Question about Whirlpool GHW9300 Duet Washer
Rattleing when water is filling - Whirlpool GHW9300 Duet Washer
  • Whirlpool Master
  • 17,130 Answers
Check the inlet line and see if the inlet valve is chatteringg due to dirt inside, thich can cause it keep trying to open.
If so remove and clean or replace.
Unless some parts are loose in the inlet water flow section there is no other option of this chattering except if the relays do so .
Locate the source of noise to identify..
Posted on Aug 23, 2010
Fill water tank
small float in tank stuck in down position. remove tank and clean with hot water. rinse the give a good shake you will hear float rattle in tank
Dec 22, 2013 | Jura Capresso Impressa S9 Coffee...
My dishwasher does not fill with water and makes a tinny rattling noise.
Here is a tip that will help you to find out why water will not come into thedishwasher...
Dishwasher Trouble No Water entering Dishwasher
heatman101
Sep 05, 2011 | Dishwashers
My top drawer says it isnt getting any water and the water hose is rattling. the bottom drawer works fine
Its common for the Dual Water Valve to slowly decrease water flow to the tub. It generally faults on the top draw as its the most used...more wear on the top valve.
This is more often seen on US Models (120v) that have hot water fill.
Jul 14, 2011 | Fisher and Paykel Dishwashers
Rattling AFTER water use, while heating
1) Rattling or clunking sound in pipes when water is shut off can be caused by lack of air chamber at the faucet. When moving water is suddenly stopped by faucet turning off, the forward energy of water suddenly stopping will cause pipes to shake. This is because water cannot be compressed. To stop this problem, each faucet has air chamber connected to pipes behind the wall. The air chamber is a simple pipe sticking up with a cap on it. The air chamber never fills with water, so a 'pocket' of air is contained inside the pipe. When water shuts off, the forward motion of water moves up the air chamber where it compresses the air which absorbs the energy, so pipes don't rattle or clunk.
http://www.crsupport.us/images/7b_build_const.jpg
2) Gurgling, popping sound inside tank is caused by sediment build up.
http://waterheatertimer.org/How-to-clean-sediment-out-of-water-heater.html
3) Add a comment with your experience so others with same-similar problem can benefit.
Also take advantage of fixya expert assistance live.
For a price, expert works with you while you work on plumbing or any do-it-yourself project.
Fixya is always less expensive than a service call.
Mar 28, 2011 | Rheem 50 GAL ELEC TALL Water Heater 6YR SC...
3357978 whirlpool: it would fill water to correct level but would not do the wash - there would just be a mechanical rattle. when i turn it off and move the dial to the spin cycle it would not spin but it...
look on bottom of unit... there is a drive coupling made of plastic that is in between the transmission shaft and connects the motor shaft . this is like a shear pin on a tractor when put under to much stress of just after wear will break to prevent damage to motor or transmission.,. it has three teeth on each piece and is connected by a black bushing in between the 2 pieces.. if the teeth break it will rattle and prevent the tub from turning... a very in expensive part to replace and have seen many people throw out perfectly good washers thinking the transmissions were bad and it was just a 10.00 part... good luck to you...
Feb 03, 2011 | Whirlpool Ultimate Care II LSQ9549L Top...
Maytag washer causes water pipes to rattle when filling
Could be something called water hammer which is a pipe issue. You can install/have installed a water hammer arrestor which is a small pipe extension that stops that.
Nov 22, 2017 | Miele 24 in. G881SCI Built-in Dishwasher
Loud rattling grinding noise when pump is running, no water enters the machine.
Make sure the water is turned on to the machine, if it is then it sounds like a faulty water fill valve, just replace the fill valve, they can sometimes be cleaned but I would never trust one, they can always stick in the on position later and flood your house. Check to see if the valve is geting 120v ac before replaceing the valve, if it's getting voltage and no water is flowing then the valve is bad. You will need to borrow or buy a multi-meter for this test.
Feb 01, 2009 | Whirlpool Gold 24 in. Built-In Dishwasher...
Rattling noises and blowing water (goldstar WG5005R)
If the unit is new and tilted enough toward the outside, the rain should not be a factor as far as water blowing out. It will make some rattling noises on the outside more so when its raining or high humidity because the outside fan throws water onto the condenser coil. Sounds like to me that its not draining to the outside.. It shouldn't be dirty enough for the drain paths to be filled with crud. Tilting it more to the outside should fix it. Hope this helps. kstfas
Aug 26, 2007 | Heating & Cooling
Washing Machines Logo
64 people viewed this question
Dan Webster
Dan Webster
Sal De GO PATS
