Question about Panasonic Televison & Video
Fault code F498 on panasonic VCR/DVD player HV-VHD1. DVD draw will not open.
As far as i understand, it is caused by dry joints - poor workmanship. Try taking the top off and pressing down on right-hand side the green circuit board with the dvd in standby. Then switch on. If that works then what i did was to take all the screws out and jiggle it then put all screws back except the one to the left of the board, next to the brown board. seems to work now. Tip found on another forum, no credit to me
Posted on Jun 12, 2008
What is the code for a Panasonic tv/dvd/vhs combo.....
New 3 digit codes for DVD/VCR, DVR/SAT, TV/VCR, TV ...
www.eliztech.com/remotes/ge-new-3digit-combo-codes.php
DVD/VCR, DVR/SAT, TV/VCR, TV/DVD, DVR/CABLE and DVR/DVD combo codes for GE/Jasco three digit universal remote controls purchased after ... 3 digit codes for GE Universal remotes purchased after August 2002 ... PANASONIC, 437.
[PDF]Manufacture Code List
https://www.att.com/support_media/images/.../set-up-code-list.pdf
AT&TDVD VCR COMBO. VCR. HTIB. REC TUN. AMPLIFIER. TV. Abex 1098. Admiral ....Panasonic 1003, 1010, 1049, 1053, 1096, 1123, 1152, 1231, 1289,. 1292 ...
Remote Control Program Codes - FTC - Farmerstel.com
Jan 01, 2016 | Panasonic Televison & Video
Have philips univerasal remote need codes for my panasonic dmr-ez28 dvd recorder
Panasonic DMR-ES30VS DVD Recorder/VCR Universal ...
www.fixya.com > ... > Panasonic DMR-ES30VS DVD Recorder/VCR
Panasonic DMR-ES30VS DVD Recorder/VCR, universal remote related issues. Getfree help ... My remote does not work anymore. what is the code for a universal remote? Thanks in ... Question about Philips DVD & Blu-Ray Players ... How do I getremote code for GE universal remote control Need remote code? How to ...
Philips Magnavox MWR20V6 DVD Recorder/VCR Remote ...
www.fixya.com > ... > Philips Magnavox MWR20V6 DVD Recorder/VCR
Dec 20, 2015 | Panasonic Televison & Video
Panasonic VCR/DVD combo - stopped recording sound
Seek tech support. This is not a self repairable work. Need technical skill.
Jun 02, 2012 | Panasonic DMR-E75V DVD Player/VCR
Panasonic Video/dvd player DMR ES30v Fault code U99
Hi,press the power button on the dvd so it goes to standby,then press the power button again to turn the unit on.I hope this helps.Jamie
Mar 12, 2009 | Panasonic DMR-ES30VS DVD Recorder/VCR
DVD olayer displays fault code F498. How do I fix it?
Error code F498 refers to "failure to process digital communication" which refers to solder failure of connectors, PCBs, laser eye and other major component interaction. It is a fairly common Panasonic problem.
A logical course of action is to present it to an authorized Service Center for appropriate action.
Your alternate options are:
  • Try a reset. Unplug from the mains for 30 minutes, hoping that it is just a system's glitch;
  • open the unit and check for any cold solder, flexible cable connectors and other electrical joints;
  • seek the services of a qualified professional.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards. Thank you for using FixYa.
Aug 11, 2008 | Panasonic Televison & Video
Menu display3
its hard to help without the schematics have you tried a VR resistor where you can decrease the resistance gradually to try to achieve the required voltage? Thats what I try when I cant get schematics.
Mar 27, 2008 | Televison & Video
Panasonic DVD-RV32
dvd wil not function and screen display f498 i need help
Dec 01, 2007 | Panasonic DVD-RV32 DVD Player
Faut F489
This is for code f489 as well as f498 F498 means a problem with flash eprom IC; meaning that unit is unable to read the basic instructions from the eprom IC. Can be cuased by several; may simply be a "bad connection issue" at the eprom Ic or somwhere in the Bus line--defective Ic or corrupted information which may or may not be recovered with a "service recovery" disc.(not an end user procedure) First step; try resoldering Eprom ic being careful not to bridge pins. second would be to take the unit to a AUTHORIZED ONLY repair shop for a firmware or eeprom update. Good Luck
May 24, 2006 | Panasonic PV-D734S DVD Player/VCR
Zenith dvd recorder/vcr
could be a small belt thats keeping the draw from opening or a power supply problem Or maybe even a fault in the slider assy that has the laser on it as if it doesent return to the "home" postions nothing else will work. Good luck
Apr 21, 2006 | Zenith XBV343 DVD Player/VCR
Televison & Video Logo
1,008 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
