Question about Sony KP-46WT510 46" Rear Projection HDTV
On the left side of our tv there is a yellow and blue edge around the words and pictures. is there anything we can do to fix this. the tv was purchased in 2004. any help is appreciated. thanks
    Top Expert:
  • Sony Master
  • 14,553 Answers
Yes there is, you can first go into the customer menu and select convergence--see if it will or will not adjust in that area. If you are willing I will tell you how to get into the tech menu to do the same thing; understand if some part of the screen will not adjust in customer menu--a bad convergence IC.
This model should use two of the STK-392-560 CHIPS FOR THIS--about 14 dollars on Ebay for a pair.
If this is the case I can tell you how to do the repair--total parts cost should be under 25 dollars.
Try adjusting with the Sony remote in the customer menu first.
I have fixed hundreds of sets with this problem--many were Sony.
See attached photo of typical convergence problem and photo of typical convergence chip.
If this told you something you did not know rate this solution as very helpful.
SD TECH
on the left side of our tv there is a yellow and - 1ea0547.jpg Number will be on front of the chips and they are side by side on a board with two metal plates with fins on them.
Yours should have STK-392-560 ON THEM.
Posted on Aug 23, 2010
The colors seem out of focus. Blues and yellows don't seem to match. For instance, if I have words projected, it's like I have a blue word with a yellow shadow of the word. And there is a band of blue...
sounds like you have ghosting, this is not adjustable unless you can get into the hidden menu and then you have to know exactly what you are doing. Or the LCD ribbons have come loose. The easiest thing to try is reflashing the software.
May 18, 2010 | InFocus Proxima UltraLight LS2 Multimedia...
MY TV NOW SHOW BLUE AND YELLOW AT THE TOP AND
i have a 52 in rca tv and i turned it on and now there is a blue and yellow stripe at the top and bottom of the tv. and the people have a blue shaddow around them ? how can i fix this?????
Aug 25, 2009 | Hitachi Televison & Video
I left my tv on when I went to bed and the picture was fine. Then I woke up and turned it off. When I came home and turned it back on, the picture was blurry all around the tv except in the middle of the...
is the blurry all around the picture have different color like a smear of red, blue or yellow?
if it is i think the posistor of your tv is not working. it is the one who activate the degaussing coil around the picture tube the prevent color miss-landing upon opening your tv set.
Aug 11, 2009 | Samsung SlimFit TX-S3082WH 30" TV
Double Vision (Mainly around the edges of the screen)
Look for your Convergence amps and check the solder connections on them....you may only have to resolder the amps...and if they fail in a couple weeks, then replace them...
If you don't beat up the convergence amps for WEEKS operating them with the bad connections, they can survive...
Jan 29, 2009 | Toshiba 50HDX82 50" Rear Projection...
Sony KP-51ws500 Sagging Picture and blurred colors
Bad convergence Amp ics mounted to large metal heat sinks on deflection bd.Sony parts around $40.00 each-generic approx 12.00 ea.The board must be pulled out of chassis frame to unsolder the ICs.and some alignment will be needed after replacement.NOT a do it yourself job unless experienced at soldering and desoldering.
Jan 04, 2009 | Sony KP-51WS500 51" Rear Projection...
Copy of picture and words slightly to the left side in red
do not try to do to it anything.please contact the nearest repair shop.
May 23, 2008 | JVC AV-27230 27" TV
Sony kp-65wv600 blue arch line on left side
in the menu does it have a convergence menu? try doing that.
Feb 20, 2008 | Sony KP-57WS500 57" Rear Projection...
My TV is not working! Please help!
http://home.earthlink.net/~oleg.filippov/ConvergenceFix.htm
http://cmpalmer.blogspot.com/2006/11/fixing-my-own-tv-part-ii.html
Sony Convergence
http://www.techlore.com/blog/entry/19694/Sony-Convergence-Repair-My-Sony-TV-has-a-distorted-picture-/
http://www.techlore.com/article/19631/Sony-Convergence-Procedure/
Dec 22, 2007 | Samsung HC-P4363W 43 in. TV/DVD Combo
Sony KP-46WT510 46" Rear Projection HDTV Logo
198 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
