Kenmore top loader washing mashine style 158424000 The lid fell down hard and the switch that turns on the washer when the lid shuts is loose or broken and now washer won't turn on now when I put the top down anymore
    Champion:
  • 245 Answers
You have to replace it. Its called a lid switch. It costs around$ 45 to 50 bucks. It's really 2 screws and a plug under control panel.
Posted on Aug 23, 2010
I have a washer mashine kenmore oasis top load wont start
check the lid safety switch located under the top thats actuated when the lid is closed if its bad the unit will fill but not operate on any cycles
Aug 02, 2011 | Kenmore Oasis HE 27082 Top Load Washer
Kenmore 110 washer fills and does the wash cycle but wont drain or spin. Totally shuts down after wash cycle. What do I need to replace
sounds as though the lid switch has gone bad, either that or the motor has lost the reverse winding on it.. most likely lid switch tho.
the lid switch is only "seen" by some older kenmore "110" series at the end of the wash cycle, or end of the rinse cycle. it purpose is to keep the unit from spinning if the lid is opened so no one looses an arm, etc.
generally the console on those machines hinges over backward so you can remove the cabinet top and 3 sides as a unit together..
the lid switch is under the machine top and isn't easily accessible without removing the cabinet.
May 20, 2010 | Washing Machines
Kenmore mod 23832100 Lid Switch broken HOw do I
Good day,
There are 3 different style lid switches used on Whirlpool/Kenmore washers. You have to break down the unit to determine which one you use. Any appliance parts house will carry what you need.
Here is an excellent tutorial.
http://www.youtube.com/watch?v=fC8SY3cU1Yc
Mar 01, 2010 | Kenmore 23822 Top Load Washer
Broken switch on top loader
new style (on top under console) clips in with lid up, old style screws in from side (those frequently break)
Mar 08, 2009 | Whirlpool Cabrio WTW6600SBT Top Load...
Washer agitates, drains OK, but spin doesn't start
Timer is defective. Your unit has a netural drain. When finished agitating, the shuts down and then starts up reversing to drain and spin. On the initial reverse start, the water drains without the transmission spinning. After a timed period 3-4 minutes, the timer is supposed to pause, stopping the motor for a few seconds. When the motor stops again, the transmission shift to the spin cycle and when the timer resumes power tothe motor it should spin. You are doing the same thing when you lift the lid...stopping the timer and then the tranny shifts and when you set the lid down, the washer spins. Replace the timer.......
Feb 09, 2009 | Kenmore 23822 Top Load Washer
Machine wash ,but will not rinse or spin
You have a broken lid switch. Assuming you have the same style washer. The switch is #11,
Dec 16, 2008 | Kenmore 24032\24036 Top Load Washer
Kenmore elite top loader electric washer
you have poor contact with the left lid hinge and the lid switch.1st open the lid and check the 2 phillips head screws on the left side of the hinge.if they are loose tighten them and try mach.if the screws are tight,the lid switch might need to be replaced or adjusted.there will be 1 screw in each corner of the back of the console facing down.remove and flip console up,if there are no screws,take a putty knife and slide under front left and right corner of console and flip console up.the lid switch will be on left.if it is not broken out of socket,adjust hinge bar underneath switch by removing switch and bending silver bar up SLIGHTLY
Sep 27, 2008 | Kenmore 24032\24036 Top Load Washer
Kenmore 88422 Top Loader Washer
The symptoms you describe are often caused by a lid switch malfunction. It may be loose or not making good contact. If you open and close the lid, you should hear a "clicking" sound as the lid switch is activated. If you do not hear the switch, check to make sure the lid strike in still intact. This is a small plastic piece mounted on the lid that pushes down on the switch through a slot on the wash tub opening on the right hand side. If this piece breaks off, it will give the same symptoms of a broken lid switch. Next, check the two mounting screws on the right side of the wash tub opening to make sure they are tight. These are the mounting screws for the lid switch. Sometimes they come loose and the switch does not make proper contact. If you attempt all these preliminaries, and the switch still does not seem to be working properly, replace it. A replacement can be found at searspartsdirect.com. Just type in your model number and the part will be located under the "Top and Cabinet" heading. For instructions on how to replace a lid switch, click on the following link:
http://www.fixya.com/support/r385198-replacing_lid_switch
This is a simple and inexpensive repair. I hope this helps you. Let me know if you require further assistance.
Aug 17, 2008 | Kenmore 22422 Top Load Washer
Washing Machines Logo
Top Washing Machines Experts
