Question about Kenmore 13.7 cu. ft. / 388 liter Upright Freezer 23424
There is cold coming in at bottom but not at top vents
  • Kenmore Master
  • 43,501 Answers
Check out these tips...they can help you figure out whats going wrong with your refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
http://www.fixya.com/support/r3662945-refrigerator_not_cooling_or_fridge_not
How to Defrost Refrigerator Defrost Timer Problem
http://www.fixya.com/support/r3771673-defrost_refrigerator_defrost_timer
Water Running in efrigerator from Freezer
http://www.fixya.com/support/r3780310-water_running_in_refrigerator_from
heatman101
Posted on Aug 23, 2010
Freezer works fine but sides get really warm
Try clearing all vents - inside (make sure vents not covered - in fridge and freezer) and outside (gently vacuum - the coil areas in the back and bottom of fridge)
May be overworking itself to stay cold
Sep 05, 2014 | Kenmore Freezers
Why Kenmore freezer gets cold but doesn't freeze.
Air needs to circulate.
Try clearing all vents - inside (make sure vents not covered in freezer) and outside (gently vacuum - the coil areas in the back and bottom
Aug 25, 2014 | Freezers
The lower half of the freezer is cold but not the top. There is no air blowing ou the top vent. What should I do?
Hello friend, thanks for your inquiry!
I understand that the top of your Frigidaire freezer is not cold but the lower half is. I would recommend to perform a defrost on your freezer, I understand that it is a frost free freezer but it could be that maybe something has caused it to freezer over. You can perform a manual defrost by unplugging your appliance for four to six hours. If that is unsuccessful and you are still not getting cooler temperature up top I would seek assistance from a professional to come out and diagnose your appliance. -Matt
Aug 14, 2014 | Frigidaire 14.1 cu. ft. Upright Freezer...
Freezer not uniformly cold
Check the fan vent to see it's not blocked or frozen. Sometimes a defrost will clear ice temporarily, but it will happen again if you have a bad fan.
Mar 26, 2014 | Amana 19.6 cu. ft. / 555 liter Upright...
Top shelves in freezer not freezing food. Also no ice from ice maker. Seems cold air has stopped coming out of top vent
We had the same problem with our refrigerator just yesterday. Defrosting (even tho frost-free) cleared up the airflow problem-- If it's frost-free, when it defrosts enough to allow air flow, the automatic defrost can take over. Cause was stored food blocking the vent between the freezer and lower part of fridge.
Mar 02, 2013 | Freezers
Kenmore 106.42102301 (top refridg, bottom large freezer) water draining from cold air vent gradually building up on racks and bottom.
Check out these tips...they can help you figure out whats going wrong with yourrefrigerator and why it is not cooling
Water Running in refrigerator from Freezer
heatman101
Sep 17, 2010 | Kenmore Freezers
My freezer isnt as cold as it should be, top part of fridge isnt as cold and ice maker isnt freezing water
find the air vent and see if there is anything in front of them to prevent the air from recirculating. ice could be in the vents to,
Apr 13, 2010 | Freezers
FREEZER MAKING ICE, BUT FOOD IS THAWING
If you have a Freezer on the top model Kenmore, with warm temps in the fridge, AND water dripping onto the top shelf of the lower fresh food compartment (FFC), this is usually caused by a clogged defrost drain. Since Kenmore is not an actual manufacturer of anything, they take other brands, i.e. Kitchenaid, GE, Frigidaire, etc., take their names off and put on a shiny Kenmore nametag. This is a common problem with Kitchenaid refrigerators. You can determine if your Kenmore is made by kitchenaid by looking at the model # tag. the first three digits will indicate the manufacturer, Kitchenaids begin with the sequence, 106.*.If this is indeed how your model # begins, keep reading. Since the water cant go down the drain tubing to the pan at the bottom of the unit, it builds up on the freezer floor, eventually blocking the air return vents from the fridge to the freezer, and the vent from the freezer to the fridge. YOu can check this very easily. Look at the ceiling of your FFC, near the back. toward the sides you will see two square holes, about 2" square, stick your finger and feel around the inside of those holes, do you feel any ice/frost, or do you just feel styrofoam, you might even see frost/ice below the level of your ceiling? This drain usually gets clogged with defrost water that does not completely drain, then of course it freezes, eventually plugging up the drian hole located at the level of your freezer floor, behind the back wall. The water keeps accumulating, and freezing, on the freezer floor, eventually filling in and clogging the air vents..no air flow , the fridge wont cool. The easiest way to resolve this, empty out all contents and store someplace cold for 24 hours...a 2nd fridge, outside in a cooler if its cold like here in chicago. After its empty, unplug, open both doors and blow a fan for 24 hours. Prepare for an abundance of water due to melting ice.
After you defrost, you can plug it back in and it will be fine, HOWEVER, I suggest you take the back freezer wall off, you might have to take a floor cover off first, likely 2-4 screws in both the floor and the back wall. When you have the evaporator exposed, you will see a black cal rod defrost heater underneath the evaporator, as well as your drain hole just to the right of center underneath both heater and evaporator. Take a piece of 12-14 gauge solid, not stranded wire, removing the insulation and exposing the entire 6-8" piece of copper wire. wrap the wire around the diameter of the cal rod heater, 3-4 turns should be sufficient, and stick the other end of the wire down that drain hole. This will melt any ice that will build up in the future, everytime your unit goes into defrost cycle, so this wont happen again.
If air vents are clear of frost/ice, next thing to check is the back wall of your freezer, does there appear to be frost/ice/snow on the back wall? If so, your unit is not defrosting. On most Kenmores, this is usually caused by your defrost timer, located in the canopy mounted at the top of the FFC on Top freezer models, or your defrost thermostat, which is clipped onto the evaporator coil inside your freezer. Again, if its a 106 model Kenmore, this thermostat will have a pink and a brown wire coming into/out of it. My suggestion, if it isnt defrosting, change both. tjhe defrost control will connect with a plug, but you will have to hard wire the thermostat, ( cut wires from old, strip wire, and connect using wire nuts and electrical tape.)
Since y ou mentioned the water accumulation, more water recently, my diagnosis would be the former versus the latter, as the lack of actual defrosting coincides with lack of defrost water, however I'll never say never.
If your unit is a side by side model, check for ice on freezer floor...clogged drain. Check again for frost/ice on back wall, not defrosting, check same two parts, (the heaters rarely go bad on Kitchenaids, but never say never) You should also check for air flow into fridge, even if no frost / ice visible on back wall. Open the FFC door, and locate the air vent near the top, back of the fridge, on the left wall. While depressing the door switch, AND WITH THE FREEZER door closed, put your finger/hand near that vent. Do you feel any cold air? If you dont, you could have a bad door damper, not uncommon, or a bad damper control--> the temperature control WITHOUT the off or "0" position.
If any of this seems a bit overwhelming, I suggest you have a reputable repair technician check your fridge.
Oh, and lastly, you WILL NOT have two compressors, one for each compartment, nor will you have two sets of defrost heating elements, one for each half.
ALL cooling for 99% of refrigerators made in last 25 years takes place in the freezer, with the fridge being an empty box, except for an air intake vent, and an air exhaust vent which leads directly back into the freezer. When a refrigerator unit seems to still be cold in the freezer, but not cold enough or not cold at all in the FFC, its ALWAYS going to be caused by lack of air flow. But as you can see, there are a few things that can cause that lack of air flow.
Apr 05, 2010 | Frigidaire 14.1 cu. ft. Upright Freezer...
Freezer Not Freezing Food
there is a circulation fan and also a vent. Either the fan is blowing, or there is a cloged vent.
Feb 11, 2009 | Kenmore 14.1 cu. ft. / 399 liter Upright...
Kenmore 13.7 cu. ft. / 388 liter Upright Freezer 23424 Logo
32 people viewed this question
Top Kenmore Freezers Experts
AJMAL KHAN
christian nielsen
Dan Webster
Dan Webster
Are you a Kenmore Freezer Expert? Answer questions, earn points and help others
