My Sceptre remote stopped working tonight. I tried changing batteries but that did not work. Any suggestions?
  • 718 Answers
SOURCE: Tv Remote stop working already
This only takes about a minute and will restart 1 in 3 "Dead" Original Remote Controls.
Step 1- Pull the batteries out of the remote and leave them out until Step 4.
Step 2- Press and release each and every button one at a time on the remote control until every button has been pressed and released at least once!
Step 3- If your remote has slide switches, you must move the switch to
each position then repeat the button pushing in Step 2.
(When you're done, be sure to put the slide switch in the correct position to operate the unit the remote came with!)
Step 4- Put the batteries back into the remote, being very careful to install them correctly.
New batteries should be used if you're not sure about the old ones.
Step 5- Try the remote.
Special Note:
If you have a digital camera, camcorder or camera phone you can test the remote to see if it is emitting a signal. Face the remote towards the lens of the digital unit until you can see the front of the remote. Depress any button on the remote. You should see a light (steady, blink or flashing) being emitted from the remote.
If you do then the problem might not be the remote but the sensor on the set.
Posted on Feb 28, 2011
micromend
  • 748 Answers
SOURCE: My sharp plasma tv (about 1 1/2 old) works but one
Hello
I've seen this. This is a warranty issue. It's not the transmitter that's bad but the receiver inside the TV. Find someone in your area who does Sharp warranty.
Posted on Jul 28, 2009
  • 210 Answers
SOURCE: Remote control stopped working.
good way of testing remote is point it at camera on phone( turn on camera first) and look for flashing light when pressing buttons if no light then remote faulty if it flashes then fault might be with re-server in tv
Posted on Nov 10, 2009
SOURCE: Sceptre 32 tv won't turn off or change channels,
I have the same problem, did you ever get this fixed?
Posted on Feb 17, 2010
  • 8457 Answers
SOURCE: Our remotes suddenly stopped working.
Tries take the remotes aparts.Take some Q tips soak it with some rubbing alchahols.Clean the PCB circuits board and the rubbers films between them might help,could work after do the cleaning.Not,than sorry ur remotes CPU probally it shorted and dead.That why the remotes not functioning any more.
Posted on May 24, 2010
My remote for my 32in sceptre tv stopped working looking for a code that might work on a universal remote
You have this backwards. The code is generated by the remote. If you have a universal remote, you can use the code search routine described in the instructions to find a code that works. Those same instructions might include a list of devices the universal remote is capable of controlling and your Sceptre TV might be on it.
Dec 30, 2013 | Sceptre Televison & Video
Sceptre TV unexpectedly changes input source away from HDMI
My sceptre tv just started randomly changing through input modes, sometimes once or twice before stopping and sometimes it continues
Jun 30, 2012 | Sceptre X405BV-FHD3 40 in. LCD HDTV
Nov 30, 2009 | Sceptre X32BV-Naga 32 in. LCD TV
Remote stopped working
You can look at the IR beam coming from a remote control using electronic cameras, like camcorders or webcams, if you want to see whether the remote is actually working. It doesn't sound like the remote is your problem. But it is probably your TV. IR receivers don't go out too often, but it can happen. You can try holding the remote directly in front of the receiver.
Apr 16, 2009 | Sceptre Naga III X27SV 27 in. HD-Ready LCD...
Comcast Remote Can't Program My Sceptre HDTV
Thanks...this worked great for me. I used code 11100 on my Sceptre tv and it appears to be working perfectly!
Nov 27, 2008 | Zenith DBZN-311 Remote Control
TV Universal Remote Codes
Most remotes have a "Code Search" function. Try that and if it doesn't work then it's not compatible.
Hope that helps...
Geno
Apr 01, 2008 | Sceptre X20G-Naga II 20.1" Flat Panel LCD...
Televison & Video Logo
548 people viewed this question
Top Televison & Video Experts
