Question about Sport & Outdoor - Others
I have a snapper z yard cruiser 38inch deck 14hp joystick control how do i rout the belt to replace it
2 Suggested Answers
wireguy212
  • 1627 Answers
SOURCE: snapper yard cruiser 33in. cut joystick blows
Unplug the engagement clutch[it bolts to the motors crank] and try to engage again.If the fuse does'nt blow you need a clutch.If it does still blow you need a switch or you have a short in the harness.
Posted on Nov 03, 2009
Mower deck belt routing diagram for snapper mower model YT16D414B
Request the mower deck belt routing diagram directly from Snapper.
Jul 09, 2017 | Snapper Garden
How do you replace drive belt on a 19 hp yardman 46 cut
Lisa, You could try to Google search your make and model# manual.
Check the attached links manual,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
46 Deck Belt Pulley Routing Riding Mower
Replace Your Lawn Tractor Deck Belt
MTD YARD MACHINES 46 CUT RIDING MOWER DECK BELT INSTALLATION REPLACEMENT
Yard Man 604 Operator Manual
Aug 06, 2016 | Garden
My snapper yard cruiser Lou runs drives turns left right but when I pull the PTO switch the blades will not engage it's a snapper z yard cruiser with kohler engine
There are limit and safety switches in the wiring circuit. When it registers a back-up it disables the blades or turns the engine off. Find the backing switch and try to temporary bypass it
Jul 10, 2015 | Snapper Garden
48" snapper zero turn yard cruiser
ether bad check valve or pump went out check valve 100.00 if pump 300.00
Sep 07, 2014 | Snapper ZT2748 48" 27HP Zero Turn Lawn...
My MTD 14hp lawn tractor (38", 6 speed) shuts of
You have a short somewhere . A cut or stripped wire that , at the time of lowering your deck, touches the body. It's like turning off your key. Look around under your deck and you will find what I'm talking about. Fix wire and tie up to prevent future problems. GOOD LUCK.
Jun 16, 2011 | Yard Machines MTD Gold 20 HP Lawn Tractor...
Replacing broken drive belt.
look under foot rest on tractor usually there is a diagram under there for belt routing and also sometimes on the mower deck it's self
Jun 24, 2010 | Craftsman 24 Hp 48" Deck Yard Tractor
Snapper yard cruiser 33in. cut joystick blows
Nov 03, 2009 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
The newly purchased deck belt turning the blades is extremely loose
If idler is in tact and spring attached, it is likely that the belt isn't routed properly. If you try to route the rear-most portion of the belt around the idler, it will be loose. You must route the front-most portion of the belt around the center blade pully and then around the idler. Just Google "MTD 46 inch deck diagram" and you will go to a Parts Tree site with the proper diagram showing routing.
May 26, 2009 | Mtd Garden
Sport & Outdoor - Others Logo
57 people viewed this question
Top Sport & Outdoor - Others Experts
Are you a Sport and Outdoor - Other Expert? Answer questions, earn points and help others
