Question about Focusrite Saffire Pro Sound Card
Firewire connection dead - Focusrite Saffire Pro Sound Card
My Avastor HDX Portable HD drive just crashed. I had it connected to my Mac, and when finished using it I wanted to eject the disc but it wouldn't, whatever i tried. So i disconnected it anyway. But...
Hi!
i dont know if your drive is dead , but try to connected to an Other Pc with different System (windows Xp Or 7 ) and see if it work try to formate it , but if he didn't work that's mean is dead ,
good Luck
May 23, 2011 | Avastor HDX-800 400 GB FireWire 400...
My G5 tower is no longer recognising my external iSight camera. The only thing that happened was that I switched the G5 off and on again, it was working fine previously. Can you help? Many thanks
Best thing you can do is to determine whether its the port or the camera.
If you go to the Apple in the upper-left corner, and go to "About this Mac", then click "More information", it will start System Profiler. On the left side, under "Hardware", click on "Firewire" and see if your iSight shows up. If you have another FireWire device, plug it in, and see if it shows up there as well. The solution could just be a dead iSight (hopefully!). The worst case scenario is a dead FireWire bus...
If you have a dead iSight, I'd guess that ebay would be your best resource at this point. If its a dead bus, I'm afraid it won't be terribly cost effective to fix it :-/
Jan 06, 2011 | Apple iMac G5 Desktop
I have a Canon MVX150I Mini DV Digital Camcorder and wanting to know how to connect to my Apple MacPro Book. When i connect with a FireWire 800/400 (9-pin to 4PinCable) the MacPro cannot find it. I am...
Place the camera in VCR mode, connect a firewire cable and open iMovie, that should work. If not open the System Profiler and see if the camera is on the Firewire Bus.
Could be a bad cable or dead camera port, try with other equipment to trouble shoot the culprit.
Sep 18, 2010 | Canon MVX150i Mini DV Digital Camcorder
Download file procedure from p2 card to Mac via firewire
Hello!
Since you own Macpro you need to connect a duel adapter for pcmcia cards and since Macpro has already drivers for P2 ,the rest is easy,just connect and follow the procedure.
PS
You can also download through firewire and usb port.
Feb 21, 2010 | Panasonic AG-HVX200A Mini DV Camcorder
Kodak i260 firewire dead
100/110 board failure, Firewire is placed onboard the CPU PCB 100/110.
Dec 10, 2008 | Kodak I260 Captiva IA-Express Path-Through...
Ipod won't charge
It means the hard drive is crashing. If it's clicking it means there is a problem with the hard drive. Try restoring your ipod or reformatting it.
Reset To reset your iPod:
  • 1. Toggle the Hold switch on and off. (Slide it to Hold, then turn it off again.)
  • 2. Press and hold the Menu and Select buttons until the Apple logo appears, about 6 to 10 seconds. You may need to repeat this step. 5rs_reset_clickwheel.png
    Tip:
    • If you are having difficulty resetting your iPod, set it on a flat surface. Make sure the finger pressing the Select button is not touching any part of the click wheel. Also make sure that you are pressing the Menu button toward the outside of the click wheel, and not near the center.
    • If the above steps did not work, try connecting iPod to a power adapter and plug the power adapter into an electrical outlet, or connect iPod to your computer. Make sure the computer is turned on and isn't set to go to sleep.
OR TRY THIS
iPod's battery doesn't charge Several things could keep your iPod's battery from charging. The major causes are listed below in logical order. Check each one to see if it's what's keeping your battery from charging.
Low-powered USB port iPods that connect to USB ports require a high-power USB port. Keyboards and some USB hubs will not charge iPod. Connect iPod directly to the computer or to a USB AC power adapter. Click here for more information.
Connect directly to computer If you connect iPod to something that connects to the computer (like a USB hub or FireWire drive), connect iPod directly to the USB or FireWire port on the computer.
FireWire port on a Windows PC The FireWire (IEEE 1394) ports on some Windows-compatible computers may not be powered, and consequently won't charge iPod when you plug it in. Check here to see if the FireWire port on your PC can charge iPod.
Your computer goes to sleep Your computer can only charge iPod when it's turned on and not asleep. Make sure your computer is on and not set to go to sleep when you want to charge iPod. Tip: Some Macintosh computers can charge iPod even though they're asleep. If your sleeping computer doesn't charge iPod, don't worry, just wake it and let iPod charge.
You are using Windows 2000 If you use your iPod with a computer using Windows 2000, see document 304801 "iPod: Proper charging procedures for Windows 2000" for steps on how to keep iPod charging.
There are too many devices in the FireWire chain Your computer can provide power to FireWire devices that don't have their own power sources, such as hard drives and cameras. If there are too many of these kinds of devices connected to your computer, iPod may not be recognized.
  1. Disconnect all devices from your computer's FireWire port(s).
  2. Connect iPod to the computer's FireWire port using the FireWire cable that came with iPod.
If this resolves the issue, consider purchasing a powered FireWire hub to connect your nonpowered devices to. These hubs are available from the Apple Store.
iPod is locked up If iPod is locked up it will not charge, reset iPod. When you reset iPod all your songs and files are saved, but some customized settings may be lost. Tip: iPod will not wake automatically if you connect to a 4-pin FireWire port. Press the Select button (center of wheel) to wake iPod.
Faulty cable If something is wrong with the FireWire or USB cable that came with iPod, it may not supply any power to charge the battery. Note: Only iPod models with a Click Wheel can get power from a high-powered USB port using the supplied cable (includes iPod mini, iPod (Click Wheel), iPod photo, iPod with color display, iPod nano, and Fifth Generation iPod).
  1. Make sure you are using the cable that came with iPod. Some third-party cables may not work properly with iPod.
  2. Make sure nothing is in or blocking your computer's FireWire or USB ports.
  3. Check the connections to make sure the cable is completely plugged in.
  4. Try another known-good FireWire or USB cable if available.
If this resolves the issue your FireWire or USB cable needs to be replaced. You can arrange for replacement at the iPod Service Website.
Faulty port on the computer If something is wrong with your computer's FireWire or USB port, it may not supply power to iPod. Note: Only iPod mini can get power from a high-powered USB port using the supplied cable.
  1. Check the connections.
  2. Try another known-good FireWire (or high-powered USB) port on a different computer if available.
  3. If you do not have access to another computer, use the Apple iPod Power Adapter.
  4. Plug in one end of the FireWire cable to the Apple iPod Power Adapter and the other end to your iPod.
  5. Plug the Apple iPod Power Adapter into a working electrical outlet.
  6. If you have an iPod (with Dock Connector) model, connect the FireWire end to the Apple iPod Power Adapter and the dock connector to iPod. Warning: Never plug the dock connector end of the FireWire cable into a computer's FireWire port.
If this resolves the issue, consult your service and support guide to see how you can have the computer's port repaired.
Faulty Apple iPod Power Adapter If something is wrong with the Apple iPod Power Adapter, it may not supply power to iPod.
  1. Try another known-good electrical outlet.
  2. Make sure all the connections are good. Try disconnecting and reconnecting all connections to make sure they are snug.
  3. Try another Apple iPod Power Adapter if one is available.
  4. Try connecting iPod to a computer's FireWire port using iPod's FireWire cable.
If this resolves the issue the Apple iPod Power Adapter needs to be repaired. You can arrange for repair at the iPod Service Website.
You might consider additional troubleshooting steps for the Apple iPod AC Adapter before having it replaced.
Faulty dock connector or FireWire port on iPod If something is wrong with iPod's FireWire or Dock Connector port, it may not supply power to iPod.
  1. Make sure nothing is in or blocking iPod's FireWire or Dock Connector port.
  2. Check the connection to make sure the FireWire or Dock Connector cable is completely plugged in.
If this did not resolve the issue iPod needs to be repaired. You can arrange for repair at the iPod Service Website.
Related Terms: charged, dead, die, dying, drained, draining, drain, drains, frozen, freeze, freezes, freezing
Keywords: ktech kipod kipodwin kipod1 kipod2 kipod3 kipod4 kipod5 kipodphoto kipodmini kipodmini2 kshuffle kipodnano kipodnano2 kshuffle2 Did this article help you?
It solved my issue...
Tell us what works for you.
It's good, but...
Report typos, inaccuracies, etc.
It wasn't helpful...
Tell us what would have helped.
Apr 21, 2008 | Apple iPod MA446LL/A MP3 Player
Firewire Port not working
HAVE YOU HAD THE CAMCORDER ON THE MAINS ADAPTOR WHEN IT WAS CONNECTED TO THE FIREWIRE AS IT HAS TO BE TO POWER THE FIREWIRE PORT!
Nov 08, 2007 | Sony Handycam DCR-TRV320 Digital Camcorder
PLEASE HELP ME! Panasonic firewire connection won't work!
In short, many people have firewire issues such as missing motherboard drivers, or dead firewire ports. You have to show it working on some machine before you know to try to fix your machine. Did you try Movie Maker?
Sep 06, 2005 | Panasonic AG-185 Camcorder
Computers & Internet Logo
20 people viewed this question
Top Focusrite Computers & Internet Experts
David Payne
David Payne
Are you a Focusrite Computer and Internet Expert? Answer questions, earn points and help others
