Question about Kenmore Freezers
The LED temperature light on the fron of my Model 26458 freezer ii not working. I unplugged it for one minute as the troubleshooting section of the manual said and when I plugged it back up, it did a self-check, but the temperature LED did not come on. therefore, I don't know what temperature setting the freezer is on. Can you tell me how to change the bulb, or is it another problem?
  • 126 Answers
SOURCE: high temperature light is always on
could be a leak. have it checked by a tech.
Posted on Jan 13, 2008
bobotfel
  • 236 Answers
SOURCE: FREEZER SECTION WORKING OK, FRIDGE SECTION NOT WORKING
Check the vents of your fridge side if present, if no air then may be your blower not working or some ice formation that blocks the air(try defrosting). Check also your vents for obstruction or overloaded with stocks.
Posted on Jan 26, 2008
22yooper
  • 828 Answers
SOURCE: Freezer Problem
If it started to cool again the compressor was running. Check the condenser and make sure it is clean. Provide as much air movement through the garage as possible . 100 degrees is a high temperature to be operating a refrigerator in.
Posted on Jun 10, 2008
buddymcl777
  • 67 Answers
SOURCE: Changing the temperature on the Isa SP Freezer
It sounds like the control panel is in locked mode. Try pushing the button and holding for 3 to 5 seconds. One of the buttons should unlock doing that. It is set that way to keep kids from messing with the temperature.
If you can't get it google the Isa website and try to find your model or to download a manual.
Posted on May 05, 2009
SOURCE: I have a frigidaire upright
OK, this is a failed controller board, any E4* is Power supply & Controller Board, probably caused by a power spike.You need to get the unit looked at to see if it is able to be repaired, and if parts are available. If you wish to try and repair this yourself, you must get a service manual, to do so, and to be able to order parts.
Posted on Apr 06, 2010
How to reset a samsung refrigerator model number rs261mdpn aftthea power outage
http://www.searspartsdirect.com/partsdirect/part-number/Samsung-Parts/Refrigerator-Parts/DA41-00669A/0046/401/Model-RS261MDPNXAA/1482/0165000
this is the control board you will need for your model if unplugging the unit for 5 minutes doesn't fix the problem. If they are LED lights, then I point my finger at this. This is a plug and play board with molex connectors. Very easy to install with unit unplugged. You can manually reset the display and check for error codes by holding the top left and top right button on your user interface for 5 seconds in unison FOR 5 or more seconds after all the lights flash.
Feb 01, 2015 | Samsung 26.0 cu. ft. French-Door Bottom...
The upright frigdiare freezer displays -10 degrees and runs continusly i couldnt set it to 0
Good Afternoon Friend,
I understand your Frigidaire freezer, model# LFFH21F7HWJ, is displaying -10 degrees and runs continuously. I also see that you were unable to set it to 0 degrees. I suggest resetting your appliance, by either unplugging it or shutting the power off at your home's circuit breaker, for 3-5 minutes. Sometimes there can be a miscommunication between the different boards inside your appliance. Restore power and try the temperature to 0 degrees. I ask that you please follow up with a comment on the post, at your convenience, to advise if further troubleshooting is needed or if your appliances status has changed successfully. Hope this is helpful.
-Best Regards-
WP
Jul 02, 2014 | Frigidaire 20.3 Cu. Ft. Frost-Free Upright...
Frigidaire model ffu2065fw1 light and alarm works but the control module is blank???
Good Morning Friend,
I understand that the light and alarm are working fine on your Frigidaire freezer, model# FFU2065FW1. I also see that you are receiving power to the control module, however it is blank. I suggest resetting your appliance, by either unplugging it or shutting the power off at your home's circuit breaker, for 3-5 minutes. Restore power and try adjusting the temperature. I ask that you please follow up with a comment on the post, at your convenience, to advise if further troubleshooting is needed or if your appliances status has changed successfully.
-Best Regards-
WP
Jun 21, 2014 | Frigidaire Freezers
Why isnt the top part of my Daewoo FRS-U20BG larder fridge/freezer working although rest of freezer seems ok?
Is it just the freezer section? Open the freezer door for a minute and then, without shutting it, press the button on the inside that makes the light go out. The fan at the back at the top of the freezer should start whirring. This circulates the freezing air. If it doesn't start then that's your problem as the freezing air isn't getting to the top of the freezer. It's simple enough to replace. Buy a new part (30 pounds?) and replace from the inside by removing the back panels to the freezer. Turn the freezer off and unplug first though, obviously! Hope this helps.
Jun 16, 2014 | Daewoo FRSU20IA Freezer
First the freezer alarm beeping with red light flashing, inside light went out and freezer standard electronic temperature control display unit no longer lights up.
Hi Loretta, I am happy to assist you!
Based on the symptoms you are describing, it sounds like your freezer may possibly have a communication problem with the control board, a potential wiring failure, or faulty temperature control. Before reaching out to a professional, let's try resetting your freezer. This can be done by either unplugging it or flipping off the circuit breaker. It is important to wait approximately ten minutes. If it proves ineffective, In this regard, I would suggest contacting an Authorized Service Technician that will be able to assist you in the exact diagnosis of the appliance.
Best regards!
Jan 31, 2014 | Frigidaire Freezers
Freezer reset button
Hello Stella, based on the symptoms you are describing it sounds like the temperature control is in the OFF position. When this occurs the temperature control turns off the compressor, but does not disconnect the power to the light bulb or other electronics. Did you try activating the freezer by pressing the UP arrow until display shows "4" or desired setting and allowing 24 hours for temperature to stabilize? For future reference you can lock the control to keep from accidently changing the temperature setting. If so, I recommended resetting the unit by either unplugging it or flipping the household circuit breaker off. It is important to wait roughly ten minutes, then turn the freezer on and redo the previous steps. I ask that you please follow up with a comment on the post, at your convenience, to advise if further troubleshooting is needed or if the unit's status has changed successfully. Thank you.
Aug 05, 2013 | Frigidaire Freezers
I have a kenmore upright frost free freezer mod #253.26432100. A couple of months ago everything defrosted and the unit was not running at all. I unplugged it cleaned it and plugged it back in, it turned...
You have a problem with the ADC.
Frigidaire has also jumped into the market with an adaptive defrost board. The fresh food section light switch and light bulb must work. To initiate a defrost cycle, open the door and push the light switch in and out 5 times within 6 seconds. The compressor and fans should shut off and the defrost heater should come on. Open the door and push the light switch in and out 5 times within 6 seconds to remove the refrigerator from the defrost mode and back into a cooling mode.
This product comes equipped with an Adaptive Defrost Control (ADC). To activate manual defrost, press and hold the Freezer temperature UP (WARMER) key while pressing the Fresh Food temperature DOWN (COLDER) key 5 times within 6 seconds. A "d" in the freezer temperature window and "F" in the refrigerator temperature window will display when the heater is activated. To deactivate manual defrost, press and hold Freezer temperature UP (WARMER) key while pressing the Fresh Food temperature DOWN (COLDER) key 5 times within 6 seconds. "d" and "F" will be displayed until the defrost cycle is complete. (approx. 8 minutes)
Nov 23, 2010 | Frigidaire 20.3 cu. ft. / 575 liter...
We moved our freezer model lffh21f7hwe to another location, turned it on, checked it later and it was -10, I tried to raise the temperature up, now the light says OF. What do we do?
try to unplug the unit for a few minutes.then try and adjust you temp again if you you to high with the temp you will shut it off
Oct 10, 2010 | Frigidaire Freezers
Freezers Logo
54 people viewed this question
Top Kenmore Freezers Experts
AJMAL KHAN
christian nielsen
Dan Webster
Dan Webster
Are you a Kenmore Freezer Expert? Answer questions, earn points and help others
