Question about Kenmore 60172 Electric Commercial Dryer
It takes 2 or 3 cycles to dry one load of clothers
  • Kenmore Master
  • 43,501 Answers
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
If your dryer is not drying like it once did or if you just have not taken the time to give yourself a clean dryer in a long time then you need to do that. At least once a year the dryer cleaning should take place. Lint build up in the dryer duct is one of the main causes for your dryer to fail.
Here is the rest of this tip about Dryer Maintenance
heatman101
Posted on Sep 12, 2010
The dryer heats up,it also goes through the entire cycle but the clothes are never thourly dryed.What could be the cause?
Typically it is because lent has built up in the vent tube. Here is a good site that shows you how you can do it yourself: http://www.wikihow.com/Clean-a-Clothes-Dryer-Vent
Sep 04, 2014 | Kenmore Dryers
LG Dryer takes too long to dry clothes
Sure the outside vent is not clogged up? If so it will overheat and turn it self off and do a poor job of drying the clothes.
Also check and make sure that all of the heating elements are working properly.
Jul 09, 2017 | Dryers
It takes several cycles to dry clothers in my Kenmore elite He4 dryer, it feels like hot air is blowing but the clothes are not getting dry any suggestions?
werw
Sorry to read about your problem, I hope this helps you out.
Clean your dryer vents, and lint filters. You may need to clean vent from wall to outside. to test this.. unhook vent pipe from wall..and run dryer and see what happens. or you have a defective heat coil
I tried to help you. Please help me and Rate/Vote on my response. We take the time to answer your question. take the time to rate us.Thanks and good luck
Dec 28, 2010 | Kenmore Elite HE4 Electric Dryer
My dryer will only slightly dry my clothers
make sure you have the required 240 volts to the unit,then check the high-limit and cycling thermostat(s) on the element case and make sure you have good air flow through out the unit,if its plugged with lint air won't flow and it won't dry right
Apr 26, 2010 | Maytag Atlantis MDE7400AY Electric Dryer
Maytag Performa Dryer doesn't heat up properly. Takes 2 to 3 cycles to dry clothers. Recently changed elements. Maybe a little better but not much. Any ideas?
I replace an awful lot of blower wheels on these. The flat portion of the plastic blower melts causing the wheel to be loose on the shaft. I have repair photos HERE
I pop the top and remove the front, then remove the old blower wheel and clean out the dryer, oil the rollers and idler and check the glides for wear. When I gits that baby back together it be sweet.
Feb 26, 2010 | Dryers
We have a kenmore series 70 washing machine that is 5 years old. During the spin cycle at the begining it is adding water to the tub, then spinning. we have to by pass the first part of the cycle inorder...
I would concur the timer is not working properly. Get the number off the timer and search ebay. I have been finding parts for half or less the retail cost.
Eric
Nov 22, 2009 | Kenmore 22422 Top Load Washer
Washer-dryer # wm3677HW will not dry,heats up, run, on and on
You're a moron. This unit washes and dries. That's the whole point of it. Perhaps you should do some research before answering the question. the most likely cause is the water lever sensor.
Aug 09, 2009 | LG TROMM WM2688H 4.0 cu.ft. Front Loading...
Kenmore Dryer Model 110.888029 Serial MH1102412 Type 180.00
MOST LIKELY PROBLEM IS A RESTRICTION IN THE EXHAUST. DISCONNECT THE VENT FROM THE BACK OF THE DRYER AND TRY DRYING ONE LOAD. IF IT DRIES O.K.,
THERE IS A RESTRICTION IN THE EXHAUST. CLEAN THE LINT OUT FROM THE ENTIRE LENGTH OF DUCT WORK.
Apr 08, 2008 | Kenmore 63942 Dryer
Kenmore 60172 Electric Commercial Dryer Logo
35 people viewed this question
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Sal DeAngelo
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
