Question about Sharp EL-738 Scientific Calculator
How to get 4 decimals on EL738 - Sharp EL-738 Scientific Calculator
1. Press the "SET UP" button
2. Press "0"
3. Press "0" again
4. It's written there "DIG(0-9)?"
Choose how many decimals you want.
In this case, press 4 because you want 4 decimals.
Hope this will help :)
Posted on Sep 14, 2010
Which is more precise, fractions or decimals??
Fractions can be more precise than decimals. For example: 1/3 can not be expressed exactly as a decimal. .33333333333333333333333333333333333333333... is only an approximation.
Some numbers cannot be expressed precisely as either a fraction or a decimal. pi is an example.
Jan 04, 2017 | Homework
Which is the data key on the sharp el738f
To input data on the SHARP EL738 you need use the ENT button. Type in the data value and press ENT after it.
May 16, 2014 | Sharp EL-738 Scientific Calculator
Sharp el-738 convert to fractions
Unfortunately the EL738 does not have the ability to convert decimals to fractions
Feb 10, 2014 | Sharp EL-738 Financial Calculator
If i have 1 divided by 5 to the power 2 how do i inverse it using a sharp EL738?
(1/10)^2=0.01
To calculate the inverse just invert the fraction 1/10 becomes 10 and you calculate 10^2=100 =1/0.01.
On the Sharps, look for a key marked 1/x or x^-1. If the marking is on the key you just press it while the number whose reciprocal you want is displayed. If the marking is on the face of the calculator you will have to press 2nd F before the key.
Mar 01, 2013 | Sharp EL-738 Scientific Calculator
I have only two decimals after my comma, i need more
Press SETUP 0 0 then enter the number of desired digits.
Aug 22, 2012 | Sharp Brand New-El-738 el738 - Express...
Define algebra:decimal
Decimal is the base-10 notational system for representing real numbers. The expression of a number using the decimal system is called its decimal expansion, examples of which include 1, 13, 2028, 12.1, and 3.14159.
Each of the arabic numerals 0 to 9 is called a decimal digit, and the period placed to the right of the units place in a decimal number is called the decimal point (or, in the case that a comma is instead used for this purpose, the decimal comma).
The decimal is a way of managing numbers that has ten as a starting point, or base. It is sometimes called the base ten or denary numeral system. The word "decimal" is also used instead of the word "period" to point out the dot that is sometimes used separates the positions of the numbers in this system. Almost everyone uses this nowadays and prefers the convenience of it probably because it shows up most often in calculations in nature and has "one" as another starting point for the system. The number one is usually the easiest to work with in calculations.
You may go to the link below for decimal tutorial:
http://www.algebra1help.com/flash/noflash/3.html
Jun 16, 2011 | Computers & Internet
Sharp el506d calculator has the decimal in the wrong place.
Try pressing the FSE button to switch between Fixed, Scientific, Engineering, and Normal displays. When in Fixed display, you can use <2ndF> < TAB > then enter a number from 0 to 9 to choose the number of decimal places in that display. To reset EVERYTHING to factory defaults: With the calculator off, press and hold these three keys: <2ndF> < ) > < ON/C > then release all three. The calculator will go through a series of tests (it takes a few seconds) and then be at its factory defaults. I have uploaded the manual for this calculator at www.theusermanualsite.com.
Nov 21, 2008 | Office Equipment & Supplies
Sharp EL-738 Scientific Calculator Logo
8,601 people viewed this question
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
k24674
jasbo
jasbo
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
