Question about Samsung Electronics - Others
Error region code ht-z220 pls want to know to set a free region
    President:
  • 1,139 Answers
Ok, here is what you need to do :-
1. Remove any disc that might be in the machine
2. Unplug the power lead from the player
3. after 30 seconds reconnect the power lead
4. Turn on the dvd player with the remote and wait for "No Disc" to be displayed.
5. Press enter on the remote then press 8,4,2,6,9 then press enter. The dvd player should switch off
6. Turn the dvd player back on, then off again. Do this once more and it should now be region free
Hope this helps and thank you for using FixYa
Posted on Aug 29, 2010
  • dicender Feb 13, 2011
    THIS IS WICKED! IT REALLY FIXED MY ERROR REGION!
MAKING A SAMSUNG HT-F6500W REGION-FREE
1) Switch Player off then On (this is to clean-boot firmware).
2) Wait until main menu appears
3) Open Disc Tray and Close Disc Tray (May not be necessary)
4) As soon as "No Disc" is displayed quickly press REPEAT on
remote quickly use the following code for your current
region:
Region 1: Press - 2,9,3,3,4
Region 2: Press - 5,7,5,3,8
Region 3: Press - 5,6,7,3,2
Region 4: Press - 7,6,8,8,4
Region 5: Press - 5,3,8,1,4
Region 6: Press - 2,4,4,6,2
5) Your current Region will appear in the top-right corner
6) Quickly Press "9" before it disappears (It should replace
the code with a "9" in the corner)
7) Switch Player Off and then On again.
Note that REPEAT is part of the code so one smooth press of
6 keys is required.
There isn`t currently a region hack for Blue-Ray Disks
Dec 27, 2013 | Samsung HT-F6500W/ZA Home Theater System -...
Region code
You can change region code three times, I do not know if there is a hack to make it universal, I will have a look.
Jul 13, 2008 | Audio Players & Recorders
I would like to make my SAMSUNG HT-F5500W region free
There seems to be useful info here:
http://forum.videohelp.com/threads/342271-Samsung-HT-D6750w-Region-Free
Dec 07, 2013 | Samsung HT-F5500W 5.1-Channel 3D Blu-ray...
HT-Z320 displays PROT code and then shuts down
i had the same problem a prot display then it would shut down. turns out i had the sub disconnected(noise complaint from the shaking at my apartment complex) but the speaker wires for the sub connected to the amp or central unit. when i disconnected the sub i left the wires on the floor behind the sub separating the pos. and neg. somehow the wires got moved around and the pos was touching the neg. as soon as i noticed and fixed this problem the system was working fine. my samsung hometheater model is HT-BD1250
Dec 29, 2009 | Samsung HT-DB120 System
I cant play any discs on my samsung ht x200 due to a disc region error
Go through the set up menu on the Ht DVD player (if it's all in one) and change your settings for the region code. Obviously it is not the one that you have already set it to (probably set by manufacturer). NTSC, PAL, etc. I hope this helps.
Oct 26, 2009 | Samsung HT-X200 Theater System
Want to play my old DVDs from overseas, but I get a region code error.
Try the following:
1. Open tray and remove any disks in tray.
2. Close tray.
3. Switch Off Player and Unplug from mains wait 30 seconds (this clears RAM)
4. Reconnect to mains
5. Turn on player with remote.
6. Press ENTER on remote.
7. Press 8, 4, 2, 6, 9. Using keys on remote. If your player is already set to region 2
8. Press ENTER on remote. (The tray will open and player will power off and close tray.)
9. Switch on power from remote.
Player is now Region Free.
Apr 16, 2009 | Samsung HT-DS610 System
Samsung ht tz315 unlock code
i JUST tried the unlock to multi region for my samsung ht-tz315 and it didn't work does anyone have a crack for this please. thks
the code was
Turn On player with remote
Press Enter on the remote
Press 8, 4, 2, 6 and 9 on the remote
The player will power Off
Switch On power from remote
does not work
Aug 01, 2008 | Televison & Video
Code to make my dvd player multi-region
@totallytad,
Try:
Known region free hacks for a Panasonic SC-HT75 are described here or here.
You can also try:
Try this It is for a SC-HT75 but seemed to work on my machine.
Start with an empty tray
USING THE REMOTE press "SETUP"
Go to "DISPLAY" menu
Select "ON SCREEN MESSAGES" then press "ENTER" button
Press ">10" found on the bottom right coner
Press "6" button
Press "4" button
Press "3" button
Press "8" button
A PASSWORD WINDOW SHOULD APPEAR
TYPE IN "3192"
PRESS THE "ENTER" BUTTON TWICE
You will see RESET-DVD in the display and after this the disk will be read and the HT-SC75 is Region Free.
When replacing "3192" by "3193" The HT-SC75 is also Macrovision Free!!! This was originally posted here.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Thank you for using FixYa.
Apr 26, 2008 | Televison & Video
Electronics - Others Logo
515 people viewed this question
Top Samsung Electronics - Others Experts
Jeff Sterrett
Jeff Sterrett
David Brown
David Brown
Are you a Samsung Electronics - Other Expert? Answer questions, earn points and help others
