Question about Dometic Rooftop RV Air Conditioner
What is the expected air temp on a Duo Therm Roof Unit? Also can they be recharged? Thanks!
  • Dometic Master
  • 43,501 Answers
They should run 50 -55 F or about 20 degrees less then the indoor air temp... and yes they can be recharged.....
How to add Freon to a Air Conditioner or Refrigeration System
http://www.fixya.com/support/r5638346-add_freon_air_conditioner_or
heatman101
Posted on Aug 23, 2010
Can I recharge a Duo Therm 600315.001 RV Roof mounted air conditioner? It uses R22 refrigerant. If not, where can I find a replacement or can it be serviced somewhere?
I would suggest that you visit an ac specialist shop as all air conditioners( car, truck , house and yours all use the same principle of operation
because it is roof mounted in an RV may be a caravan repair shop that has an ac specialist in the workshop or a truck service shop that installs ac units in truck cabins would be a good place to start
Mar 13, 2016 | Dometic Heating & Cooling
Duo Therm 3109228.001
sounds like thermostat issue not communicating with relay modeule
Aug 01, 2014 | Dometic 3109228.001 Duo Therm Comfort...
RV AC is working fine, but the water is leaking from the ceiling Where is the drain tube on the unit, The AC unit is a roof type, Duo Therm serial # 43404934, Part # 3105459
Normally, the condensate will drain out of the unit onto the roof and off the edge to the ground. Remove your cover inside (probably 2 screws) and tighten the 4 bolts you will find inside. If they are tight, go to your RV supply place and get new roof gasket. Remove the AC and insert the new gasket and resecure the AC to your roof.
Thanks for your question @ FixYa.com
Jul 26, 2011 | Dometic Rooftop RV Air Conditioner
I have a dometic duo therm roof ac unit that is low on freon - can the system be recharged?
It is a closed system, (ends are soldered) that said, a heating and cooling guy may be able to install fill valves and re-charge for you, but make sure you get a quote ahead of time. How old is the unit? Not normal for them to need re-charge, and I've seen them work good for 15 years, if maintained properly. Has it been completely cleaned recently?
May 26, 2010 | Dometic Rooftop RV Air Conditioner
Installing rv roof airconditioner heat strip
I see what you see also in the manual. The difference is the Heat Strip package that part is optional and the 600212-001 with the optional heat strips becomes the new 600315-001 I talked to Dometic Duo-Therm and the models are the same but they both are not heat pumps but the new heat strip package comes on when told to go into heat mode when you change the thermostat to heat. The part you purchased will fit both model numbers you listed for your roof top air conditioner. Thanks, Sea Breeze
May 09, 2010 | Heating & Cooling
Dometec Briskair Duo-Therm Compressor won't quit running
Have you taken return air filter grille down at ceiling assy, & cleaned filter with dish soap & warm water? Check & see if you see little probe sticking out in behind there, and wipe it carefully as well, and make sure it's lined up to sense air flowing through there. Take a flashlight & look up into coils at front for lots of dust on them as well. Perhaps a thorough cleaning of all coils is in order if you say there's lots of dust, as choking airflow off with dust & dirt, will only shorten life of unit & use more hydro than necessary.
Jul 07, 2009 | Heating & Cooling
I have a duo therm air conditioner think thermostat problem
Google dometic rooftop air conditioning parts!Wouldnt suggest using off brand parts maybe diffrent?if that one is set up for 12v also maybe deffinatley diffrent!!!Try cleaning condensor aluminum fins on roof top if condensor is dirty will throw whole system out of whack!!!use oven cleaner and hose with nozzle be careful not to bend fins throughly rinse off cleaner after soak period spray off completly off roof and sides quickly!!!!!may damage decals etc!!! anyhow try that before replacing parts then use factory or alike parts!!!Good Luck!!!
Jun 24, 2009 | Dometic Rooftop RV Air Conditioner
Location of Drain holes on Duo-Therm Model 630035.321
Good place to start is up on the roof. Look way under the unit (hard to see some times) along the bottom, between where the gasket sits on the roof and metal bottom of unit. Should see small round or similar sticking down from unit. There will be a hole in the side of them. Poke around with a wire or something to open them up. If you don't see water/condensation running across your roof from unit when it's operating, (usually in 2 directions, 1 each side of unit) then yup, there plugged.
Aug 05, 2008 | Dometic Rooftop RV Air Conditioner
Dometic Rooftop RV Air Conditioner Logo
273 people viewed this question
Top Dometic Heating & Cooling Experts
Bill Long
Donni Steen
mike cooper
Are you a Dometic Heating and Cooling Expert? Answer questions, earn points and help others
