Question about RTO PasLode 900420 Impulse Framing Nailer
BOUGHT THE 900420 USED. DID NOT GET A OPERATION MANUEL. DO NOT KNOW HOW TO USE THE TOOL
  • 490 Answers
Here is the link to the user's manual at Paslode. Happy nailing:)
http://www.paslode.com/uploadedFiles/Operation_Cordless_Framing_Nailer.pdf
Posted on Aug 23, 2010
Paslode 350 tell no light
If you have no light at all in the handle and you're sure you have a charged battery, then I would look at the battery contacts - that tool has the contacts molded into a circuit board assembly so if it is not obvious I would take it to a repair center to be diagnosed.
May 07, 2014 | RTO PasLode 900420 Impulse Framing Nailer
Paslode impulse framing gun is dead, no green light
are you sure battery was charged ? if so , then battery contacts or circuit board may be broken.. but its probably a spark unit( little black box in handle of tool) that has gone bad. fairly easy to replace , but little expensive (60-80 dollars)
Sep 18, 2012 | RTO PasLode 900420 Impulse Framing Nailer
I'm not a seamstress by far lol,bought a used sewing machine and need the instruction manuel. does anyone know how i can get one?
Check on-line for that make and model...you might be able to either order one or download a copy directly from the company themselves...that's how I got mine for my Janome and how I was able to fix my machine myself by getting the instructions to do a reset and save myself a couple of hundres dollars
Sep 13, 2012 | Brother LS-2125 Mechanical Sewing Machine
Lockout Follower bar and spring location for Paslode 900420 Nailer
you can try going to paslode.com and downloading a breakdown of this tool. The lockout bar and spring go under the metal plate on the side where the pusher spring is. You have to remove the nose piece (2 screws) and lift the metal plate. Towards the bottom there is a slot that the spring goes in and as you are holding the spring push on the back side and lay the lockout bar in place. Replace the metal plate and hold in place to ensure these parts more freely. Reassemble tool. Let me know if you need more assistance.
Mar 11, 2012 | RTO PasLode 900420 Impulse Framing Nailer
Nailer has not been used for a while. will not work.Bought used, had trouble; would work intermitenly. got it repaired. now will not work.
Roy,
If you got it "repaired" by an authorized mechanic for Paslodes, take it back and make them fix it.
HolzHacker (means: wood-butcher)
Dec 19, 2010 | RTO PasLode 900420 Impulse Framing Nailer
Will the paslode 900420 discharge two nails at the same time.
Stick with the paslode brands nails... the money you save using other brands is off-set by higher maintenance costs and tool down-time
May 03, 2010 | RTO PasLode 900420 Impulse Framing Nailer
Friend took my 900420 nailer apart to clean it and when he got done, had a small spring about 3/16" x 1" left over. Does anyone have a clue where it might go?
Thin spring?
Goes in-between the Follower Guide and Button.
There are several Coil springs used in a Paslode 900420 framing nailer.
1.In-between the Upper Probe and the Lower Probe.
(Safety device you depress so the gun will shoot)
2.Trigger
3.Lockout Bar
4.Follower Guide and Button
(There is a flat spring also. Goes in-between the Probe Stop and Probe Release)
Here let me show you,
http://www.paslode.com/uploadedFiles/Cordless_Framing_Nailer_Parts_Diagram_Schematics.pdf
Oct 17, 2009 | RTO PasLode 900420 Impulse Framing Nailer
Paslode cordless framing nailer model 325 (black)
the fan is what returns the valve in the chamber, whilst it may have been lubed it must be spotless in the chamber. Use paslode gun cleaner a clean cloth and the handle of a wooden spoon or similar and clean all residue and grime out of chamber and re lube. Or you just have a dead tool that was used for parts! good luck
May 08, 2009 | RTO PasLode 900420 Impulse Framing Nailer
RTO PasLode 900420 Impulse Framing Nailer  Logo
226 people viewed this question
Top RTO Air Tools & Compressors Experts
yoopertech
John Trevino
Ronny Bennett Sr.
Ronny Bennett Sr.
Are you a RTO Air Tool and Compressor Expert? Answer questions, earn points and help others
