Question about Honeywell Programmable Thermostat Heater
It flashed replace batteries, I did and now it is dead, just the outlines show up and I cannot turn on the air or heat
    Problem Solver:
  • 6 Answers
Pull you thermostat back off and try to reinstall it sound like you missed one of the pins in the back of the thermostat
Posted on Sep 16, 2010
Heat Pump, "open start circuit"
Yes it is the start up on the compressor and then the other capacitor is the run cap after the start up. You need to replace the 45mfd cap
Jun 03, 2013 | Heating & Cooling
Epc light in a 2003 Turbo-S Volkswagen beetle turned on, shut off. Next day car wouldn't turn over. How do I fix this from happening and start the car?
check battery volts should be 12.6 volts.if not battery dead.have battery charged and test if battery can be charged alternator faulty.if battery dead cant be charged replace battery.and clean battery cables if EPC warning light still flash have vechicle code scan for faulty accelerator control system or mass air flow sensor.to get vechicle started after replacing battery just turn ignition switch to the on position for 30 seconds then turn off ignition switch then start engine.
Apr 04, 2013 | Cars & Trucks
Yashica T Zoom dont turn on only shows battery outline flashe's
Have you found a solution to your problem?
I am having the same problems with my Yashica T4 Zoom.
At least I have a suspicion, what it could be! ;-)
I think one of the electrical components needs to be replaced. Behind the battery compartment there is a big capacitor installed. It is only to be seen, when opening the camera's body. I think that this capacitor might be broken. Since it is used to store energy, this might very well be the reason the camera does show a blinking battery symbol.
I don't think that the repair is worth the camera.
Sorry ... for the both of us. :-(
Feb 10, 2013 | Cameras
NOKIA 1280 WATER DAMAGE STE DEAD
Aug 14, 2011 | Cell Phones
I have an 05 Chevy Uplander. Battery went dead so
While under the hood to jump the battery, is it possible that a vacuum line might have gotten disturbed, broken or pulled off of a connector?
I would probably look there first; it might be a simple problem not directly related to the dead battery episode.
Nov 30, 2009 | Televison & Video
Akai airconditioner AC-KS24HRC Changed batterirs in remote can not get heat mode icon on remote therefore no heating.Still under warranty but can not find Akai repairer Newcastle N.S.W. Australia...
I had the same problem. Check the remote control section of the manual. When you change batteries the screen flashes the hot and cold icons alternating. press a utton when the hot one is on and it will activate the heat+cool mode.
Jul 15, 2009 | Heating & Cooling
Low battery indicator, even after a new battery
You probably have a dead cell in your replacement battery. Camera batteries have a limited number of charge cycles, and this is not a rare issue with "aged" batteries. Also, when you get a new battery, buy a genuine Canon replacement and not one of the el-cheapo Chinese copies available online. In camera batteries, you really do get the quality and performance you pay for!
Jun 27, 2017 | Canon Photography
What reasons other than fuses would make the heat and A/C stop working. The fan will not come on.
Thermostat, blower motor, system needs a recharge, a short, a loose ground, dead battery, vehicle not turned on, no heat or air installed in vehicle - option not selected -, bad modules, other fuses bad - you'd be surprised how much of a difference it makes checking ALL fuses and replacing bad ones, bad control, system needs replaced, heat not turned on, air not turned on, bad fan. bad fan motor. A million reasons, so at some point, you may need to get it to looked at.
Jan 24, 2009 | 1995 Isuzu Rodeo
Heating & Cooling Logo
107 people viewed this question
Top Honeywell Heating & Cooling Experts
Bill Long
Paul Carew
vance jones
Are you a Honeywell Heating and Cooling Expert? Answer questions, earn points and help others
