Question about Whirlpool LGR3624JQ Gas Dryer
Heats up shuts off wont heat back up - Whirlpool LGR3624JQ Gas Dryer
  • Whirlpool Master
  • 43,501 Answers
If you are having problems with your gas dryer not heating the most common problem is that the ignitor goes bad. Even though it glows sometimes it is still not working properly.
Check out this tip that will give more details…
Gas dryer not working gas dryer not heating
http://www.fixya.com/support/r4398592-gas_dryer_not_working_gas_dryer_not
If you have an electric dryer, you can have many different things that can go wrong causing the dryer not to heat.
Check out this tip to see the things that can fail to cause your electric dryer not to work.
Dryer Troubleshooting Electric dryer wont heat
http://www.fixya.com/support/r3866345-dryer_troubleshooting_electric_dryer_won
heatman101
Posted on Aug 23, 2010
Dryer works but timer doesn't move. I just replaced it and still having the same problem.
Kenmore 400 6942 Dryer Heat timer - Questions - Fixya
www.fixya.com > Forum > Dryers > Kenmore > Kenmore 400 6942 Dryer
Kenmore 400 6942 Dryer, heat timer related issues. ... The timer doesn't work. ... the heat turns back on the timer stops,heat shuts off the timer will move again,if the ... not heating/timer knob not turning . the dryer works but is not heating and i ...
kenmore 400 doesn't heat, and timer doesn't move, but dryer ...
www.shopyourway.com > Manage My Life > Questions
I understand your Kenmore 400 Dryer doesn't heat up or the timer doesn't move, butit tumbles sometimes. I found the manual for your Kenmore Dryer in ...
Fixing an Electric Dryer that Doesn't Heat and the Timer ...
? 5:51
https://www.youtube.com/watch?v=0mo_gw0p2CI
Jun 29, 2013 - Uploaded by SamuraiRepairman
Although electric dryers are the simplest appliance to work on, ....and now the dryer won't heat and the timer doesn't advance, butthe motor still runs? .... Diagose a Whirlpool or Kenmore Dryerthat Keeps Running, Wont Shut ...
Dec 21, 2015 | Kenmore 400 6942 Dryer
Heat pump compressor wont come on in heat mode, works fine in cool mode, we get heat occaisionally for about 2 min, then the compressor shuts off. it is a fridgedaire window unit.
Try setting the thermostat at a normal heat setting. By raising the temperature too high the unit thinks that the heat pump won't be effective and go into strip heat mode.
Nov 17, 2013 | Frigidaire Energy Star Room Air...
Will not shut off will not heat
check for 240 volts if its electrically heated,if you lose one leg of power or 120 volts on the timer side it wont turn the timer to shut off and only 120 volts wont operate the 240 volt heating element
Nov 16, 2010 | Kenmore 62602 Electric Dryer
Dryer wont start
most of these dryers have a thermal fuse that shuts the dryer down when it over heats and it is not resetable. most of these on a kenmore are on the back of the dryer. locate the thermal fuse and use an ohm meter to tell if it has continuity or not. no continuity - replace it.
also if your dryer is over heating one of the most common causes is a crimped vent hose or pipe. don't use plastic hose as it crimps shut easily and won't let the heat out of the dryer causing the problem you described.
May 25, 2010 | Kenmore 500 6952 Dryer
My dryer wont heat up or shut down
It's not heating up because the heating element is broken and should be replaced. It won't shut down because the thermostat isn't sensing heat and continues to run while expecting heat. So replacing the heating element should get it running properly.
Mar 23, 2010 | Whirlpool LER5636P Electric Dryer
I have a GE Hotpoint flat top stove model # RB787WC1WW and the oven will sometimes shut off by itself. Is there a sensor that shuts it down when it reaches desired heat. It will sometimes turn on if you...
That is what the oven elements are suppose to do. When it gets to temp the thermostat cuts the elements off and as it cools they will heat back up. if it cuts off and wont heat back up its probably the thermostat
Mar 08, 2010 | Hotpoint RB787 Electric Kitchen Range
Replaced heating element/worked for 10 min now doesnt
Howdy: Check the thermostat on the inside in the back. If unpluged or lint is clinging to it , the unit will shut off heat. Please inspect. Good luck - It also could be defective. - Doug
Dec 09, 2009 | Kenmore Dryers
'05 Impala blower wont shut off and wont blow heat
my2004 impala heat and a/c wont shut off and still has power to it when when we unhooked the switch?
Nov 25, 2009 | 2005 Chevrolet Impala
Kenmore heavy duty clothes dryer will not heat
REMOVE THE BACK AND CHECK THE HEATER FUSE AND THE HEATING ELEMENT-MIKE
Feb 25, 2009 | Kenmore Dryers
Tv wont turn on only clicks and then flashes red timer light
I heated up board with hair dryer through back of TV without taking back cover off. The heat was on high for approx. 5min. and was placed on right side of TV about 1/3 up from bottom.
Nov 20, 2007 | Sony FD Trinitron WEGA KV-36HS510 36" TV
Whirlpool LGR3624JQ Gas Dryer Logo
Top Whirlpool Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal DeAngelo
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
