display indicates a failed inverter. b> Long Term Periodic Operation b> With this failure mode, the laptop screen illuminates normally upon start-up and remains that way after several minutes, hours or even days, until it goes very dark again. Brightness controls or restoration attempts do not work. Most often, the screen will function normally with a computer restart, but will eventually return to black. Faint ghost images might appear, as seen in the total blackout mode. b> Dark With Color Variation b> Upon computer start-up, the monitor shows black or dark gray, accompanied by very faint images. The screen might have an intermittent color change, or remain on with a non-standard color variation, like pink or red. b> Auto Control Switch b> If the screen appears black, with no faint or ghost images, look for the lid switch near the back hinge. The switch, when depressed with a closed lid, shuts off the computer and monitor functions. Sometimes the switch becomes stuck in the closed position, disallowing the computer and monitor to turn on when opened. Pushing the switch manually several times can often free it up. If the switch tab has broken or jammed inside the case, it needs replacing. b> Loose Connection In this mode, the display looks normal upon start-up, but tapping the side case of the computer turns the screen black. More tapping results in the screen functioning normally then cutting out again. This condition points to a loose wire connection from the inverter to the LCD backlight lamp, or the video cable. The connectors can be accessed by removing the monitor bezel screws and pulling the plastic retainer off. Both connectors can be cleaned and refitted.
Feb 10, 2013 | Lenovo G550 PC Notebook
Black screen
Usually when you see a reddish hue then black.....is indicative of an inverter or backlight failure. Hold the laptop up after it is started and look from the bottom toward the top. Try to shine a flasklight at the bottom of the screen upwards...see if you can see the windows startup screen or anything that gives an indication that the laptop is running and booted to where you can faintly see something on the screen. If you can barely make out an image, then 9 times out of 10 you need another inverter. There are rare occasions that a backlight bulb will fail, but this is rare and most backlight bulb failures are from shock damage. The inverter can be changed by simply removing the screen bezel, unplugging the inverter and changing it. If the bulb has been broken or burned out, it is more cost efficient to simply change out the lcd panel. The bulb sits in a channel under the lcd panels inside the aluminum framework. The panel has to be disassembled to remove it.
May 23, 2010 | Toshiba Satellite Notebook l505dls5005
My sreen is fickering all the time,so bad sometimes the screen goes black,
Sounds like you need a screen replacement. The bulb that provides the backlight to the screen is going / gone bad.
Jan 07, 2010 | HP Pavilion dv9000z Notebook
I have a black margin each side oof the sreen
shutdown the computer and start tapping on f10 if vista key to go to the bios, and then check if you still have the same kind of screen , press f9 and f10 to exit out of the bios to go to the normal screen , if you see the same kind of screen. If you see the same screen uninstall the device driver for moniter and restart and then if required uninstall the display adapters and restart the computer
Dec 19, 2009 | HP Computers & Internet
Epson powerlite s4 projector is pink
I assume this is an LCD. I don't remember the s4 being a DLP projector.
This sounds like the LCD panel used for the red color has gone out. The image is made up of red, green and blue images layered upon the screen. If the red panel has gone out then there is nothing filtering out the red light in the image. This causes a nice red hue to the whole screen.
It could be a simple open and reconnect fix. I personally have never opened a projector, so I'm not going to walk you through it as I do not know how hard it would be to tinker with. It should eb a cheap fix for a true repair man though.
Apr 01, 2009 | Epson PowerLite® S4 LCD Projector
CCD-TRV228E GReen/black sreen problem
It is problem of bad CCD IMAGER and this part requires replacement.
If you know basic electronics and have enough experience of camera repair then get CCD IMAGER under following part number...
A-7013-276-A CCD BLOCK ASSY (CCD IMAGER)
Dec 19, 2008 | Sony CCD-TRV228E Camcorder
I have a 56" Toshiba DLP TV, yesterday evening while watching the CNN news we have heard a cracking sound and the video disappeared, the screen went black. The audio was OK, but the two pilot lights...
Hi when was the bulb last changed as when the bulb goes it will do this. at the back of the tv is a panel, it will have vents an a sign saying something like bulb on it the bulb is in there and there is a screw holding this cover on and inside is a clip that holds the bulb in place, remove bulb and check it for its colour if its black then its blown and you just need a new one. if its damaged in any way replace it and do not touch the glass.
May 23, 2017 | Televison & Video
HP Pavilion dv6000z Notebook Logo
98 people viewed this question
Top HP Computers & Internet Experts
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
