Question about Frigidaire Electric Dryer
I have an electric Frigidaire dryer model #FER641CFSO, Im not getting any heat and was wondering if this could be a problem with the thermostat
  • Frigidaire Master
  • 43,501 Answers
If you are having problems with your gas dryer not heating the most common problem is that the ignitor goes bad. Even though it glows sometimes it is still not working properly.
Check out this tip that will give more details…
Gas dryer not working gas dryer not heating
http://www.fixya.com/support/r4398592-gas_dryer_not_working_gas_dryer_not
If you have an electric dryer, you can have many different things that can go wrong causing the dryer not to heat.
Check out this tip to see the things that can fail to cause your electric dryer not to work.
Dryer Troubleshooting Electric dryer wont heat
http://www.fixya.com/support/r3866345-dryer_troubleshooting_electric_dryer_won
heatman101
Posted on Aug 23, 2010
My frigidaire dryer GLEQ2152ES0 runs but no heat and the lights all blink
bad heating element check with multi meter first? check ur thermostats also. lastly may be not getting full 240 at the terminal block
Jun 09, 2014 | Frigidaire GLEQ2152ES Electric Dryer
Frigidaire dryer too hot
check for air flow on back of dyer, also check the heating element. could be a bad heating thermostat in dryer. good-day !
Feb 10, 2012 | Frigidaire GLEQ2152ES Electric Dryer
I have a frigidaire clothes dryer, model number FSEC747GES1. it turns on but does not get hot, just cold air. wondering if it is the heating element and if so what part number it is, aprox. the cost and...
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check out this electric no heat tip...
heatman101
Sep 17, 2010 | Dryers
My front load dryer model number FEQ1442ESO is running but i dont have any heat. do you know what could be wrong
an internal thermostat called a snapstat and/or your heating element and/or your dryer ventmay not be working or needs cleaning. you need someone experienced in testing with an ohmmeter to test and get back to us.thanks karl
Dec 02, 2009 | Frigidaire GLEQ2152ES Electric Dryer
I have a frigidaire dryer model#crer5700ASO and im trying to locate the heating element . Which is the best way to get to it.
it's behind the drum,the drum is on a rear bearing,it slides down into the holder so to remove the drum you have to lift the drum up in the rear and you'll see the heater on the back wall part number 131553900
Parts & Accessories | Shop & Find Lawn & Garden, Appliance Parts at Sears PartsDirect | SearsPartsDirect.com go here put your model number in and you can see dryer
Nov 27, 2009 | Frigidaire GLER642A Electric Dryer
Dryer squeak and back panel is hot? Frigidaire Dryer FDE436RES1
It sounds like you have a rear bearing bad.
as far as over heating check the vent line. Your thermostats are ok or your high limit would blow and you would have no heat.
Sep 01, 2009 | GE DBXR463EDWW Electric Dryer
My Dryer won't get hot
try doing the following checks--
  • Check for proper air flow
  • Test the safety fuse
  • Test the thermostats
  • Test the centrifugal switch
  • Test the timer motor
  • Test the heating element
If you need the manual check the following link.choose the manual for the appropriate model.
http://www.retrevo.com/samples/Frigidaire-Dryer-manuals.html
Dec 11, 2008 | Frigidaire GLEQ2152ES Electric Dryer
GLER642A dryer heating element
Things that could stop a electric dryer from heating: - house fuse or breaker ( needs 2! )... - heating element ... - burnt wire ... - thermostats ... thermal fuse ( not all models )... - motor heat switch ... - timer ... - selector switch ... - burnt power cord/plug
Oct 10, 2008 | Frigidaire GLER642A Electric Dryer
Dryer not going to full heat
Nov 15, 2007 | Frigidaire GLER642A Electric Dryer
Frigidaire  Electric Dryer Logo
224 people viewed this question
Top Frigidaire Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Frigidaire Dryer Expert? Answer questions, earn points and help others
